Re: How far back does the fan need to be from the radiator? [Re: Scojodak] #744612
07/13/10 05:51 AM
07/13/10 05:51 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
I saw a friend at a car show Saturday and he reminded me how i solved his overheating problem. Since he had done about everything I could think of I told him to check the coolant. Sure enough, the coolant was almost pure antifreeze. Cheap and easy to check. Just a thought........
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: How far back does the fan need to be from the radiator? [Re: runinonmt] #744613
07/13/10 08:55 AM
07/13/10 08:55 AM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
I'm going to run to Home Depot today and pick up one of those laser guided temperature gauges. I'm not running anywhere near full antifreeze. The mix I run only floats about 3 of the 5 balls in my tester (don't remember what that equates to) but is less than a 50/50 mix.
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744614
07/13/10 12:56 PM
07/13/10 12:56 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Drove about 15 miles today and stopped at Home Depot to get a infrared temperature probe. It is only 88* out so things were fine. The gauge stayed between "E" and "M" the entire time. When I stopped I left it running and the top tank was 180* and the bottom tank was 166* or so. So I'm getting good cooling across the radiator (I was also thrilled at how well my small trans cooler was working). Maybe it'll really warm up this afternoon and I can try to get it to overheat.
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744615
07/13/10 01:22 PM
07/13/10 01:22 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
14* drop across the radiator isn't very good. Under the best conditions you'd get around 40 degrees.
If it works, it works. If it's getting hot and you can't see anything better than that, you have a problem with either low air flow or coolant moving too fast.
- Stu Harmon
Re: How far back does the fan need to be from the radiator? [Re: feets] #744616
07/13/10 03:07 PM
07/13/10 03:07 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
That was at idle. I think I need an assistant to hold the throttle for me while I check out temperatures.
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744617
07/13/10 03:21 PM
07/13/10 03:21 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You should get a high temperature drop at idle. The coolant is moving slow enough to spend time in the radiator dropping temperature.
- Stu Harmon
Re: How far back does the fan need to be from the radiator? [Re: feets] #744618
07/13/10 04:23 PM
07/13/10 04:23 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Is the fan pulling enough at 700rpm to get adequate air flow?
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744619
07/13/10 04:53 PM
07/13/10 04:53 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If you haven't changed the pulley ratio and the clutch is in good shape, it should be adequate.
- Stu Harmon
Re: How far back does the fan need to be from the radiator? [Re: feets] #744620
07/13/10 06:07 PM
07/13/10 06:07 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I've been thinking that maybe it was the rad considering I've replaced everything else. Now the data really seem to be pushing that way. I'm going to do a tad more testing today. But no, I have not changed the ratio.
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744621
07/13/10 08:17 PM
07/13/10 08:17 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Of course we had rain come through this afternoon and cool everything off. I can't get the t-stat to stay open long enough to do any more testing.
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744622
07/14/10 03:55 PM
07/14/10 03:55 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Finally, some data! The top tank is getting to over 205* when it starts to pass "M." The fins are running about 155* and seems very even across all the fins. But the bottom tank is 175* or so. What in the world does that mean?
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744623
07/15/10 12:17 PM
07/15/10 12:17 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Bump
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744624
07/15/10 12:26 PM
07/15/10 12:26 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
175 in means that you are not getting enough air flow or water surface area.
if it cools down while driving at speed it's not enough air flow.
Re: How far back does the fan need to be from the radiator? [Re: DJVCuda] #744625
07/15/10 02:15 PM
07/15/10 02:15 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
But why would the tubes between the tanks be so cool while the bottom tank is so much hotter?
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744626
07/15/10 02:22 PM
07/15/10 02:22 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
how many rows does it have?
what are the temps of the back tubes?
there should be some reading differences from the inlet to the outlet.
Re: How far back does the fan need to be from the radiator? [Re: DJVCuda] #744627
07/15/10 02:40 PM
07/15/10 02:40 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
It should be three row.
I cannot get good readings on the back tubes because there is a fan moving in the way. If I turn the engine off everything soaks to the same temp.
Top to bottom the tubes go from near the temp of the top tank down to about 150* or even lower for some. But the bottom tank is freaking hot.
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744628
07/15/10 03:00 PM
07/15/10 03:00 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
If the transmission cooler is in the bottom of the radiator that would explain the elevated temps there.
Re: How far back does the fan need to be from the radiator? [Re: bobby66] #744629
07/15/10 04:11 PM
07/15/10 04:11 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I also have an external cooler after the one in the radiator. The entry temp on it is around 150 and the exit temp is 110 or so. I'm really confused about what's going on.
