Re: Let's hear some W7,W8,and W9 builds
[Re: 408strokerdart]
#743317
01/01/12 07:28 AM
01/01/12 07:28 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
9" R3 3.79 Callies 4.185 bore MGP rods 13.8 static 55mm cam 15* Coleman/Arrington W8 420 intake SV-1 3 step header w/Burns merge External wet sump
894hp-657tq
Built to spray a little, but decided to go N/A. Car is now finished just in time for the bad weather. We will run this engine for one season before selling it and doing a full N/A build.
Almost a clone to mine....why is mine such a turd by comparison? Hey Jim, could you share some cam/valvetrain specs on your build? PM if you want. No offense to any others, but this an impressive build for the power output. I am sure I am 100 hp less with almost the same combo and more compression.
Why do you think yours is a turd??? I certainly don't.
Dean has the cam card so I'll post the #s on Monday. From memory, I think we ended up with 1.8 intake and 1.7 exhaust Jesels. 278in/294ex 113 installed 109. Peak hp was 8200 on the best pulls.
We had a good flowing 15* head to start with, then had Matt at MBE work em' over some. They went just over 400cfm @.800 on 2 different benches. Matt also did the bulk of the work on the 420, then we had Gabby open it up when we switched to the 110mm SV-1 from the 1.590 x 1.750 4150 Willey's carb.
The dyno work was on Precision Automotive's inertia dyno. Hopefully it's not too happy. From some other engines that spin on that pump, it seems pretty close. I believe Emilio's engine was pulled on it too. Norman (Precision owner) and my brother tuned about 80hp from start to finish and we actually freshened the engine (including rods) during the dyno sessions, we made so many pulls.
The car is finished so we're going to do some in-car tuning, then make some rent day shots as soon as we get a chance.
The proof will be in the timeslip once we get everything squared away.
[Re: jim sciortino]
#743318
01/01/12 08:02 AM
01/01/12 08:02 AM
Posts: 1,019 Finland
mafo
Finland
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: kingdust]
#743321
01/01/12 11:35 AM
01/01/12 11:35 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
well here it is,i know alot about your car Mark,uncle anthony was gonna sell your cal tracs to my pop..i dont know,maybe it was new yrs booze that made you say,what you did.I will say this though we both live in LI and if theres a prob...we can see each other. I am very friendly with Carl,John Nielson,CHUCK,big PAUL etc etc.
[Re: mafo]
#743322
01/01/12 12:21 PM
01/01/12 12:21 PM
jim sciortino
Trumbull,CT.
waiting for a time slip here...
Hold on a minute, I'll forge one. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: fishy340]
#743323
01/01/12 01:56 PM
01/01/12 01:56 PM
Posts: 189 long island new york
kingdust
LOL, i know you know those guys and and i'm sure thats where you got the your so called (you know alot about my car from uncle anthony) we have another mutual friend that doesn't like when you come on here and talk like you been racin everybody and i said i would break your balls.i have nothing against you and i actually like your car alot. as far as the mutual friend, you'll have to figure that one out.as far as you knowing about my motor and car and all that, its never been a secret,i just dont come on here talkin about how fast this or how much that! as far as seeing each other- i go out to dinner about twice a month with uncle anthony and everybody you mentioned, we can meet face to face anytime you want. ![](/ubbthreads/images/graemlins/tsk.gif)
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
[Re: jim sciortino]
#743324
01/01/12 04:30 PM
01/01/12 04:30 PM
Posts: 84 Minnesota
Coldart
Minnesota
894hp-657tq
Jim, Nice numbers. SV-1's seem to be love/hate, what did you change on intake for it? What size header and are these the headers going in car? Thanks! Mike
[Re: Coldart]
#743325
01/01/12 05:50 PM
01/01/12 05:50 PM
mafo
Finland
Jim, here is a little inspiration for you http://www.youtube.com/watch?v=lx8GwdxSGHIonly a 1.32 60 ft, I need to get that converter working or I have to go with a clutch ![](/ubbthreads/images/graemlins/devil.gif)
[Re: jim sciortino]
#743326
01/01/12 06:10 PM
01/01/12 06:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm curious to what valve size to bore you guys have to what the cam specs are... granted I wimped on my cam for spring life but curious of these specs... I have a 2.18 valve with a 4.125 bore and I'm thinking its shielding the valve inlet... I do believe a bigger bore would help ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Coldart]
#743329
01/01/12 08:25 PM
01/01/12 08:25 PM
jim sciortino
Trumbull,CT.
So far so good with the SV-1. Took the car out today for it's 1st spin and it felt good. The real test will be how it comes up when we get it to ATCO. Idles nice, drives around nice.
We had a ported 598 with the 4150, that went 842hp IIRC on it's best pull. Sold the 598 and had MBE do a 420 that went 861 with the 4150. Gabby opened it up to a dominator flange when we swapped the SV-1 and it climbed to 894.
The headers a 2-2.125-2.250 w/4' Burns merge collector.
It was nice to finally sit in the seat today and break a law (or 2) to ring in the new year. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: mafo]
#743330
01/01/12 08:34 PM
01/01/12 08:34 PM
jim sciortino
Trumbull,CT.
Jim, here is a little inspiration for you ![](/ubbthreads/images/graemlins/thumbs.gif)
Inspiration is good!!! ![](/ubbthreads/images/graemlins/biggrin.gif)
Even with the 60s not there yet, you're still running good, which for an N/A car is no joke. Can't make it up like a nitrous, or boosted car. Engine must make some real steam. I had a car years ago that 60 footed in the 1.32 range and it only ran in the 9.40s.
[Re: fishy340]
#743332
01/01/12 08:47 PM
01/01/12 08:47 PM
jim sciortino
Trumbull,CT.
so a mutual friend,don't like when i say im this and that? looks like i said to Jim not YOU,that he can drop his motor off to me on the ferry! and you say something stupid about me,and how i drove the first time out with my car..well the cats out my man,,i will see you.
I think your car is freakin' SWEET....
When you get a chance, hop on the ferry and meet up with Dean and I. We'll take my car for a ride and grab some food. We're minutes from Bridgeport. Steve Seifert is right near us too, with that beautiful HEMICUDA' of his. We'll shoot the S _ _ T over some grub. Make the winter go by quicker. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Gary Robbins]
#743333
01/01/12 08:52 PM
01/01/12 08:52 PM
jim sciortino
Trumbull,CT.
This thread is useless wihout pics BTW,sounds like a bada$$ ride
As soon as I clean it.LOL
[Re: fishy340]
#743335
01/01/12 09:25 PM
01/01/12 09:25 PM
jim sciortino
Trumbull,CT.
i'd actually love to see the car in person,we had some of the ct boyz here today to watch a real good street race it takes me w no traffic 35mins to be in ct..it would take me over an hr just to get to that ferry.Let me know in a pm,when ur workin on it and i'll take a ride out there w my pops one sat or sun he loves this stuff more then me.
Sundays are good for me. Just say the word. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: jim sciortino]
#743336
01/01/12 09:47 PM
01/01/12 09:47 PM
Posts: 3,456 Out West
408strokerdart
Out West
894hp-657tq
Always nice to compare combos and output. I feel like mine is underperforming by about 2-3 tenths and I use the word "turd" jokingly since some people seem to be able to nail it the first time. I think I can get all mine has to offer with some more passes. Also having Brett work the heads over some in the upcoming month. Probably regrind the cam also after getting some new flow numbers. I just want to see a "real" 850 hp run what it should in a 2850 lb car. Jim, I would be interested in your cam specs when you get the chance. Thanks.
