Re: Let's hear some W7,W8,and W9 builds
[Re: 408strokerdart]
#743337
01/01/12 10:26 PM
01/01/12 10:26 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Always nice to compare combos and output. I feel like mine is underperforming by about 2-3 tenths and I use the word "turd" jokingly since some people seem to be able to nail it the first time. I think I can get all mine has to offer with some more passes. Also having Brett work the heads over some in the upcoming month. Probably regrind the cam also after getting some new flow numbers. I just want to see a "real" 850 hp run what it should in a 2850 lb car. Jim, I would be interested in your cam specs when you get the chance. Thanks.
I'll get back to you tomorrow. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: kingdust]
#743338
01/01/12 11:16 PM
01/01/12 11:16 PM
Posts: 181 Long Island, New York
W7 Duster
well here it is,i know alot about your car Mark,uncle anthony was gonna sell your cal tracs to my pop..i dont know,maybe it was new yrs booze that made you say,what you did.I will say this though we both live in LI and if theres a prob...we can see each other. I am very friendly with Carl,John Nielson,CHUCK,big PAUL etc etc.
LOL, i know you know those guys and and i'm sure thats where you got the your so called (you know alot about my car from uncle anthony) we have another mutual friend that doesn't like when you come on here and talk like you been racin everybody and i said i would break your balls.i have nothing against you and i actually like your car alot. as far as the mutual friend, you'll have to figure that one out.as far as you knowing about my motor and car and all that, its never been a secret,i just dont come on here talkin about how fast this or how much that! as far as seeing each other- i go out to dinner about twice a month with uncle anthony and everybody you mentioned, we can meet face to face anytime you want.
Be careful Mark or they will delete this thread. Post your engine combo instead. Later, Chuck.
[Re: FASTFISH420]
#743341
01/02/12 05:23 PM
01/02/12 05:23 PM
jim sciortino
Trumbull,CT.
9" R3 3.79 Callies 4.185 bore MGP rods 13.8 static 55mm cam 15* Coleman/Arrington W8 420 intake SV-1 3 step header w/Burns merge External wet sump
894hp-657tq
Built to spray a little, but decided to go N/A. Car is now finished just in time for the bad weather. We will run this engine for one season before selling it and doing a full N/A build.
I think Jims dyno is alittle happy..lol
My old motor was real similiar it was 410 inch 4.185 bore 3.72 stroke.It was the Motor that Tim Davis built for Dan Palolini with was a record holder in NSCA real street.Dan never dynoed it. I bought it and had Tim update it,the only thing we changed was the intake to a 420 ported by Davis.It was 16.1 compression.it made 880 on BES dyno and ran 9.18 in my car.It had a weird head I which I had back.CFE 16 degree this motor loved rpm we had it 9400 on the dyno made 880 at 8800. That motor got pieced out along time ago
You may be right.
We questioned it too, but Precision says it's a typical Superflow calibration. On the best pulls, 894hp-657tq was corrected, 886hp-651tq was observed.
We'll find out when we try to show it in the car. Might be time to invest in a data logger. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: W7 Duster]
#743344
01/02/12 10:45 PM
01/02/12 10:45 PM
Posts: 189 long island new york
kingdust
don't worry chuck,i'm done. my car will do the talkin!
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
[Re: 340_Dart]
#1919898
09/26/15 01:54 AM
09/26/15 01:54 AM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
394 ci r3 9.00 14.9cr 3.64 stroke 4.155 bore 850 lift w7 ported heads sheetmetal intake 1050 carb belt drive 1 7/8 headers 3 1/2 collectors 727 trans 2750 lbs 9.20 @ 146 so far..i think it should be faster
[Re: Plymouth340]
#1920029
09/26/15 01:11 PM
09/26/15 01:11 PM
Posts: 1,784 PA
W5DART66
PA
394 ci r3 9.00 14.9cr 3.64 stroke 4.155 bore 850 lift w7 ported heads sheetmetal intake 1050 carb belt drive 1 7/8 headers 3 1/2 collectors 727 trans 2750 lbs 9.20 @ 146 so far..i think it should be faster What did seller tell you this engine made for power?
[Re: 340_Dart]
#1920095
09/26/15 03:15 PM
09/26/15 03:15 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Has anyone built a drag motor based on an A8 sprint block? I know all the troubles with getting parts. Just looking for the durability aspect. I have one sitting here that I could use. It just looks "flimsy" to me. I had dreams of reworking it for p7s, but the cam tunnel would need to be totally replaced. Would mostlikely go with some w8s or 9rps.
[Re: TRENDZ]
#1920264
09/26/15 09:38 PM
09/26/15 09:38 PM
Posts: 159 australia
charger410
australia
Has anyone built a drag motor based on an A8 sprint block? I know all the troubles with getting parts. Just looking for the durability aspect. I have one sitting here that I could use. It just looks "flimsy" to me. I had dreams of reworking it for p7s, but the cam tunnel would need to be totally replaced. Would mostlikely go with some w8s or 9rps. Ex sprintcar engine from Us in my Chug. 410in 4.15 x 3.8 A8 block solid roller 268/50 780lift W9 heads, titanium valves, pac springs, jessel rockers JE pistons Carrilo rods Bryant Crankshaft Barns 4 stage dry sump Kinsler injector stacks 1 7/8 step into 2inch pipes, 3 1/2 collectors Dyno 875hp 652fbs Been running for 4years never touched the engine besides plugs and oil Have only done street events on slippery tracks but will take it to the local 1/4mile track and see how it goes in a week and will post my time here good or bad Cars weight 3412 Lbs I went and did some passes, my car wasn't up to Tec so only a couple 1/8 mile runs before being asked to leave. Managed 1.45 60's, with 6.160 at 113mph. Very ugly too with allot of wheel spin and the [censored] bouncing it wasn't pretty!! Only using half peddle in first A8 blocks would have to be strong they run for 20 laps at full song at 8000-9500 on dirt getting banged around, running over corrugated and grippy parts of the track to find the right line.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
[Re: TRENDZ]
#1920276
09/26/15 09:57 PM
09/26/15 09:57 PM
Posts: 22,822 Bitopia
jcc
Bitopia
My A8's are crossbolted deep skirt early/heavy? blocks, flimsy is not how I would describe them.
[Re: 340_Dart]
#1920305
09/26/15 11:00 PM
09/26/15 11:00 PM
TRENDZ
Milwaukee WI
I think the block your speaking of is the touring series A8. Super cool block to have. Mine is non skirted splayed caps. It has cooling jackets only part way down the cylinder, maybe 3 or 4 inches. There is no "extra" material anywhere on this block.
[Re: W5DART66]
#1920324
09/26/15 11:30 PM
09/26/15 11:30 PM
Plymouth340
CEDAR RAPIDS
[quote=Plymouth340]394 ci r3 9.00 14.9cr 3.64 stroke 4.155 bore 850 lift w7 ported heads sheetmetal intake 1050 carb belt drive 1 7/8 headers 3 1/2 collectors 727 trans 2750 lbs 9.20 @ 146 so far..i think it should be faster What did seller tell you this engine made for power? dyno sheet says 900hp @ 9000..i must be missing something?? I'm shifting at 8000 so far
[Re: 340_Dart]
#1920332
09/26/15 11:44 PM
09/26/15 11:44 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
9.6 deck a set of Brett w8s small valve 2.15.and 1.6 rocker 420 intake ported by me .king billet 4 inch crank.Oliver 6.200 rod. a nasty little 55mm comp cam 12.8to1.running 9.0s 146 at 4400ft 3080lb 68 dart. Step header with merge with more to come .. still working the bugs out..only on my second quarter mile outing... pushing pump 85 through an sv1
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Plymouth340]
#1920405
09/27/15 01:38 AM
09/27/15 01:38 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
[quote=Plymouth340]394 ci r3 9.00 14.9cr 3.64 stroke 4.155 bore 850 lift w7 ported heads sheetmetal intake 1050 carb belt drive 1 7/8 headers 3 1/2 collectors 727 trans 2750 lbs 9.20 @ 146 so far..i think it should be faster What did seller tell you this engine made for power? dyno sheet says 900hp @ 9000..i must be missing something?? I'm shifting at 8000 so far I'd say 225 hp is missing....these dynos can be made to sell engines..#fact
[Re: fishy340]
#1920408
09/27/15 01:49 AM
09/27/15 01:49 AM
Plymouth340
CEDAR RAPIDS
[quote=Plymouth340]394 ci r3 9.00 14.9cr 3.64 stroke 4.155 bore 850 lift w7 ported heads sheetmetal intake 1050 carb belt drive 1 7/8 headers 3 1/2 collectors 727 trans 2750 lbs 9.20 @ 146 so far..i think it should be faster What did seller tell you this engine made for power? dyno sheet says 900hp @ 9000..i must be missing something?? I'm shifting at 8000 so far I'd say 225 hp is missing....these dynos can be made to sell engines..#fact he had bigger dia. headers 1 7/8/2/2 1/8 and diff carb.
