Re: Let's hear some W7,W8,and W9 builds
[Re: 340_Dart]
#743278
07/08/10 07:44 AM
07/08/10 07:44 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Mine is a pretty simple W-9... Chapman CNC ported heads, 9.2 deck 48* siamese block, 50mm cam .700 lift 276/284 @50 112LSA, 14.1:1 CP pistons, 4.125 bore with a 3.79 billet crank... 420 intake with a 1050 dom on E-85, the only trick thing on my engine is the dry sump oiling system... I wish I would have gone with the bigger bore to unshroud the valve... plus I need more cam, would like about .100 more lift... currently its a 405ci ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#743279
07/08/10 08:08 AM
07/08/10 08:08 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Mine is in progress , but is vaguely similar to Mike's. 9" deck and 4.125 X 3.79. The short block was bought on ebay and advertised as a tall deck , which would have given me a lot more options to change things around. But after the hassle and wait I went through before I finally got it ( I could turn this into a bash Rick Liuzzo fest right about now......I'm still not over it or happy with the result ), I decided to forge ahead and make the best out of it. So it will be using a 6" rod ( Crower ) and should be in the 13.5 : 1 neighborhood. I will also be burning E-85 The heads are being done by a local guy ........another thing I would do differently. He is very good , but not MoParcentric......and he has a boat load of customers which I think has back burnered my deal more than once. I have a blank cam core ( solid roller )that will be sent to Bullet once I get some flow numbers. I have an early block with the babbitt cam bearings. Wet sump with a Stef's pan........oiling through pushrods to 1.6 T&D rockers. It will have reverse flow cooling with a remote water pump. I am maybe more interested in reliability than all out performance , so I am looking for strong flow numbers through the mid lift and relatively tame cam specs to make it easy on parts. I am leaning on a H.P. 950 done up by Rob Mix , a local E-85 guru. I plan on streeting this thing a fair bit , so I had to compromise a little bit on how radical I went with certain aspects of the build. I think it is a lot easier to build one or the other.......at least some of the choices I had to make would have been made for me by past experience of others. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: 340_Dart]
#743281
07/08/10 08:17 AM
07/08/10 08:17 AM
MR_P_BODY
What kind of RPM are you guys running those motors @ 405ci?
I normally turn 8000 to 8200... has been mid 9000 but didnt make power up there... later I dynoed it and I make peak at 8100 ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 340_Dart]
#743282
07/08/10 08:46 AM
07/08/10 08:46 AM
Posts: 6,151 Melbourne , Australia
LA360
I had a W8 engine almost finished, it was just getting too costly and I really wanted to go R5/P7 anyway. Rick Liuzzo helped me out a bunch with the deal. The combo was: 9.0" Deck Block 4.125" bore 3.25" Bryant Crank 15:1 JE Piston by Rebco Groden Aluminium Rods W8 13 degree by CFE CFE Sheet metal intake Single 1050 Dominator Weber Belt drive Jesel Front drive Distributor Jesel 1.75/1.6:1 Mohawk rockers Comp 60mm Roller 0.488" lobe, 275 @ 0.050" on a 110 l/s Moroso 5 Stage Pan with an AutoVerdi 6 Stage Pump
With that lobe separation the peak RPM would have been around 8800RPM. When Rick and I first started talking the combo out he was talking more around a 113-115 l/s that would have seen the tacho shoot to around 9000-9500RPM. I didn't see myself being able to afford the Valve Spring bill for the year, so it was toned down a little.
The heads were decent, but weren't a maxed out Pro Stock Truck head, so the engine would have made low 800's at best.
Alan Jones
[Re: LA360]
#743284
07/08/10 09:16 AM
07/08/10 09:16 AM
Posts: 1,019 Finland
mafo
Finland
Mine is:
8.8 deck 4.185 bore 3.55 stroke cfe heads and intake 15-1 mgp rods dual da vinci dominators weber belt drive jesel front dist bullet 5o mm cam psi springs moroso 5 stage pump home made drysump to fit valiant chassis
900+ hp but not dynoed since last version was built shift rpm around 9000 max 9600...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: SB412DUSTER]
#743286
07/08/10 11:42 AM
07/08/10 11:42 AM
Posts: 1,880 USA
Ron Silva
USA
This engine was in my Demon. Still is.
474 CI R3/W9 11:1, small solid roller, set up mostly for the street. Best uncorrected time was 9.92 @ 133 in Phoenix, AZ.
SRT DEMON ONE SEAT
[Re: MIKES_DUSTER]
#743288
07/08/10 12:22 PM
07/08/10 12:22 PM
Posts: 1,880 USA
Ron Silva
USA
I think it was 262 and 268 @.050 and .630 lift (w/1.5 rocker). 108 LSA installed at 104 Int CL.
SRT DEMON ONE SEAT
[Re: 340_Dart]
#743289
07/08/10 09:20 PM
07/08/10 09:20 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
My junk!
417" R3/W8 NITROUS MOTOR 9.16" DECK, 48* SIAMESE BORE, R3 BLOCK, 4.185" BORE CALLIES DRAGON SLAYER 3.79 STROKE CRANKSHAFT PRO GRAM BILLET MAIN CAPS 50MM CAM TUNNEL COMETIC HEAD GASKETS BUSHED LIFTER BORES GRP ALUMINUM RODS 5.90" DIAMOND CUSTOM NITROUS PISTONS W8 CNC COLEMAN/ARRINGTON HEADS W/ TITANIUM VALVES T&D MACHINE 1.60 RATIO ROCKERS ISKY ROLLER LIFTERS CRANE/MONTE SMITH CUSTOM NITROUS SOLID ROLLER CAMSHAFT MILODON GEAR DRIVE MP 9.20" DECK TIMING COVER ATI BALANCER MP '598 WILSON PORTED INTAKE W/ MONTE SMITH FOGGER KENT RITTER FAB. ALUMINUM VALVE COVERS CHARLIES FAB. ALUMINUM CUSTOM OIL PAN MSD DISTRIBUTOR MSD CRANK TRIGGER STOCK CAR PRODUCTS OIL PUMP MOROSO 3 VANE VACUUM PUMP W/ REGULATOR
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#743290
07/08/10 09:21 PM
07/08/10 09:21 PM
Plumb Wired
Blue Ridge, VA
My other junk!
430" R3/W8 TURBO/PROCHARGER MOTOR 9.20" DECK, 48* SIAMESE BORE, R3 BLOCK 4.250" BORE MP BILLET 3.79 STROKE CRANKSHAFT BCR BILLET 4 BOLT ALUMINUM CAPS 50 MM CAM TUNNEL ORINGED DECK W/ COPPER GASKETS BUSHED LIFTER BORES BME 500 SERIES ALUMINUM RODS 6.00" VENOLIA CUSTOM TURBO PISTONS W8 CNC COLEMAN/ARRINGTON HEADS W/ TITANIUM VALVES JESEL ROCKERS COMP CAMS ROLLER LIFTERS CRANE/CAM MOTION CUSTOM TURBO SOLID ROLLER CAMSHAFT MP/ALBERT RACING ENGINES CUSTOM TIMING COVER WEBER BELT DRIVE ATI BALANCER MOROSO FAB. ALUMINUM VALVE COVERS CHARLIES FAB. ALUMINUM CUSTOM OIL PAN MSD DISTRIBUTOR & WIRES MSD CRANK TRIGGER PETERSEN CUSTOM DRIVE MANDREL
Mike Gray
RIP Monte Smith
[Re: mafo]
#743292
07/09/10 08:34 AM
07/09/10 08:34 AM
Posts: 70 Finland
mopar396
Finland
Almost ready: R3 48# 9.2 deck Mopar billet crank 3.55" Lemans W8 heads Belt drive SMRE cam C&S aerosol billet 950 tuned to E85 With F3 procharger
MOPAR OR NO CAR
[Re: mopar396]
#743293
07/09/10 09:51 AM
07/09/10 09:51 AM
Plumb Wired
Blue Ridge, VA
Andy, best so far on motor in the summer heat 6.03 @ 114mph / 9.49 @ 141mph, 3180#. Keep in mind the camshaft in this motor it likes the N2O. Now if we can just get it to 60ft. Mike Gray
RIP Monte Smith
[Re: Plumb Wired]
#743294
07/09/10 11:19 AM
07/09/10 11:19 AM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
416 inch W8
9.0 deck R3 358WC block LA enterprises kryptonite crank grp aluminum rods diamond pistons,titanium wrist pins pro stock ring pack 10 degree CFE W8 heads pro stock weber belt drive jesel rockers 1.9 60mm cam tunnel 60mm LSM swap fire cam fully ported 420 intake 2.19 bore CFM carb peterson external oil system star vacuum pump
haven't seen it in awhile..lol
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: Stroker Scamp]
#743296
12/29/11 06:42 PM
12/29/11 06:42 PM
ggddemon
anybody wanna add to this
O.K. 477ci solid alum block/sleeved to 4.180... no water here! diamond pistons/ 15.2 4.125 crank GRP rods/peterson pump/stefs oil pail/hamburger pan Nickens built sheet metal intake w/2- toilets on VP's M5 CFE's magic on solid W-8's/ jesel's 1.6 rockers on top SCE's W/8 covers 2-2 1/8 stepped headers made locally and ceramic coated. dyno'd..1022hp and 681 tq. Haven't got a chance to play yet.
