Horrible rattle is driving me crazy! Solved!
#740861
07/05/10 02:12 PM
07/05/10 02:12 PM
Posts: 5,660 Flint, MI
Gusteve
I Love the Unicorn Song!!
Flint, MI
Hey all,
Whenever I hit a bump in my 68 charger it makes a nasty rattle. It sounds like my trunk is full of loose metal parts that are bouncing up and down. I can't seem to find where its coming from.
It's done this since I first bought the car years ago, but I never worried about because I knew I was going to replace a lot of stuff, and that would probably fix it. After replacing the rear suspension, shocks, fuel tank and exhaust, its still there.
Everything I've replaced is nice and tight. I can't figure out what else is left that would make this kind of racket. I thought maybe it was the metal pieces that make up the trunk-lid spring mechanism. I covered the metal rods with rubber hose in areas where they might touch. That didn't help.
Any other ideas?
Re: Horrible rattle is driving me crazy! I can't find it.
[Re: DennisH ]
#740864
07/05/10 02:42 PM
07/05/10 02:42 PM
Gusteve
Flint, MI
At one point I had the entire interior stripped, so I know there's nothing in the back seat area. As I said, all the rear suspension parts are brand new and tight, exhaust is new and tight. Maybe I'll run my shopvac down into the wheelwells in the trunk.....
[edit] -looking at it again I wonder if there's junk in the forward portion of the wheel-wells. I suppose I've have to to pull the back seat and the rear trim panels off and see. But its really a racket, and I can't imagine just a few misc nuts and bolts causing all the noise.
[Re: stumpy]
#740867
07/05/10 03:51 PM
07/05/10 03:51 PM
Posts: 1,105 Ont, Canada
moparo
Ont, Canada
Check your top rear shock bolts.
Pinion snubber screws
performancecarrestorations.com
[Re: can.al]
#740874
07/06/10 12:06 AM
07/06/10 12:06 AM
Posts: 587 minot north dakota
ledft79
minot north dakota
Hop in the trunk and have some one give you a ride down the back alley while you listen. Just a thought. It may help pin point where the noise is from.
DRIVE EM, DONT HIDE EM.
[Re: MO_PA]
#740878
07/06/10 09:35 AM
07/06/10 09:35 AM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
Check the rear seat cross brace lower section....my spotwelds cracked & this would rattle horrendously. Note my numerous failed attempts to fix it without a welder (finally borrowed a friends welder & went at it)
1MYTGTX
[Re: moparo]
#740879
07/06/10 09:48 AM
07/06/10 09:48 AM
Posts: 1,210 Rochester, New York
GregY
Rochester, New York
Exactly what I was going to say. Just fixed a rattle on mine caused by loose snubber bolts.
[Re: Gusteve]
#740880
07/06/10 10:00 AM
07/06/10 10:00 AM
Posts: 329 Orange Park, FL
MRHWS
Orange Park, FL
Did you install the fuel tank pad when the tank was replaced?
1973 Charger SE
1974 Charger Rallye 440 Aztec
2008 Charger SRT8
