A/C question #739903
07/04/10 09:18 AM
07/04/10 09:18 AM
Tires are smokin , Iowa
1Adam12 Offline OP
super gas
1Adam12  Offline OP
super gas
Is switching from R-12 over to R-134 freon the way to go on the classic Mopars?
Re: A/C question [Re: 1Adam12] #739904
07/04/10 11:03 AM
07/04/10 11:03 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
it makes it easier when it comes time to fill your system. R12 is a little harder to find and costs a lot more than R 134. IMO, if your fixing up your a/c set up, switch to R 134.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: A/C question [Re: mopars_1] #739905
07/04/10 12:22 PM
07/04/10 12:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
They do make some substitute fro T12.Just have to be careful as some of the cheap stuff did have propane benzyne etc in it.Its as pricey as R12.Basically if you can find 12 you cant buy it unless you have a cert.Its just easier to change to 134.Just replace the dryer and have a vacuum pulled along with the Orings.The new Orings are avaliable in all sizes.That and add some oil to the system.Rocky
Chrysler Firepower
Re: A/C question [Re: therocks] #739906
07/05/10 09:32 AM
07/05/10 09:32 AM
1Adam12 Offline OP
super gas
1Adam12  Offline OP
super gas
Re: A/C question [Re: therocks] #739907
07/05/10 12:10 PM
07/05/10 12:10 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Don't forget to change the compressor oil to 134 compatible oil. r12 oil + r134 = Booom!
Kevin
