Re: Tremec based 5 Speed swap...how much did it cost you ?
[Re: AlexP]
#73909
06/15/08 12:32 PM
06/15/08 12:32 PM
Posts: 3,076 Renton, Wa.
Classof70Chally
super gas
super gas
Renton, Wa.
The cost will vary depending on what you need. The 4 spd to 5 spd 'kit' prices assume several things. Some of these include that you send them your existing bellhousing to be remachined for the Tremec. If not then a new Kiesler unit is about $300. A pistol grip will run you about $140? if you don't already have one and a decent clutch and press plate will be another $300 or so. They will also make up a new driveline (incl in kit) but they require that you to first install the trans, measure the distance, and then fax them the info. Then about 2 weeks later you get your driveline. My 4 spd to 5 spd swap cost me $4,300 + or - but I upgraded the clutch, bought a new press plate and pistol grip and bought their bellhousing. I think the minimum you could get away for with the basic kit will be around $3,500 after shipping, etc. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 5spdcuda]
#73917
06/16/08 09:22 AM
06/16/08 09:22 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Under $3k
I think a B body would be much easier than my E-body swap.
Start with a Mustang spec TKO600 and get a Lakewood bell. Turn the TKO bearing retainer to Mopar size and re-fit. Mock it up, mark bolt holes in lakewood and drill. Bolt it together with flange nuts inside and tack weld nuts.
Use factory clutch linkage with a Jeep 4.0L throwout bearing with is a dead ringer for the mopar one but fits the Tremec bearing tube perfectly.
The TKO's use a Chevy spline and since GM and Mopar Pressure plates have the same pattern I was simply able to buy an off the shelf 11" clutch kit from Summit for an GM product.
Since the B-body shifter position is located forward more than the E-body you would have to relocate the shifter to one of the other positions. It will be on center rather than offset to the drivers side.
Theres more homework to be done but that the jist of it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: rj8806]
#73923
06/16/08 05:07 PM
06/16/08 05:07 PM
Posts: 363 Richmond, TX
Sinister68
Richmond, TX
>$5K for the whole conversion kit from Automatic to TKO500
-James
2013 Challenger SRT
1968 Charger R/T
