8 3/4 diff markings and ID help..
#73694
06/14/08 07:06 PM
06/14/08 07:06 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Re: 8 3/4 diff markings and ID help..
[Re: OzHemi]
#73695
06/15/08 12:09 AM
06/15/08 12:09 AM
Posts: 8,510 Candler,NC / Myrtle Beach, SC
JDMopar
![](/ubbthreads/images/graemlins/scope.gif) If it's an E-body rear, it's from a 70 model car. The parking brake cables both run to the drivers side on 70's. It's possible that it's a C-body rear. The only difference I have been able to find between the C and E housings is the placement of the brass T for the brake lines. I'll have to look under my Challenger,and then at a C barge rear out back to be sure. Right now it's dark,it's raining, and I'm lazy! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: OzHemi]
#73696
06/15/08 12:53 AM
06/15/08 12:53 AM
Posts: 243 St. Louis, MO
DodgeMaterial
St. Louis, MO
The yellow "F E" means: F = 1970, E = E-body. I have "F B" on my 1970 Coronet. Fairly common markings. Hope this helps Dave.
DodgeMaterial - Dave
JS29U0B - FK5 - 440-4 Auto
WS23V0A - EB5 - 440-6 Auto
[Re: JDMopar]
#73697
06/15/08 12:28 PM
06/15/08 12:28 PM
OzHemi
Garden Grove, CA
Dang, talk about slack ![](/ubbthreads/images/graemlins/tonguue.gif)
If it ever stops raining there before the snow starts, thanks for looking for me ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: DodgeMaterial]
#73698
06/15/08 12:28 PM
06/15/08 12:28 PM
OzHemi
Garden Grove, CA
Thanks Be interesting to know what all the other markings are too ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: screamindriver]
#73701
06/15/08 11:43 PM
06/15/08 11:43 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
11-10-X on the housing is the rear axle assembly date {11/10/69}... ...And the yellow 079 on the axle tube is a quick assy line reference for the rear...This code should be on the build sheet also...
I don't see an 079..Maybe an 078 or an 073...
073 = 1970 E body 3.23 open w/11" drums a 489 case & 7290 yoke
078 = 1970 E body 3.91 Sure Grip w/11" drums a 489 case & 7290 yoke
079 = 1970 E body 3.54 Dana 60
[Re: 1_WILD_RT]
#73703
06/16/08 08:46 AM
06/16/08 08:46 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
1_WILD_RT:
Would you happen to know the 3-digit number code for a '68 B-body 3.23 open with drums? Looks like my '68 Hemi Charger R/T has a number of 242 or 042 on the housing, but can't make it out perfectly...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: OzHemi]
#73704
06/16/08 11:51 AM
06/16/08 11:51 AM
OzHemi
Garden Grove, CA
What about the 8Y3, any ideas?
![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: hemi68charger]
#73706
06/16/08 12:53 PM
06/16/08 12:53 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
1_WILD_RT:
242 = 1968 B body 3.23 open 11" drums 742 case & 7290 yoke
[Re: 1_WILD_RT]
#73707
06/16/08 02:02 PM
06/16/08 02:02 PM
hemi68charger
Houston, Tx
1_WILD_RT:
Bingo... That's what I thought............ NOW, if I can find the stencils for that.. I know Sylvain carries products such as this for hoses and such, but I need to verify rear end housings... Anyone out there have sources for the stencils? This just verifies to the na-sayers I've come across what I've told him, not all hemi cars had suregrips...
Thanks alot........
[Re: hemi68charger]
#73709
06/16/08 03:03 PM
06/16/08 03:03 PM
Posts: 93 Jacksonville, FL
burnt_o_matic
Jacksonville, FL
Those originals are usually pretty sloppy. You could just make yourself a potato stamp.
