Couple Edelbrock Motors on Dyno
#735888
06/28/10 07:25 PM
06/28/10 07:25 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Never dynoed an Edelbrock head motor before, have ported tons of castings & built fair amt of E head motors, but no one ever wanted them dynoed... & then all sudden I have 2 on in a week... Business seems to work that way sometimes.
I'll just give basics of each....
1st Motor: 360, .030" over 365 CID 3.58" SCAT 4340 crank 6.123" H beams Custom Ross 4.03" Flat tops 1/16 rings 11.04:1 compression Milodon 7 QT pan Mechanical water pump Comp Cams Solid roller, 264/271 @ .050", .655"/.640" 108 LSA PRW moly rockers, 1.5:1 Hughes CNC Edelbrocks, 2.08"/1.60" valves Fully "ported" Edelbrock Super Victor intake Pro Systems 950HP
2nd Motor 340, .030" over 416 CID 4.0" K1 Crank 6.125" K1 H beams Off shelf Diamond 4.07" Flat tops, 1/16 Rings 12.4:1 Compression Moroso 8qt pan Mechanical water pump Bullet Solid Roller 272/274 @.050" .670"/.655" 108 LSA Hughes 1.6:1 aluminum rockers Shady Dell Stage 2 Edelbrocks, 2.02"/1.60" valves Port matched Edelbrock Super Victor 750 Speed Demon
Ran both motors with my 1 7/8" dyno headers....
The 365 came in to me as a complete engine that kept burning up Comp Pro Magnum rockers since it was converted to roller cam... All I did to it was modify oil system, install PRW rockers, & changed spring/retainer/lock/cup combo to something that would work better than what was on & would clear the large arches on underside of the PRW rockers. Heads had been milled to edge of intake seats to help compression, intake manifold supposedly had $800 in "port work" done to it... it looked nice, but was almost all just sand roll work/casting removal. I put set of 1.50" OD PAC springs & a 1.35 OD CV products Ti retainer combo on & shortened the installed heights down to 1.90 from the unruly 2.0" where they had been @ before. I did'nt even know you could get a 2" spring on a SB E head! Even with the small diameter spring/retainer I still had to trim some of the arch on the rockers about .030" Roller springs & SB E heads/rockers just don't play together nice without having to get crazy & machine rocker pedestals off...
So I grooved the camshaft, & hand honed the rocker bodies, installed T&D adjusters & few other little things & rockers looked like new after day of thrashing. The Comp Pro Mags made it 1/8 mile before they had welded themselves to shafts... So that one seems to be healthy in the valvetrain once again. Main cap walk, that's another story...
The 416 was a budget deal for local guy who races @ Beaver Springs, just wanted all off shelf parts & a good "bang for the buck" stage 2 type port job on the heads. K1 Crank/rods/set of Diamond FT's. Ran set of Howards lifters (same as Doug Herbert) etc.
I decided to go for compression on heads, so I could run a good bit of cam in it, so instead of doing any deshrouding/enlarging/reshaping of chambers like I normally would, I left them physically as small as I could... Basically just sand rolled them & blended in sharp edges left from the top cut of valve job where it intruded on port side walls... with doing this & milling heads to edge of intake seat I was able to get a 57.5 CC chamber which gave me right at 12.5:1. If I had done some chamber work, I'd probably have been at least in the 61-62 range, which really would'nt have killed compression too bad, still would be over 12, but again the budget was'nt calling for killer head work, so I just left chambers alone & hoped they would work ok, figured I'd use it as an experiment. Focused more on intake ports & did very basic bowl blend on exhaust side. Wish it had little bigger valve in it as well but again no $ for such extras...
Customer had supplied a used up Holley Strip Dominator... I found issues with it & had to make tactical decision to replace it. Normally I'd just put a regular old Victor 340 on it but I was able to score this Super Victor for almost $100 less than Summit gets for one somehow through another source brand new... so went with it. Am not a huge SV fan, but was curious to see how the 416 it compared to the 365 & kind of wanted to keep manifold same to eliminate a variable in equation.
Anyhow.... on to the results....
The 365, I thought would make 555HP/460 TQ The way it came in the door, I was real close, it was in the 556/455 range after initial pulls. I was thinking it would hate the SV intake (way big for it) but TQ was not that far off... we put HVH spacer on & was instant 16 HP, confirming my suspicion that the intake was bit big for this motor. Normally don't see anywhere near that kind of gain with a tapered spacer, usually about 1/2 of that if lucky.
Ended the day with 38 timing, 1" HVH & 577HP/471TQ
Today we ran the 416... I was shooting for 620HP/540 TQ...
Started the day with 32 timing & a 950 HP. Slowly Worked way up to 606 HP/535TQ with 35 timing with that carb & a 1" HVH. This was my carb, so did'nt want to spend alot of time messing with tuning it, did one jet change & that was it... Customer had brought a new Dominator that he was planning on buying off a buddy of his, so we figured we'd spend our tune time on it...
So on went the 1050 with a 2" adapter.... was some brand new whiz bang TRC? 1050... looked nice, & as usual with most "pretty carbs" from unknown sources, it would not make a clean pull... 580's power & that was after hour & half of messing with it just to be able to get 1 pull with it. Progressive linkage was binding up both opening & closing etc. It was a disaster... I warned the customer as soon as I saw it, I told him most of those aftermarket messed with Dominators unless it is coming out of a reputable shop like Pro Systems or Cubic etc. usually don't work for one reason or another. Idle air bleeds WAY off etc etc. After 1 pull I just said get it off there... send it back. So then he had an old 750 Speed Demon that he had ran on mild low 12 sec 340 for past couple years... bolted it on & bang, 619HP/544 TQ Wideband #'s & EGT's dead on where we wanted to see them.... did not even think about playing with jetting on it, just left it alone, we got our 620 & it sounded good. My 950 has been fast down the track on several different cars & been on bunch of motors here & there, it's a GOOD piece, but this 750 Demon worked really well on this combo, I was definitely surprised....
The 416 made over 500 FT lbs from 4400-6400.
Peak HP was @ 6400, & we pulled it to 6700 & it was still 614 HP @ 6700. Looking back, I think we should have tried 6900 or so... but I was little wary of the hughes rocker system & 625 lb springs & ton of RPM. This is bracket motor, so I'd rather keep it happy & alive than go after every last RPM on it.
I was little surprised @ how well it hung on up top for small CSA/runner/valve head on so many inches... Seems like most guys who run 4" Crank E head motors shift in low 6's.
Peak TQ Was @5100 RPM, pretty typical 4" crank, small head.
But anyhow, was nice to finally see some #'s off of some non typical (for me anyhow) engine combos. Gives me a better feel for what various configurations of Edelbrock head work can accomplish, & I gotta admit the super victor surprised me a bit on both, I really thought the TQ would be hurt more than it was, the 416 made hair better TQ per inch, but @ 1.29, the 360 was not BAD at all for this dyno.... The EGT's did show some issues with the overall design, but don't think it was anything critical.
Good learning experience.
Re: Couple Edelbrock Motors on Dyno
[Re: RyanJ]
#735890
06/28/10 07:57 PM
06/28/10 07:57 PM
FastOne
[Re: mopardamo]
#735893
06/28/10 08:14 PM
06/28/10 08:14 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Hello,
Love posts like this with such great info.
Thanks RyanJ
Damon
I agree..I love the engine dyno posts.
Nice work, RJ.
[Re: RyanJ]
#735898
06/28/10 10:25 PM
06/28/10 10:25 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
Ryan, thanks for taking the time to post that. Appreciate it.
Q: (Ballpark) how much material is usually removed from the head to mill it to the edge of the intake seat?
Also interested in what fuel was run in each one.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#735903
06/29/10 08:21 AM
06/29/10 08:21 AM
RyanJ
moparts member
moparts member
State College, PA
That particular set of heads on the 416 we took .064" off to hit the edge of intake seat.
I actually ran 112 Sunoco in both motors as it's all I had lying around @ the moment.... The 365 probably could have ran on pump gas, but I like to stay safe & not try to hurt parts during a dyno session. Don't need to be detonating stuff for no reason.
[Re: meus31]
#735904
06/29/10 08:29 AM
06/29/10 08:29 AM
RyanJ
moparts member
moparts member
State College, PA
nice builds ryan. i sent you a set of e brocksfor a customer of mine about 4 years ago. its a 408 pump gas deal. well know he,s board of running 10.40 and want to step up too compresion and a bigger cam and also a custom set of pistons with a nice ring pack and such and he has a super victor as well. his heads were your stage two with the 2.02. want to try and get all he can out of the heads and the intake and step up too a vacumn pump. what kinda steam do you think you could in a optmized package is 650 doable?
This 416 with a vacuum pump, light ring pack, chamber work, little more exhaust port work, 2.055" valve, good custom oil pan would be around 645 HP. Race block, convert intake to 4500... maybe 660 out of an all out effort E head deal with CID in the 420-425 range.
In other words about 100 Less HP potential than an all out INDY head type motor.
But this 416 made good power... made exact same power on this dyno as a 394" 48 degree W2 I did here a few months ago. it made 621, @ 13:1, 48* 47 CC chamber 15 degree valve angle W2, fully ported with 2.055's, 3.58" stroke & 4.185" bore in an R3, .043" rings, T&D rockers etc. Only thing "holding back" that motor was it was a circle track class motor that was required to run a flat tappet & I had like a 262 @ .050" FT based off an .875" Ford lobe in it (pretty mild ramps).... Cam like was in the E brock motor would have pushed that one well into the 660's, but still for an Edelbrock head to run with a ported 48* W2, is pretty good.
