Re: HELP, stroker crank not spinning freely when torque
[Re: JohnRR]
#734244
06/29/10 10:20 AM
06/29/10 10:20 AM
Posts: 16,932 NC
440Jim
NC
Jim, did you have to clearance your bearings?
Some will definitely be better than others, the first one after a sandpaper change would be alot better than the last .
No. Both of my low deck blocks are machined for 440 mains with the aluminum main caps. The cranks are RB 4.250" (Current motor Callies, backup 440Source), and I am using MS-1277HG bearings.
