Re: Best brand of pump Super Unleaded
[Re: Thumperdart]
#733691
06/25/10 11:52 PM
06/25/10 11:52 PM
Posts: 945 La Vernia, Texas
Pat7272
La Vernia, Texas
In my opinion - Exxon (93 here in Texas)
from what I`ve heard, a lot of the gas comes from the same wells
Crude is (more or less) crude, it has everything to do with the refining.
Really, the fuel probably isnt all that different as long as you stick with a name brand and dont go to a shady, run down looking station. So good luck!
Props for running pump gas, IMO the coolest cars racing today are on pump fuel!
[Re: marvo451]
#733693
06/26/10 10:14 AM
06/26/10 10:14 AM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
With 225 psi cranking compression, I have to get my pump gas at this station. These are the unleaded choices. They even have 110 leaded race fuel at the pump for as cheap as I have found it anywhere.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#733694
06/26/10 10:47 AM
06/26/10 10:47 AM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
I wish we had those kind of pumps here but the 94 sure is expensive there! We have a 20 cent differance from 87 to 93.
I noticed in my MPG testing that I always got my best MPG useing BP, I don't know why but I could get another 20 miles per tank with BP. We don't have BP here so I tried a bunch of different places with little differance, even the stuff advertised as "no ethanol" and none stuck out to me except the "smiths" gas station here, Some reason it takes about 2 gallons less to fill my dakota or durango, I don't think it is better gas but the calibration of the pumps, I have ran way longer than I ever should after it hits the empty mark and it just won't take as much as it will from the other stations but it goes the same distance before hitting empty.
As for HP or true octane above or below what is on the pump I just don't know.
One more thing to think about when buying fuel is what auto makers dub "Top tier gasolines" they have the most consistantly high detergents in the gasoline. If I remember correctly Shell, exxon, and BP were on there. Top Tier is a special rateing they came out with for fuel makesrs that meet a certain standard for keeping engines clean.
[Re: marvo451]
#733697
06/26/10 09:56 PM
06/26/10 09:56 PM
Posts: 18,025 S.E. Michigan
ZIPPY
S.E. Michigan
I've had the best luck with:
1. BP/Amoco 93 2. Mobil 93 3. Shell 93
In that order....meaning I really try to run BP/Amoco all the time if possible, the other two in a pinch.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#733698
06/26/10 10:45 PM
06/26/10 10:45 PM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
I run Sonoco Ultra93, they used to have Ultra94 in my area.
[Re: marvo451]
#733700
06/27/10 12:10 PM
06/27/10 12:10 PM
BradH
As the post says....what is your favorite brand of pump super unleaded? Best brand of pump Super Unleaded
What choices do you have where you live?
[Re: B5 Bee]
#733701
06/27/10 01:21 PM
06/27/10 01:21 PM
jbc426
West Coast, USA
98 octane?? That's an 86 octane decal installed upside down.
Yah, I saw that too, but this "pump gas" sticker is straight up the coolest of the bunch!...lol
[Re: jbc426]
#733702
06/27/10 02:09 PM
06/27/10 02:09 PM
the whole notion that the gas at different stations is different is almost laughable, at least around here. we see the trucks/tankers lined up at port everglades with chevron, shell, BP, hess, and no name carriers, etc. and they all fill up from the same hose that comes from the same tank. all of those companies have different marketing for the same additives. do some real research to confirm this.
[Re: marvo451]
#733705
06/27/10 09:45 PM
06/27/10 09:45 PM
BradH
We only have Exxon, Chevron, Shell and Phillips 66 readily available.
If there really is any difference between them, I'd vote for Shell.
What I run around here (mid Atlantic) is either Sunoco or Shell.
Years ago David Vizard did some comparison of various pump fuels and did find some distinct differences between the brands. However, his info is probably so outdated today that it's not worth digging up for reference.
[Re: jbc426]
#733707
06/27/10 10:39 PM
06/27/10 10:39 PM
jbc426
West Coast, USA
The station I got this picture of the pumps a few weeks ago is in Northern California's Bayarea. There are also several VP stations and I believe one Chevron station carry 100 octane Unleaded. They all meet the strict California emissions regulations, but of course the 110 octane leaded fuel is for race use only and not legal for street cars.
They are making it more difficult to even buy leaded race fuel here anymore with out giving them lots of personal info and specifying which licenced race car it is going to be used in including when and where.
