Re: M/T Street Drag Radial Users
[Re: Kudakidd]
#732943
06/24/10 07:34 PM
06/24/10 07:34 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I ran 28-30 on the street with mine,and14-ish at the strip@ 3200 lbs..Start around 16 and go down from there,it depends on car weight,etc. M/T says no less than 12 psi if I remember correctly.
[Re: dustergirl340]
#732946
06/24/10 08:28 PM
06/24/10 08:28 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
28 on the street and 20 work good at the track over 3300 pd car, but if you race a lot they will not last long, just FYI
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
chico
[Re: Crizila]
#732950
06/24/10 09:47 PM
06/24/10 09:47 PM
Posts: 7,863 Witness Protection Program
Kudakidd
I bought a pair slightly used (255/60-15) for a great price. Here's the help I need. What psi do you use on the street? At the drags? And is there any other tire characteristics I should know about. Thanks in advance, KK
I didn't like them. They shed lots of rubber during a burn-out. They would get "gummy". Could never get a feel for them - hooking or not. Be prepared to remove lots of rubber from your 1/4's.
Speaking of burn outs, do they like short ones or long John Force types?
[Re: caper]
#732951
06/24/10 09:48 PM
06/24/10 09:48 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
My car is 3800 lbs , I run 19 lbs at the strip
HOLY COW your car is a pig
That's a heavy Dart. But I really dig it
I usually use 18-19 pounds too.
codfish
[Re: Dunnuck Racing]
#732953
06/24/10 10:11 PM
06/24/10 10:11 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Absolutely not.. Start at 20 and adjust from there.. I took someones advice and tried to drop the air pressure to 15 and the car would not hook at all..
True Dat!!!! These things are aweful during burnouts.. One time I did a show off move and a monster burnout at the Cannery during Vegas a couple years back.. It took me over 2 hours to clean the rubber boogers off..
But, I have found if you spray the 1/4's with Tri-flow or WD-40 prior to a burnout, it doesnt stick as well and cleans up very easy with a little kerosene..
I have found a decent smoky burnout first thing in the morning and then just a quick little heat-up for the rest of the day works best..
[Re: Jeepmon]
#732954
06/25/10 09:53 AM
06/25/10 09:53 AM
Posts: 233 Amarillo, Tx
daithi2
Amarillo, Tx
24# street 12# strip. one hard burnout for first one and very light burnouts after that. usually dont get a good hook until 2nd or 3rd pass.
47 Dodge - turbocharged 493"
05 SRT6 - Only 10 second and fastest SRT-6
[Re: Crizila]
#732956
06/25/10 12:21 PM
06/25/10 12:21 PM
Posts: 951 Alliance, Ohio
Valiant_Showoff
Alliance, Ohio
That's why you make polished stainless steel mud flaps............
[Re: MIKES_DUSTER]
#732958
06/25/10 12:29 PM
06/25/10 12:29 PM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
I run the 325/50-15's and I normally run 15psi. I am 3380 race wieght and have been 1.29 60's foot braking in cold weather. Normal 60's this time of year are 1.32. The do shread some rubber, but I see guys burning them way too much. As with everything else the cahssis setup will play a factor. On a good track, as soon as they bring the motor down (sometimes hardly smoke at all) I roll out. I run consistent 6.teens in the 1/8 and have been 6.02 and 9.50's in the 1/4. I am on my 5th set and won't even consider anything else. car is deadly consistent. the driver? not so much
