Re: 440 with a 292/509 cam good street combo what u say.!!
[Re: joewhite440]
#731424
06/24/10 12:55 PM
06/24/10 12:55 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I have an Indy-SR headed 440 and I use Comp's XE295HL grind. I think it's a much better profile than the .509". If you don't want to go with a solid cam, the XE295HL grind is about as good as it gets. ![](/ubbthreads/images/graemlins/Twocents.gif) You've got a nice car. Good luck. ![](/ubbthreads/images/graemlins/thumbs.gif)
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: joewhite440]
#731425
06/24/10 01:13 PM
06/24/10 01:13 PM
Posts: 768 Maryville tn
67coronetman
Maryville tn
Thanks For the reply and i like the old school ways too.!!
Old car are me......
[Re: 1968RR]
#731426
06/24/10 01:15 PM
06/24/10 01:15 PM
67coronetman
Maryville tn
Thanks for the info and yes sir it now has turned out to be a fun car and its very clean and i will be making some changes soon so once again thanks have a great day.!
[Re: joewhite440]
#731427
06/24/10 03:22 PM
06/24/10 03:22 PM
67coronetman
Maryville tn
Hey Joe its was nice talking today hope all is well talk to you soon.!
[Re: 1968RR]
#731428
06/24/10 08:32 PM
06/24/10 08:32 PM
67coronetman
Maryville tn
Tell me more about your set up if you don't mind.?
[Re: 67coronetman]
#731429
06/25/10 12:57 PM
06/25/10 12:57 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
I don't know about what you got when you bought the car, and I don't want to get involved. I do know that car ran 11.70 with a .509 cammed 440 with factory heads on it. That car got swapped around to quite a few different owners in the area ( I wasn't one of them.).
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
[Re: 11secaarcuda]
#731430
06/25/10 05:13 PM
06/25/10 05:13 PM
67coronetman
Maryville tn
Well from what i have been told is i am the 4th or 5th owner of this car.! and that is from the guy who got it from the original owner.!
[Re: 11secaarcuda]
#731431
06/25/10 05:26 PM
06/25/10 05:26 PM
67coronetman
Maryville tn
Would you be willing to chat with me on the phone.???
[Re: 67coronetman]
#731432
06/25/10 08:50 PM
06/25/10 08:50 PM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
Hey Mark ![](/ubbthreads/images/graemlins/wave.gif) My old engine had 452's,big valves,some good bowl work and opened up the intake ports a bit.I used the Comp XE295HL and it drove good and raced good. I had a 509 in it before that with the 452's and just a bowl port with the MP templates and it ran low twelves with a 3.54 gear and a Hemi 4-speed ![](/ubbthreads/images/graemlins/Twocents.gif) Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#731433
06/25/10 10:47 PM
06/25/10 10:47 PM
67coronetman
Maryville tn
Nice car i love those its old school very cool.!
[Re: fourgearsavoy]
#731434
06/26/10 02:34 PM
06/26/10 02:34 PM
67coronetman
Maryville tn
I know some don't like old mopar cams & i am ok with that * but they still work good and have been around for a long time and still make real good power hope all you have a great day and make the choices that you want listen to what other say but make the right one for your car as you see fit for your application.!
[Re: 67coronetman]
#731436
06/27/10 10:26 AM
06/27/10 10:26 AM
Posts: 957 Heart of Ohio
4boxers4
Heart of Ohio
It is disappointing to see so many members not answer your question but instead choose to somewhat negative in their advice. It's up to you to have what you want, whether it makes sense to others or not. That being said... The 509 is a good cam. You need to match it well with other parts(you have good heads) so I don't see a problem with 11's and streetable. Hydraulic cams are my preference for dual purpose and I have never had a problem in 25 years of tuning. Good luck.. ![](/ubbthreads/images/graemlins/beer.gif)
Persistance is omnipotent
Durability Engineer, Chair and Couch division...
[Re: 11secaarcuda]
#731438
06/27/10 11:37 AM
06/27/10 11:37 AM
67coronetman
Maryville tn
Oh i just want to chat not throw off on anyone.!
[Re: 4boxers4]
#731439
06/27/10 12:31 PM
06/27/10 12:31 PM
67coronetman
Maryville tn
Thanks i know other have there own ideas and its ok if they don't like old mopar cams but i do and will use them when i see fit.! i like the 509 alot.! ** if anyone out there has a mopar 292/509 cam & lifter combo new still in the box if you want to sell it let me know.!
[Re: 67coronetman]
#731440
06/27/10 12:44 PM
06/27/10 12:44 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Thanks i know other have there own ideas and its ok if they don't like old mopar cams but i do and will use them when i see fit.! i like the 509 alot.! ![](/ubbthreads/images/graemlins/iagree.gif)
They were ahead of their time work darn well especially if people take 5 minutes to degree them! The stacking effect of crank key, bottom gear keyway, top gear dowel hole and dowel pin placement can have cams off by 8 to 10 deg usually 3 to 4 but not in the good way! Proper degree for combo helps too. With that big motor you should look at the 320 .533 mopar Hydaulic cam ran one for years street strip and loved it! ![](/ubbthreads/images/graemlins/thumbs.gif)
