Page 3 of 4 1 2 3 4
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: 67coronetman] #731403
06/23/10 03:06 PM
06/23/10 03:06 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
No big deal just one of those things we are supposed to be aware off. I two finger type and hate when I hit cap locks by mistake and have to go back and type it all again! LOL!!!
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: Dodgem] #731404
06/23/10 03:31 PM
06/23/10 03:31 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Cool car, btw.
The old Mopar solids 528-557-590 are noisy because the spec is .032 lash.
Modern solid lobe profiles run much tighter lash.
For example, the Ultradyne/Bullet solid flat tappet cams run .016 lash.
Similar tight lash settings for Comp FL, SQ, MH, MF, and MM.
- Big difference in valvetrain clatter at .016 compared to .032+.
As far as reliability goes...you are just as likely to rip the lobes off of the cam with a hydraulic lifter as a solid if you don't have any zinc in your oil.
No matter what design you go with, I would have a custom cam ground up for your application.
Call Hughes engines, or Tim at Ultradyne/Bullet, or Dwayne Porter at Porter Racing heads, or Brian at IMM engines.
This is the short list, there are many other very good builders on this board who could guide you, also.
You will likely get more answers on this topic over on the race section, as there will be more engine builders lurking.
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: GregCon] #731405
06/23/10 05:54 PM
06/23/10 05:54 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Every solid I've ever used in a BB Mopar went like this: install it with a cold setting on lash. Drive it around a few hundred miles. Reset the lash one time. It never moves again. You can recheck it all you want. It never moves again. No big deal.
If something suddenly moves very much, that usually means you broke it and it's time to take it apart for a look.
If the noise is a huge problem why not tighten up the lash a bit?
Rich H.
Esse Quam Videri
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: ZIPPY] #731406
06/23/10 10:12 PM
06/23/10 10:12 PM
Maryville tn
67coronetman Offline OP
Maryville tn
Ok thanks for the info.!
Old car are me......
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: 67coronetman] #731407
06/23/10 10:16 PM
06/23/10 10:16 PM
Maryville tn
Maryville tn
With all the replies what i would love to see is for ( 5 ) people that have built a good combo with hdy cam & lifters with either eedy heads or 906 heads or any factory heads that had port work done or if you used indy sr heads in your build to share with me what you like about it and what all you did.!!
Thanks So Much.!!!!!!!!!!!
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: 67coronetman] #731408
06/23/10 11:05 PM
06/23/10 11:05 PM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
I have a 440, with KB pistons,eddy heads, eddy street dominator manifold, 2 7/8" headers, a good old 509 cam. Engine builder told me it was right about 10.4 to 1 CR. The car will usually run right about 12.00 -- I need better tires as they will not hook up, these are nitto drag radials about 7 years old now, lol. Kevin
71 gtx.....
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: 67coronetman] #731409
06/23/10 11:40 PM
06/23/10 11:40 PM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
Ok here we go.!!!! i have a very clean and sweet street car with a 580 hp 600 ft tq motor.!!! (( but i hate solid lift cams. i have read alot and even talked to the prevous owner of the car & i now have and the motor combo he had and i do believe i am going back to a hdy cam set up. he was running it ran a consistance mid 11 sec runs and was very street friendly. Here's what i have a full body & interior 66 plymouth satellite trans is good to go all new with a new stall 3200-3600 and 391 gears. (( So what say all my mopar brothers out there tell me of your combo's ) Oh yes i have indy sr heads so air & fuel flow will be no problem.!
** i would be interested in hdy cam & lifter parts if you have some for trade.?? our i may buy if resonable.??
Did you buy that car in Pennsylvania?
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: 11secaarcuda] #731410
06/24/10 07:17 AM
06/24/10 07:17 AM
Maryville tn
Maryville tn
Why would you ask that.?
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: sleddinfool] #731411
06/24/10 07:19 AM
06/24/10 07:19 AM
Maryville tn
Maryville tn
Hey thanks nice looking car.!
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: sleddinfool] #731412
06/24/10 08:18 AM
06/24/10 08:18 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Those are very large headers!!!
One of a kind?
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: fox] #731413
06/24/10 08:22 AM
06/24/10 08:22 AM
Maryville tn
Maryville tn
I am sure he meant 1 7/8
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: 11secaarcuda] #731414
06/24/10 09:22 AM
06/24/10 09:22 AM
Maryville tn
Maryville tn
** What i should have said was i got taken in washington Pennsylvania.** This car is now a real running street car after i spent more money to fix a mess that was never put together right in the first place.! So to answer you yes i got it up there.!
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: 67coronetman] #731415
06/24/10 09:47 AM
06/24/10 09:47 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
welcome to my world. this car was WAAAAAY over hyped by the owner/restorer. His body work was amature at best and he sorted me on more parts than I can list. Bottom lone for me, next time up have somebody go look at it if I can't. I have spent over 2 years getting parts and fixing some of his mess...but that's another post.
Coming soon!!!!
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: Mr.Yuck] #731416
06/24/10 09:51 AM
06/24/10 09:51 AM
Maryville tn
Maryville tn
Yes Sir i know how you feel its to bad that others out there can't be honest about what the have or don't have.??
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: 67coronetman] #731417
06/24/10 10:01 AM
06/24/10 10:01 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
he must have been a Chevy guy, because no Mopar guy would do what he did to another. If he wasn't 3000+ miles away I would have dropped the car at his garage and shoved the keys right up his hind side.
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: Mr.Yuck] #731418
06/24/10 10:19 AM
06/24/10 10:19 AM
Maryville tn
Maryville tn
No i am all mopar never ever liked chevy's at all i bleed mopar all the way.! And yes if he was closer i would have put the keys where the sun don't shine.!! Its ok he will get his one day it will come back around.! (( No from what i gather he final did this enough that he got what he wanted and made alot of people mad i know of at least ( 3 ) i have talked to in the last two years.!
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: 67coronetman] #731419
06/24/10 12:00 PM
06/24/10 12:00 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
Is he a member on here??? To close to home for me not to be aware of him. (Pm Me Who to watch out for).
Joe Sr
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: joewhite440] #731420
06/24/10 12:30 PM
06/24/10 12:30 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I thought that car looked familiar.
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: Jeff_383] #731421
06/24/10 12:35 PM
06/24/10 12:35 PM
Maryville tn
Maryville tn
Why do you know this guy that i am talking about.?
Re: 440 with a 292/509 cam good street combo what u say.!! [Re: joewhite440] #731422
06/24/10 12:37 PM
06/24/10 12:37 PM
Maryville tn
Maryville tn
He was at one time not sure now.! i think he has changed his user name so other don't know who he is he has friends that are on here and let him know when other are talking about him.!
Look i am not trying to be a ass but when a man tells me something i take him at his word (( A REAL MAN WOULD NEVER SET OUT TO TAKE ADVANTAGE OF OTHER TO GET WHAT HE WANTS I WAS HONEST IN ALL I SAID AND STILL HAVE ALL MY PAPER WORK AND TOTAL SPENT ON THE CAR,MOTOR TRANS ,STALL AND SO ON THAT I TRADED FOR THIS CAR AND I WILL SAY I CAME OUT ON THE SHORT END OF THIS DEAL REAL BAD.!!!
Page 3 of 4 1 2 3 4
