'40 Dodge Pickup Fuel System #730960
06/21/10 11:33 PM
06/21/10 11:33 PM
NE Iowa
Road_RunnerSteve Offline OP
NE Iowa
We're trying to get the '40 pickup running. Is there a sock type filter on the end of the fuel pickup on one of these? It has spark issues, too, but we are addressing those separately.
Thanks!
Re: '40 Dodge Pickup Fuel System [Re: Road_RunnerSteve] #730961
06/22/10 01:02 AM
06/22/10 01:02 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
Nylon would have been pretty rare back about then but there probably was some kind of filter somewhere.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: '40 Dodge Pickup Fuel System [Re: shinnery] #730962
06/22/10 07:33 AM
06/22/10 07:33 AM
NE Iowa
NE Iowa
Well we've cleaned the sediment bowl (acts as a fuel filter) but there are some signs of the pickup tube not letting fuel flow to the carb. I guess we're just wondering what the system is like before we tear it apart.
Thanks.
Re: '40 Dodge Pickup Fuel System [Re: Road_RunnerSteve] #730963
06/22/10 09:35 PM
06/22/10 09:35 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If its anything like cars, I suspect the end of the pickup tube is bare, its just cut off tubing. Most older stuff I've seen has a bunch of fine dust/dirt that sets in the bottom of the tank and any low places in the lines. The stuff has a very hard crust but is very fine, almost like ground dirt, base that never seems to go away.
I would give serious thought to replacing the tank and the line from the tank to the carb. Other wise expect to be cleaning that sediment bowl very often. The sediment bowl is more effective that modern fuel filters with this stuff, modern filters allow a lot of it to pass through and then it plugs up the passages in the carb. Gene
