Re: Fuel pressure drops down track with elec. pump.......
[Re: Crizila]
#730725
06/24/10 09:11 PM
06/24/10 09:11 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Replace the Fram filter with a Wix.
But really... why is 3 psi a problem? It is when it gets to 0 psi that your motor is consuming fuel faster than your pump can feed it. As long as it is above 0 you have fuel in your bowls. Is the engine missing at the top end?
Obviously, you wood like to see the pressure be the same throughout your 1/4 mile trip, but as long as the float bowls remain full, it won't make any difference if you have 4 lbs less in the lights. It does show that your existing system is "boarder line" though.
I think that it depends on the rest of the fuel delivery system. My car was way down on power at 3-3.5 psi. I looked at a bunch of other things because I too thought that 3 psi was fine. It was not.
