Re: Car Quit In The Parking Lot: HELP
[Re: YO7_A66]
#729452
06/20/10 04:54 PM
06/20/10 04:54 PM
Posts: 12,245 Looking for a way out of Middl...
IMGTX
The male terminal looks like this. ![](http://happyterminals.com/images/56%20male.gif) If you use a pair of needle nose pliers to squeeze it narrower and it will then slide out. and this is the female. ![](http://happyterminals.com/images/56%20female.gif) You will need to stick a small screwdriver/metal stick to depress the tab shown on the bottom of the picture. It will then slide out. they are available at Napa or at www.happyterminals.com Hope it helps. Now the reason that wire burnt may very well be from too much current flow to the coil/ignition system. You don't get more power out without more power in. You may want to use a relay to power the ignition system.
[Re: IMGTX]
#729453
06/20/10 06:23 PM
06/20/10 06:23 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
Capacitive discharge ignition systems don't require a ballast resistor. (They may talking about running with their CD ignition box).
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#729454
06/20/10 08:17 PM
06/20/10 08:17 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I replaced the blue wire that was burned and I made some voltage checks: Key @ RUN: Bat: 12.8v Coil +: 11.9v ECU: both terminals 12.0v Dist Connector: 1.85v Cranking: No visial spark from coil wire NO START. It did not even try to fire. I pulled my dist cap and all of the tips looked clean. I am plannin on putting on my old Orange MP ECU and try to restart, but not until tomorrow night. Any other suggestions are appreciated. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#729455
06/20/10 09:57 PM
06/20/10 09:57 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
MP distributors use stock pickups. That's behaving like one marginal and then dying. If you have a factory service manual I believe this can be tested.
[Re: jcastle1]
#729457
06/21/10 06:25 AM
06/21/10 06:25 AM
YO7_A66
Indiana
I am using the FBO distributor/ECU with the Mallory e-coil. ""MP distributors use stock pickups."" When I tested the distributor connector when the key was at the RUN position, I only got 1.85v. What voltage should I be getting at the dist pickup at the RUN position? Is it 12v or is it resisted down? I have the appropriate voltage to all of the key components as shown above except at the distributor connector. I believe the problem is either the coil or the ECU. I still have no spark from the coil wire to the top of the distributor.
I swapped out to the MP electronic ignition kit many years ago so my ignition harness is not a 70 unit. Does anyone have a diagram that shows what the blue wire (burned one in my picture) goes to on the MP ignition harness? My 70 manual shows it going to the dash lights and the key-in buzzer. Thanks
[Re: YO7_A66]
#729458
06/21/10 09:38 AM
06/21/10 09:38 AM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
Do you have another ECU you can try? I have had a few go bad and they quit working pretty quickly. The first one I had go bad the car started to act up like it was missing a little when I was driving it. I got it home and shut it off. I tried to start the car and had a hard time getting it to start and when I did it would not idle on it own and sounded like it was really out of tune. After two times of starting and dieing the car would not start anymore. I swapped out the ECU and the car fired right up without any more problems. The second one I had go bad was like a light switch. I had driven the car for a couple of years with the ECU box and after a drive one day I parked the car. A couple of days later I go out to the garage to start the car and it would not fire up. After some trouble shooting I figured out it was the ECU box. With the new ECU the car fired right up. So given my past experiences I would try the ECU first. If that does not fix it then it sounds like it is the coil. ![](/ubbthreads/images/graemlins/Twocents.gif)
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: loco340cuda]
#729459
06/21/10 09:51 AM
06/21/10 09:51 AM
YO7_A66
Indiana
Loco, Both of those issues sounds just like what happened over the weekend. I do have a spare MP Orange ECU that I will test tonight after I do a resistance check on the pickup coil. Thank you.
Can anyone confirm what the voltage at the pickup coil should be at the RUN position? Is it 12v or is it resisted down?
Thanks to everyone.
[Re: YO7_A66]
#729460
06/21/10 12:12 PM
06/21/10 12:12 PM
moper
Columbia, CT
The test I'm remembering (and it's been a very long time) is for resistance through the pickup. Not voltage.
[Re: moper]
#729461
06/21/10 12:26 PM
06/21/10 12:26 PM
YO7_A66
Indiana
David, I found a spec of 150-900ohms thru the pickup coil (which I am going to check tonight), but I was wondering what the voltage would be coming to the pickup coil with the key at RUN just so I can confirm that too. I guess I will know if it starts up that it had enough voltage. ![](/ubbthreads/images/graemlins/smile.gif) I have 12v going thru two of the pins at the ECU harness but only 1.85v is coming from the ECU (I think that is the source) and getting to the pickup. Thanks for the reply,
[Re: YO7_A66]
#729462
06/21/10 01:26 PM
06/21/10 01:26 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I don't believe you will not find a spec for voltage going to the pickup coil as the ECU measures a/c voltage generated from the pulses from magnetic distributor pickup.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#729463
06/21/10 01:37 PM
06/21/10 01:37 PM
YO7_A66
Indiana
Allen, Thank you for the clarification. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: YO7_A66]
#729464
06/21/10 01:46 PM
06/21/10 01:46 PM
70Fish
Actually, I might be having some similar issues with my ECU. How do I test that thing out to make sure it's working? Thanks
'70 Barracuda
'94 Harley Davidson FXDWG
Pit Bull named IKE
[Re: YO7_A66]
#729465
06/21/10 01:59 PM
06/21/10 01:59 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Here is a diagram that may help you out. Of course you do not have a resistor so it would be just a wire across there.
Allen
#729466
06/21/10 02:34 PM
06/21/10 02:34 PM
YO7_A66
Indiana
Allen, Thank you very much for the schematic. The burnt wire in the above pictures appears to be the dark blue wire (tracer) #23. I bypassed the bulkhead and wired the two #23's together for the short term as both sides of the bulkhead terminals were damaged. In my above pictures, there is a green wire right beside the burnt blue one. The schematic that you posted does not show a green wire in the #24 position. Does this just mean that my harness may be a little older/newer than your schematic? I need to trace it just to see where it goes. Thanks again,
[Re: YO7_A66]
#729468
06/21/10 06:12 PM
06/21/10 06:12 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Engine side goes to horns, pass side goes to horn relay, sometimes all that extra wiring gets people confused so i just blank it out.
Allen
[Re: Mopar_Country]
#729469
06/21/10 06:16 PM
06/21/10 06:16 PM
YO7_A66
Indiana
MC: Yes and thank you.
UPDATE: I checked the resistance at the coil pickup and it read 282ohms which is in the range that I found of 150-900ohms. Then I replaced the ECU with my spare and no change, no spark from the coil wire. Then I took both ECU's to my local parts store and they tested each one 6 times and they were both tested as good parts. Is my coil fried? I checked the resistance across the pos/neg terminals and it read .4ohms. ??? Thanks again,
