Re: More Engine Problems
[Re: bordin34]
#72938
06/14/08 11:40 AM
06/14/08 11:40 AM
Posts: 5,170 CT
GTX MATT
CT
Who cares if it is a big-block, it is also the most produced classic Charger EVER. Do you also feel you are better than me because you are not "beating your charger to death." People like you make young guys like me shy away from mopars. Usually older people embrace the young guys and try to teach them, you simply are not one of those good guys in this hobby. People like you make me and many others stay away from moparts, which is a valuable resource. Do you get your jollies off by insulting people and calling them stupid. You were young at one point if some [Edited by Moparts - Keep it clean] told you that you are wrecking your car what would you do? Like I said it is just a car. I hope that one day you will realize this. BTW great looking Superbee!
Some of these older guys think that they are the word of God in human form and that they could do no wrong. Take no offense. You are 100 % correct, many of these older guys look for something to blame on you because of your age. I see it all of the time. I get questioned all of the time about stupid crap because people assume that me being a young kid I dont know what im doing. I love the people that tell me that my car doesnt have a 273 in it because the smallest engine they made was a 318. Yeah sure. They forget that some of them were very capable of working on a car when they were a teen ager. I have friends that dont know enough about their own car to tune it correctly. Instead of telling them to sell it because they will never be able to do it I show them how. I think youre too far away from me but Id love to come take a look at your car. It has the electonic ignition, correct?
Sounds like an improperly timed engine, fouled plugs, a crossed wire, or maybe a combo of those three as well as possibly a poorly tuned carb. If you ignore these Mopar Police who are trying to make you go buy a Chevy (so that they could then complain about the Chevy tools with all of their chrome) you will get the correct information.
DO you have a good manual (like a Chiltons) to help you trouble shoot? Most trouble shooting stuff will be the same on alot of cars, but a manual is always nice for suggestions.
[Re: GTX MATT]
#72939
06/14/08 01:51 PM
06/14/08 01:51 PM
Posts: 842 Urbana, MD
bordin34
Urbana, MD
The brake bleeder was stripped by some previous owner. I would hate to buy all calipers and MC because I couldn't get a bleeder out. The engine has NGK XR5 plugs in it with accel wires with less than 100 miles on them, but I did buy suppression core, I don't know why. I have a Haynes manual and a book titled "Automotive Mechanics: Seventh Edition" circa 1975. From looking at the rockers before I didn't notice the push rods not in the cup. I have no cam specs all the last owner said was it had a "mild cam." Edit-Also I don't think it was a valvetrain problem. When I thought I had a bad ballast I bypassed it with my old coil and the car ran like a champ. Then the rotor fried. It could be a combo of weak ignition and a bad tune.
[Re: bordin34]
#72940
06/14/08 02:26 PM
06/14/08 02:26 PM
Posts: 5,170 CT
GTX MATT
CT
Bypassing the resistor? That will burn your coil out. The first things Id invest in would be a new balast resistor and a coil.
[Re: bordin34]
#72942
06/14/08 04:07 PM
06/14/08 04:07 PM
Posts: 5,170 CT
GTX MATT
CT
Are the new coil and ballast resistor brand new from a parts store/catalog/internet vendor?
[Re: bordin34]
#72945
06/14/08 06:02 PM
06/14/08 06:02 PM
hmmmmm. not to sound crasp, but everytime somebody asks you the same question.. we get a different answer. perhaps after you try something, write it down, that way you can keep track of what your doing and stop chasing your own tail. you NEED to get yourself ORGANIZED.
#72946
06/14/08 08:39 PM
06/14/08 08:39 PM
bordin34
Urbana, MD
On Monday I will solder the leads back onto my voltmeter. Here is a list of this I have done stuff to. ECU -Put a known working one in, still ran the same -Made another ground with 2 12awg wires to the firewall Cap and Rotor -Replaced, still ran the same -I did not feel and excessive play Ballast -Put a known good one in, MSD 0.8ohm ran worse -Put old Standard one in ran the same -Bypassed, before screwing with timing, car ran great MSD Coil -Tried 4 different ballasts, backfired with all -Ran worst with MSD ballast -After checking all the ballasts I bypassed them OEM 30 year old coil -Car no longer backfired, made less power than usual -One day the car randomly would not rev above 2000rpm, so I fooled with the timing Plug Wires -Has Accel 8mm suppression core wires with less than 100 miles on them Plugs -Has NGK XR5 plugs with less than 100 miles -Replaced champions -Gapped at .35 Valvetrain -Visual inspection and pushing with hand showed nothing. -Some side to side play Ignition Timing -Really screwed up Carb -Float levels are correct -69 primaries -Stock secondaries -Holley 670cfm street avenger Distributor -30 year old stock unit
[Re: bordin34]
#72949
06/15/08 11:38 AM
06/15/08 11:38 AM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
Looks like an ignition problem to me. If it ran great with full power to the coil than I would say that rules out all other problems right????? Concentrate on why full power is not getting to the coil using the regular wiring and take it from there. TBF
[Re: bordin34]
#72952
06/16/08 07:38 AM
06/16/08 07:38 AM
Posts: 27,728 places
79powerwagon
places
Today I hooked up my timing light and with the help of my uncle we got it in the correct area. It was way too far advanced. He thinks that a valve may be hanging up or burnt and there is a misfire as well as running rich. Tomorrow I will beck out the ignition system and look at the color of the spark.
Now yer talkin'! ![](/ubbthreads/images/graemlins/thumbs.gif)
Did you ever hook up the vacuum gauge and tell us what it read? If you do, in fact, have a burnt valve, it would show up on the vacuum gauge immediately.
[Re: 79powerwagon]
#72953
06/16/08 01:48 PM
06/16/08 01:48 PM
bordin34
Urbana, MD
Here is a video of the vacuum reading from when these series of problems first started in April. I no longer have the vacuum gauge as I borrowed it from my teacher and this is the last week of school. For the voltmeter it looks as if I need a pencil tip for my soldering iron or a new voltmeter. http://s80.photobucket.com/albums/j172/Charger34/?action=view¤t=PICT5756.flvEdit-I just checked my spark and directly from the coil the spark is a nice bright purple and I can move the wire about 1cm to 3/8" from the ground and it still sparks. Now I am going to check the spark from the distributor to plugs.
