440 source stealth heads #727998
06/19/10 09:48 AM
06/19/10 09:48 AM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Just how good ,or bad are the stealth heads OTB ??Ok to use a 530 lift roller cam with dished pistons ??
Re: 440 source stealth heads [Re: dynamite] #727999
06/19/10 10:01 AM
06/19/10 10:01 AM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
If you plan on using any larger than 5/16 pushrods, you will need to grind the heads for pushrod clearance. I would step up the springs in the heads if your going to run a roller cam. Maybe you can buy the heads bare and purchase all your valvetrain seperately through Manley. Since the heads are so inexpensive, I would purchase the CNC ported versions from 440 Source. I have been told that 440source uses Jeff at Modern cylinder heads in Michigan to port the heads, This is WELL worth it with these particular heads. I installed a set on a customers engine and they ended up working out OK once I had the valve job and guide work and pushrod clearancing taken care of. Next guy that wants the 440 Source heads on an engine that I build will get the Porting treatment. Another thing that I noticed was the valve seats protruded into the combustion chamber, we ended up facing the seat and re-doing the valve job.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: 440 source stealth heads [Re: PUNK] #728000
06/19/10 10:40 AM
06/19/10 10:40 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mine were the first ones made.I changed springs retainers and locks as I run a .588 solid cam and 4 speed.My shop also cleaned them up and back cut the valves.Third year on street and strip and no problems.I ran the FelPro Marine gaskets with mine.I run 3/8 pusheods and they just narely cleared but its best to check them.Rocky
Chrysler Firepower
