Re: 70 AAR underneath restoration what to do?? [Re: A0M397X] #72639
06/15/08 10:07 AM
06/15/08 10:07 AM
Pennsylvania
A0M397X Offline
A0M397X  Offline
Pennsylvania
Finally, off topic but I assume these markings mean something
No TV Party Tonight
Re: 70 AAR underneath restoration what to do?? [Re: A0M397X] #72640
06/15/08 10:43 AM
06/15/08 10:43 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Saved them thanks, any of the top side?
Careful, your character's showing!
Re: 70 AAR underneath restoration what to do?? [Re: mopar346] #72641
06/16/08 04:25 AM
06/16/08 04:25 AM
DFW
68RRFlyer Offline
68RRFlyer  Offline
DFW
So what would you guys do to "restore" the old primer color on the underside? Would you tint something and add a flatening agent or just use an epoxy primer? I want something that would be easy to clean if I happen to run through a mud puddle or something else! My car is all new everything underneath so I'm starting on a clean slate. The more I'm reading this post, the more I want to bring the car back to stock and not have the entire undercarriage painted body color.
Cheers
Re: 70 AAR underneath restoration what to do?? [Re: 68RRFlyer] #72642
06/16/08 06:36 AM
06/16/08 06:36 AM
michigan
70 buzz Offline
70 buzz  Offline
michigan
Does it supposed to be prmer over body color or body color over primer? Looks like primer over body color
Re: 70 AAR underneath restoration what to do?? [Re: 70 buzz] #72643
06/16/08 10:54 AM
06/16/08 10:54 AM
mopar346 Offline
mopar346  Offline
Car is dipped in primer and then the car is painted, the only paint on the bottom side is overspray on the high parts and ledges. There is a post with great info and pics on a 68 RR going on right now, it's basically the same process.
Re: 70 AAR underneath restoration what to do?? [Re: mopar346] #72644
06/19/08 11:35 PM
06/19/08 11:35 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Check out this past thread with lots of good pics:
https://board.moparts.org/ubbthreads/show...ID=#Post4363151
Re: 70 AAR underneath restoration what to do?? [Re: autoxcuda] #72645
06/20/08 07:34 AM
06/20/08 07:34 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Maybe these will help someone, these are my cars.
Before pressure washing:
After:
Re: 70 AAR underneath restoration what to do?? [Re: Challenger 1] #72646
06/20/08 08:45 AM
06/20/08 08:45 AM
Pennsylvania
A0M397X Offline
A0M397X  Offline
Pennsylvania
Great info boys. One thought mentioned here and on the other thread about black being painted under the mufflers.... Black would absorb heat from the mufflers making the floor hot. White would be a better choice if that was the idea.
No TV Party Tonight
