Challenger dash wiring questions. #726338
06/16/10 10:21 PM
06/16/10 10:21 PM
KS
MoparKansas Offline OP
KS
I was putting my rallye dash harness in last night and ran into a few problems. Most were on the accessory lighting harness and the AC harness which seem to be almost separate harnesses from the main harness. I am planning to attach a few pics to my questions, so please be patient. First question on the AC/heat control there are two wires a tan or lt green and a blue(I am color blind so I can't tell the exact color of the lighter wire)and an upper and lower terminal. Which wire goes to which terminal?
Re: Challenger dash wiring questions. [Re: MoparKansas] #726339
06/16/10 10:23 PM
06/16/10 10:23 PM
KS
KS
Question 2 What wire powers the clock? There is a red spade terminal with two wires and a black one that doesn't seem like it would reach the clock.
Re: Challenger dash wiring questions. [Re: MoparKansas] #726340
06/16/10 10:28 PM
06/16/10 10:28 PM
KS
KS
I am really confused about where all these lighting wires go. My car never had the light shown that goes below the dash where is it mounted? Also there is a long orange (3-4 ft?)wire with a a spade terminal where does it go? It is shown in this pic next to the light and another two hole female terminal - what goes in this?
Re: Challenger dash wiring questions. [Re: MoparKansas] #726341
06/16/10 10:36 PM
06/16/10 10:36 PM
KS
KS
Is this a lighting delay - silver thing? Where does this yellow striped wire plug into? Where is the silver thing supposed to mount? What plugs into the extra spade terminal in that terminal shown in the middle of the picture?
Re: Challenger dash wiring questions. [Re: MoparKansas] #726342
06/17/10 01:45 AM
06/17/10 01:45 AM
midwest
I
intragration Offline
I
midwest
The long orange may be to the floor shift selector light. Orange is for the accessory lighting, that comes on with parking lights. If not that, then cluster lights or ashtray light.
The clock on a rallye dash should be the dual red wire connector. The black would probably be for the non-rallye dash clock.
Green and blue on heater head should be interchangeable. Blue goes out to the compressor, and light green feeds the switch from the fuse block. If one of the terminals is marked "CL", put blue there just to be safe.
Re: Challenger dash wiring questions. [Re: intragration] #726343
06/17/10 01:56 AM
06/17/10 01:56 AM
midwest
I
I
midwest
Looks like you may be right about the silver device being a lighting delay. Yellow with black tracer may go to a map light. Not sure about the other connector, possibly the ignition switch light or the light above the left pod switches? Maybe there's something else local that fits the plug? At least you can use that to look it up and figure out what it is.
Re: Challenger dash wiring questions. [Re: MoparKansas] #726344
06/17/10 01:32 PM
06/17/10 01:32 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
that black light bulb holder thing i think should mount to the ac only long trim piece that reaches from steering column to glove box,sort of.im missing this piece on my car so thats all i can come up with.
Re: Challenger dash wiring questions. [Re: cuda-sweden] #726345
06/18/10 08:27 PM
06/18/10 08:27 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
You are right. It is the map light/courtesy light that goes in the lower trim piece. It is part of the deluxe light package.
Craig
Re: Challenger dash wiring questions. [Re: MoparKansas] #726346
06/18/10 08:29 PM
06/18/10 08:29 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
There is a pair of 16 gauge red wires that junction at the connector that goes to the clock.
Craig
Re: Challenger dash wiring questions. [Re: MoparKansas] #726347
06/18/10 08:37 PM
06/18/10 08:37 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The silver thing does not mount, it is kind of wedged into the harness. Mine had some black goop on it so it may have been taped in, I just can't tell you for sure.
The yellow wire with the trace goes to two places: the lamp ground connector and to the map light switch supplying it with a ground.
Craig
Re: Challenger dash wiring questions. [Re: denfireguy] #726348
06/19/10 06:47 AM
06/19/10 06:47 AM
KS
KS
OK - I am getting this slowly figured out. With the red wire going to the clock I looked closely at my old harness and the voltage limiter for the gauge cluster is where the black wire went. I looked at my AC trim panel and found where the light mounts and that there is a map light switch that I am missing which will account for one more socket of the lighting harness. As mentioned above the long orange wire with a socket would have gone to the console - which I am not going to use so I will need to unhook it. I have a few more wires that I am trying to find homes for. I'll have to take a few more pictures later to show what else I think I have figured out and what else I need to do. Thanks for all of the help!
Re: Challenger dash wiring questions. [Re: MoparKansas] #726349
06/19/10 02:30 PM
06/19/10 02:30 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
yes yes yes,let the pics keep coming,this is good info.
Re: Challenger dash wiring questions. [Re: MoparKansas] #726350
06/21/10 06:31 AM
06/21/10 06:31 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
What year is your Challenger?
Re: Challenger dash wiring questions. [Re: Snoopy] #726351
06/21/10 11:08 AM
06/21/10 11:08 AM
KS
KS
My Challenger is a 73. I will take a few more pics tomorrow. My daughters birthday is today and I won't have time to mess with it tonight. I think I am getting down to just a few things that need to be hooked up yet and verification on some things that I think go together.
Re: Challenger dash wiring questions. [Re: MoparKansas] #726352
06/28/10 11:18 AM
06/28/10 11:18 AM
KS
KS
Got a little more figured out over the weekend. I found I had the wrong glove box light in the car as it didn't have the long wire going to it - just a stub and a bullet terminmal. I found the correct one in a box with my Satellite parts, and it had a splitter terminal which I think goes to the back of the clock too so it has power all of the time. So now I have a glove box light that should work. I took some more pictures and will post later.
Re: Challenger dash wiring questions. [Re: MoparKansas] #726353
06/29/10 08:45 PM
06/29/10 08:45 PM
KS
KS
OK - the wires on the end of the harness towards the glove box are my main concern now. Here is a pic. What is the connector with all the blue wires and the long orange connector with the female spade terminal supposed to hook to?
Re: Challenger dash wiring questions. [Re: MoparKansas] #726354
06/29/10 08:51 PM
06/29/10 08:51 PM
KS
KS
Are these the wires that go to the brake light switch? What hooks to the 3 place female bullet style connector? These are all next to the wires that go to the steering column...
Re: Challenger dash wiring questions. [Re: MoparKansas] #726355
06/29/10 08:57 PM
06/29/10 08:57 PM
KS
KS
Here is the bullet connector...
Re: Challenger dash wiring questions. [Re: MoparKansas] #726356
06/29/10 09:06 PM
06/29/10 09:06 PM
KS
KS
How long should the tach wire be that goes to the coil after the firewall grommet?
Re: Challenger dash wiring questions. [Re: MoparKansas] #726357
07/01/10 02:19 PM
07/01/10 02:19 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
i think this is for the seat belt relay
Greg
Re: Challenger dash wiring questions. [Re: MoparKansas] #726358
07/01/10 02:21 PM
07/01/10 02:21 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
the bullet connector was for accessories, i think my A/C harness connects to that
Re: Challenger dash wiring questions. [Re: MoparKansas] #726359
07/01/10 07:50 PM
07/01/10 07:50 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The long orange wire connects with the console shifter light on another long orange wire.
Craig
Re: Challenger dash wiring questions. [Re: MoparKansas] #726360
07/01/10 07:56 PM
07/01/10 07:56 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Not sure how long. It should go to a female bullet connector. It should be long enough to have the connection next to the black engine connector from the harness that plugs into the firewall connector. Sounds confusing but you should be able to unplug both fairly close to each other.
Craig
