Recommendations for a tranny cooler #725272
06/15/10 07:40 PM
06/15/10 07:40 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Thinking of getting a tranny cooler for the car, as temps can reach 220* with just a few romps on the throttle, no thanks to the 3,500 stall converter. Any recommendations on brand and or mounting location.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Post deleted by Defbob [Re: BloFish] #725273
06/15/10 08:19 PM
06/15/10 08:19 PM
Re: Recommendations for a tranny cooler #725274
06/15/10 08:20 PM
06/15/10 08:20 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
B&M super cooler
Mopar Performance
Re: Recommendations for a tranny cooler [Re: moparniac] #725275
06/15/10 08:39 PM
06/15/10 08:39 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
B&M super cooler
This is a good'un.
Any stacked plate design is preferable to the old single pass radiator looking coolers from what I am told.
I have no experience with the heat sink type that Fred is showing , but he has the voice of experience IMO , so I might give them a look too.
Post deleted by Defbob [Re: moparniac] #725276
06/15/10 09:22 PM
06/15/10 09:22 PM
Re: Recommendations for a tranny cooler #725277
06/15/10 09:24 PM
06/15/10 09:24 PM
Champlin Mn.
2
2DoorPost Offline
2DoorPost  Offline
Champlin Mn.
The bigger,the better...
Post deleted by Defbob #725278
06/15/10 10:10 PM
06/15/10 10:10 PM
Re: Recommendations for a tranny cooler #725279
06/15/10 10:19 PM
06/15/10 10:19 PM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
B&M super cooler
x2...
X3.
If it's put in a spot that doesn't get strong air circulation, mount an electric fan to it.
X4
I run two of them and double enter my car every weekend.
Why does divorce cost so much? Because it is worth it!!!!!
Re: Recommendations for a tranny cooler [Re: mopar376d] #725280
06/16/10 12:31 AM
06/16/10 12:31 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Any of the available stacked plate designs work very well. Sold by B&M, Earls and many others.
Re: Recommendations for a tranny cooler [Re: Al_Alguire] #725281
06/16/10 12:38 AM
06/16/10 12:38 AM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
The bigger ....the BESTer ? ..... might be the plan on a tow-rig or motorhome ..... but on a racer ? .....
...uNless you want to kill-some stall-speed.
Re: Recommendations for a tranny cooler [Re: dOc …] #725282
06/16/10 03:05 AM
06/16/10 03:05 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
another B&M supercooler here. mines mounted above the diff & has a fan. the fans great for blowing your burnout smoke away. burnouts look impressive with long trails of smoke wofting away behind you,
Re: Recommendations for a tranny cooler [Re: rebel] #725283
06/16/10 03:22 AM
06/16/10 03:22 AM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
B&M supercooler!
Re: Recommendations for a tranny cooler [Re: BloFish] #725284
06/16/10 12:36 PM
06/16/10 12:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Don`t see why a 3500 stall vert should matter.....I`m running a 5000 stall 8" on the street/strip and have been for years and it takes several passes/miles to get to 160 degrees. I run the flat plate type B&M cooler sold at Kragens, Pep Boys etc. and it is mounted behind my ft. lic plate where it gets lots of air. Good luck...
Re: Recommendations for a tranny cooler [Re: rebel] #725285
06/16/10 02:54 PM
06/16/10 02:54 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Any pics???
Re: Recommendations for a tranny cooler #725286
06/16/10 03:12 PM
06/16/10 03:12 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I used one like this but a double pass. both fitting are on one end from SUMITT
I like the look of those coolers. and that you could mount it on the inside of a framerail.
That way if you blow a line maybe it wont spray the rear tires?
Re: Recommendations for a tranny cooler [Re: Thumperdart] #725287
06/16/10 05:23 PM
06/16/10 05:23 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Perhaps it doesn't, I just wanted to give some info: that might explain the quick generation of heat. And when I say :a few romps on the throttle" it is more like after a couple of 1/4 mile passes
I appreciate all of the advice and suggestions
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Recommendations for a tranny cooler [Re: sshemi] #725288
06/17/10 01:32 AM
06/17/10 01:32 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Any pics???
yeah but you might need your night vision glasses to see it. everything is black under there.
Re: Recommendations for a tranny cooler [Re: rebel] #725289
06/17/10 01:51 AM
06/17/10 01:51 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW mine is mounted at the rear of the car as well. We did it more to get more weight back there than anything else.
Re: Recommendations for a tranny cooler [Re: Al_Alguire] #725290
06/17/10 03:18 AM
06/17/10 03:18 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
same here plus it keeps the engine bay from looking cluttered.
Re: Recommendations for a tranny cooler [Re: rebel] #725291
06/17/10 08:48 AM
06/17/10 08:48 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
here, B&M Supercooler. The biggest one. From Summit.
SRT DEMON ONE SEAT
