Page 13 of 19 1 2 11 12 13 14 15 18 19
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: thehemikid] #723738
03/12/13 08:33 AM
03/12/13 08:33 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
They did for me even though they had to order both wires.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: rapom] #723739
03/23/13 03:19 AM
03/23/13 03:19 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Well they swapped them out,....with a $6 & change to boot, which I expected.
Then I had to pop the lock mechanism to install the connectors with grommets.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: thehemikid] #723740
03/23/13 08:56 AM
03/23/13 08:56 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Mine didn't have the lock that yours does. I just ran my engine last week and I really like how the controller works the fan. I let the engine get to 190 to see how it would get the temp down. The fan speed doubled until it got the temp down to 160. I don't think I will have any overheating problems.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: rapom] #723741
03/23/13 05:24 PM
03/23/13 05:24 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Could you hear the fan over the engine at that doubled speed?
Headers?
Hood closed?
I really don't want to hear it over the engine, but I figure at times it will be inevitable.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: thehemikid] #723742
03/23/13 06:26 PM
03/23/13 06:26 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
It wasn't as bad as I thought it was going to be. I bet most people wouldn't notice it. I have a tti full 2.5" exhaust with dynomax ultra flows so my car isn't quiet either. I was in my garage so the exhaust sound was echoing off the walls so the fan may sound louder outside.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: rapom] #723743
02/24/14 02:08 PM
02/24/14 02:08 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
Feets,
I have read through all of this (mostly), could not see the pictures you posted from 2010. I would like to make this change, but need to know a few things first. I apologize in advance if I skipped over the answer in one of the previous posts
1) new vs old style. We want the new style? What vehicle application do I look for?
2)does the new style require a "controller"? Or can I just wire +, -, and a 12VDC for the trigger?
FYI - I am replacing a dual flexalite setup that one of the fans after 10 years decided to go south. I have a 165 amp GM alternator so no power issues there
Thanks again for all the info
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: Performance Only] #723744
02/24/14 08:09 PM
02/24/14 08:09 PM
Andrewh Online content
Andrewh  Online Content
top of the 3rd page, it shows the old style fan that needs to have the controler. you can see the fins of the heat sink poking out.
it appears any fan will work, however the thinest setup appears to come from c-class type cars.
feets has a few cars and years listed in one of the other posts.
it comes down to how much clearence you have, if you can get the fan in there.
without the controler and only applying 12 volts to the fan, be aware, it will come on full speed.
if you hook up a temp controler to turn it on and off, even here in texas, it only runs for a little while and turns off again.
if you have a/c you will have to rig another switch to make it come on, or a trinary.
but you will have the same problem where the fan cycles a lot.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: whiplash] #723745
02/25/14 10:05 AM
02/25/14 10:05 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
You are going to want the controller.
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
I installed a Mercedes fan in my 67 Coronet. I have a champion 3 core radiator and I had to clearance my water pump shaft and bolts to get it to fit.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: rapom] #723746
02/25/14 10:06 AM
02/25/14 10:06 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Another angle
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: rapom] #723747
02/25/14 10:08 AM
02/25/14 10:08 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here you can see how it fits on the radiator
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: rapom] #723748
02/25/14 10:09 AM
02/25/14 10:09 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Had to make some heavy duty brackets
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: rapom] #723749
02/25/14 02:42 PM
02/25/14 02:42 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Nice job.
How is it working out for you?
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723750
02/25/14 03:51 PM
02/25/14 03:51 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
It is working great. It's nice to hear it bump up when the engine is working hard and then automatically slow down. Most of the time I it just blows half speed or less. And I expect a lot out of it because I get pissed if I go above 180. I have a 160 degree thermostat and my avg temp is 170-175. I'm running a 493 with A/C that is driven mostly on the street so I wanted the best system I could afford. And this $200 radiator and $100 Mercedes fan fit the bill. Although the controller was an unexpected expense it was worth it.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: rapom] #723751
02/25/14 03:57 PM
02/25/14 03:57 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
Rapom,
I am loooking to do this on a 67 coronet 383. Can you tell me how much room you have from the backof the radiator to the bolts on the water pump? I have a little more than 3.5" and want to make sure this will fit before I buy anything.
Also,
I see a lot of 97-98 fan C230 fan assemblies out there, the don't have the controller and probably not the power but are they sufficient? What about the HHR fans? I think they are too wide (4+") for my application.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: whiplash] #723752
02/25/14 08:28 PM
02/25/14 08:28 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I got 3 5/8" between radiator and water pump pulley bolts. Bolts and pulley shaft are shaved.
3/16" clearance between fan and pulley bolts.
My radiator is a Champion 3 core.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: whiplash] #723753
02/26/14 08:10 PM
02/26/14 08:10 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
They are a different size. You will be on your own.
I used the 2001-2007 C-class fans due to the nice fit.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723754
02/26/14 11:15 PM
02/26/14 11:15 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i have one if anyone needs it.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723755
04/30/14 10:58 AM
04/30/14 10:58 AM
il
gtxboyz Offline
gtxboyz  Offline
il
hello Mr feets or anyone who can help me I got a fan from a c class 05-07 I installed it hooked it up and it works but goes high to low back high then low and back high and so on ,any ideas I am just trying to hook her up to a switch since I am racing my 67 belvedere gtx any ideas would be greatly appreciated thanks Frank
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: gtxboyz] #723756
04/30/14 12:54 PM
04/30/14 12:54 PM
pics of the fan, and how you wired it would help in figuring out what is going on.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: Andrewh] #723757
04/30/14 06:20 PM
04/30/14 06:20 PM
il
gtxboyz Offline
gtxboyz  Offline
il
I got the plug on the driver side facing down ward the big terminal closer to the radiator I made it positive the other big terminal I put as ground and the little one on top of the ground I made hott it turns on flows the right way but once it hits max speed it shuts down then goes back to max speed and back to low and so on. maybe I got a bad fan I used little test wires maybe it's too much juice for the wires I will try and get some pics lil later any ideas thanks Frank
