Re: Monster electric cooling fan upgrade. long. w/photos.
[Re: rapom]
#723741
03/23/13 05:24 PM
03/23/13 05:24 PM
Posts: 1,805 ky hills
thehemikid
ky hills
Could you hear the fan over the engine at that doubled speed? Headers? Hood closed? I really don't want to hear it over the engine, but I figure at times it will be inevitable. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: rapom]
#723743
02/24/14 02:08 PM
02/24/14 02:08 PM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
Feets,
I have read through all of this (mostly), could not see the pictures you posted from 2010. I would like to make this change, but need to know a few things first. I apologize in advance if I skipped over the answer in one of the previous posts
1) new vs old style. We want the new style? What vehicle application do I look for? 2)does the new style require a "controller"? Or can I just wire +, -, and a 12VDC for the trigger?
FYI - I am replacing a dual flexalite setup that one of the fans after 10 years decided to go south. I have a 165 amp GM alternator so no power issues there
Thanks again for all the info
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
[Re: Performance Only]
#723744
02/24/14 08:09 PM
02/24/14 08:09 PM
Andrewh
top of the 3rd page, it shows the old style fan that needs to have the controler. you can see the fins of the heat sink poking out.
it appears any fan will work, however the thinest setup appears to come from c-class type cars.
feets has a few cars and years listed in one of the other posts.
it comes down to how much clearence you have, if you can get the fan in there.
without the controler and only applying 12 volts to the fan, be aware, it will come on full speed. if you hook up a temp controler to turn it on and off, even here in texas, it only runs for a little while and turns off again.
if you have a/c you will have to rig another switch to make it come on, or a trinary. but you will have the same problem where the fan cycles a lot.
[Re: rapom]
#723746
02/25/14 10:06 AM
02/25/14 10:06 AM
Posts: 1,883 Northern OH
rapom
Northern OH
[Re: rapom]
#723749
02/25/14 02:42 PM
02/25/14 02:42 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Nice job.
How is it working out for you?
[Re: rapom]
#723751
02/25/14 03:57 PM
02/25/14 03:57 PM
whiplash
Summit, NJ
Rapom,
I am loooking to do this on a 67 coronet 383. Can you tell me how much room you have from the backof the radiator to the bolts on the water pump? I have a little more than 3.5" and want to make sure this will fit before I buy anything.
Also, I see a lot of 97-98 fan C230 fan assemblies out there, the don't have the controller and probably not the power but are they sufficient? What about the HHR fans? I think they are too wide (4+") for my application.
[Re: whiplash]
#723752
02/25/14 08:28 PM
02/25/14 08:28 PM
rapom
Northern OH
I got 3 5/8" between radiator and water pump pulley bolts. Bolts and pulley shaft are shaved.
3/16" clearance between fan and pulley bolts. My radiator is a Champion 3 core.
