Re: Monster electric cooling fan upgrade. long. w/photos.
[Re: Performance Only]
#723661
07/15/10 09:16 AM
07/15/10 09:16 AM
Posts: 28,124 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If you cross the main power and ground wires things get ugly. It will short with enough current to make the teeth on jumper cables glow orange. That happens within 10 seconds of connecting the two wires. Leave it like that and smoke will follow in a minute or so. No doubt it's hard on the capacitors inside the motor.
BTW... Temic and Brose make the fans for Mercedes. The motors I have were made for them by Siemens.
[Re: gtx69]
#723663
07/15/10 05:49 PM
07/15/10 05:49 PM
Posts: 2,091 Delray beach, Florida
Performance Only
here's what the instruction sheet said that came with the fan. this fan assembly is an electronic device which has to be installed according to a special test procedure, please follow the steps below. we will not accept responsibility for any damage. the fan assembly has to be mounted into the vehicle before testing, because the control unit requires a PWM signal, please do not use "power supply" test, otherwise the IC card will burn out. there's more, but it's just stuff not relevant to this discussion. basically it's telling me that the fan should not be used with normal system voltage. this is a replacement fan for a C class mercedes though. i tried to talk to one of the techs at the dealership about it but unless i'm willing to pay the 155.00 per hour they won't let me talk to anyone. this dealership is hard to deal with. i was hoping maybe Feets could ask one of the techs how much voltage the fan is supposed to see under normal circumstances. no point in burning up another fan if i can't find out. of course my other question is do i need to limit the voltage to the trigger wire, or the voltage to the main positive lead, or both??? any help would be greatly appreciated.
machine shop owner and engine builder
#723664
07/15/10 06:02 PM
07/15/10 06:02 PM
feets
Senior Management
Senior Management
Irving, TX
I wonder if that's some sort of initialization thing. I haven't had any issues with mine. Andy and Kirk haven't had any problems with theirs. All of ours came out of wrecked cars. I'll see if there are any techs working tonight. Most of them have gone home by now.
#723667
07/15/10 07:25 PM
07/15/10 07:25 PM
feets
Senior Management
Senior Management
Irving, TX
I found a shop foreman before I left work. This is what we've got... There are two types of fans on these cars. The older fan is on top. It was replaced by the new style shown on the bottom. The fans are indeed controlled by pulse width modulation. Essentially, the computer sends pulses to the controller kinda like a strobe light. If it flashes slow, the fan runs on low speed. If it flashes fast, the fan runs on high speed. The computer sends that signal to the little metal box on the fan. That box reads the signals and turns on the low speed or high speed on the fan. When that box fails, the fan won't work. The fan motor is seldom harmed when that happens. The smoke leaks out of the control box, not the motor. Four large wires come out of that box. You can bypass the box and wire straight to the leads. The fan will blow on the speed you've set. The new style fans have the speed control built into the motor. When they get a constant 12 volt signal they default to high speed. That is a fail-safe that prevents the engine from overheating. Apparently, the aftermarket fans are made cheaply and don't have the fail-safe logic built in. Should you have one that fails, bypass the metal box and wire directly. The fan will run just fine. Since the majority of fans I have played with were the new style, I had no idea there would be a problem. Apparently, all the smoke leaked out of your fan. You can contact the company and see if they will warranty the fan. Since they have that statement in the paperwork, they must know it's an issue. If they refuse to warranty the fan or if you simply don't want to mess with all that again, bypass the box and wire up the fan. I'm not sure which leads will provide which speed. I will play with my donor and see what I can find out.
[Re: j3wbagell]
#723669
07/15/10 07:42 PM
07/15/10 07:42 PM
feets
Senior Management
Senior Management
Irving, TX
Do you really want to pay over $500 for a fan? The factory fan isn't cheap. Aftermarket pieces will drop in and work like the original equipment. If they have the control box, I'd simply bypass it and wire to the leads on the other side of the box. If the aftermarket guys tooled up to build the old style fan, I doubt seriously they retooled to produce an entirely new part when theirs will work. You can try asking at a regular parts store for an aftermarket 2006 Mercedes C230 fan and see if it is the new style.
To answer your question directly, no. I do not have the number handy. I can get it at work tomorrow if you like.
[Re: feets]
#723670
07/15/10 08:05 PM
07/15/10 08:05 PM
Performance Only
i suppose wiring the fan directly would be possible, but it would take a 50 amp relay i suspect. so perhaps the ballast resistor on the trigger wire is the answer??? it seems like it would basically achieve the same thing, right. or am i missing something? the fan i have has that big metal box on it like the one you pictured.
#723673
07/15/10 09:42 PM
07/15/10 09:42 PM
feets
Senior Management
Senior Management
Irving, TX
OK, I got you into to this on a customer's car so I'll try to help you out.
IF you want to try to warranty your fan, it's up to you. Id's hate for you to pay to ship it cross country and end up having the warranty denied and be out the time, money, and the fan. I took a motor out of an old style fan I brought home today. This is what it looks like:
Three wires run into the windings. The fourth runs to what is obviously a tachometer to feed back info on fan speed.
Here's a close up shot of where the wires feed into the windings:
The leads go into three concentric rings. The innermost is in the shadow to the right. I was unable to disassemble the motor completely. The axle has a cap on it that will not come off in a non-destructive manner. If my rudimentary electrical knowledge is correct, the inner ring would be a common, the middle would be a low speed setting with half the windings, and the outer would be a high speed. A close look at the picture will show that I tried to poke a little power at the terminals to see what would happen. The fan spun up for a moment then started shuddering back and forth. I think the signal box may be to blame for the shudder. My multimeter is dead so I can't do any testing.
Go ahead and cut the wires. Bypass the box. Look at the 4 wires going into the motor and see which ones you need to use. Let us know how it works. If it doesn't work, you're definitely going to lose your warranty. In that case, I'll send you the new style fan shown in the picture above on my dime. It's in near-mint condition. A close examination will show that one of the mounting tabs has an itty bitty chip. That's why it was replaced. It's the same style fan Andrewh, and I use. I would send you this motor I pulled out but we don't know it it would fail the same as yours.
Maybe yours was a bad unit. Maybe running it like this smoked it. Since it's already dead, it would be the one to use. If you don't want to try this, say something. I can understand you not wanting to experiment with a client's car.
[Re: feets]
#723674
07/15/10 09:55 PM
07/15/10 09:55 PM
feets
Senior Management
Senior Management
Irving, TX
If bypassing the control box works, you'll want to use a relay. Bosch relay number 0 332 002 150 (Echlin AR298) is a 75 amp relay. Note the measurements are metric. You can run this in conjunction with a thermostatic switch to control the fan. If wiring the fan directly works like my shop foreman stated, you should be able to use high and low speeds. One switch for high, one for low.
#723676
07/15/10 10:16 PM
07/15/10 10:16 PM
feets
Senior Management
Senior Management
Irving, TX
One relay for each speed.
If your temp switch throws a ground to trigger a fan, it can be used to ground the relay and spin up the fan. You will have a harder hit on the electrical system than with the easy start the factory provided. It should still be under the limits of this relay. The spike would dissipate quickly. It would probably be visible in dimming headlights if your system isn't ultra stable.
[Re: feets]
#723677
07/15/10 10:33 PM
07/15/10 10:33 PM
Performance Only
i'm going to give it a try. just one more thought on this for now. i have a feeling that since the fan control unit was designed for PWM, the motor itelf never really recieves full system voltage. the pwm happens so fast that the fan will run smoothly at a designed rpm. with full voltage that thing might suck the radiator right out of the car. and just an observation, the fan has little metal balance weights on it. thanks for the help and the offer. i'll let you know how it works out.
