Re: Monster electric cooling fan upgrade. long. w/photos.
[Re: thehemikid]
#723639
07/11/10 10:54 PM
07/11/10 10:54 PM
Posts: 12,156 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
...Junk yard used, ebay new, ?. Post back on its performance. My concern is the after market only "has" to last, ...what 90 days. While the OEM last, ...WAG 75-100k. So, based on what little I know, (which isn't much)(and correct me anywhere i'm wrong) i'd want a used OEM, depending on the miles.
Most, if not all, aftermarket suppliers are also OE suppliers. I have no idea who makes Mercedes fans, but it may well be that it's not Mercedes. I have hung a lot of aftermarket rad fans and have never had a comeback. Besides, for the price difference, I can buy 3 or 4 aftermarket pieces. Doesn't seem like much of a gamble to me.
Master, again and still
[Re: gtx69]
#723641
07/12/10 07:24 PM
07/12/10 07:24 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
I ended up changing the way it is mounted next picture no bolts.Perfet fit i fit it behind the flange it gave me about 1 inch more room between water pump and fan motor.I am using a 3 core alum champion raditor.Now i just have to wire it up.I brought the kit feets suggested.$22.00 at advance auto.I have a already had a flex-a-lite on car wouldn't work with this setup.
Hey, Could you show how you mounted the shroud and fan to the radiator? Maybe a close up pic of the mounting points? That would be great!
[Re: Blakcharger440]
#723642
07/12/10 08:51 PM
07/12/10 08:51 PM
Posts: 2,091 Delray beach, Florida
Performance Only
i got the fan installed and wired today. it's mounted to a 26" crossflow radiator. like feets, i've tried just about every electric fan out there at one time or another and this thing has them all beat. the electronic temp controller is set to turn on the fan at 185 degrees. it was 95 degrees today and we had the air conditioning running on max. the fan worked flawlessly. engine temp varies a little bit depending on rpm but it kept the engine between 182 and 190 degrees. with the HHR fan the temps would climb up to over 210 with the air on sitting there idling. night and day difference and very happy with it. Feets, if your reading this, thanks for the info.
machine shop owner and engine builder
[Re: gtx69]
#723644
07/12/10 10:30 PM
07/12/10 10:30 PM
Performance Only
the radiator is a northern cross flow. 26" between the tanks. as far as the controller goes, nothing trick there. the wire that used to power the HHR fan is now used as the trigger wire for the new one. the sensor is in the cylinder head right now. i'm going to change that though so the fan doesn't run quite as long after shutting down the engine. (heat soak)
[Re: Performance Only]
#723650
07/13/10 12:33 PM
07/13/10 12:33 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Glad to hear it's working out for you! I'm always open to sharing good stuff I find as well as helping others learn from what I've screwed up.
[Re: Andrewh]
#723655
07/13/10 07:44 PM
07/13/10 07:44 PM
Performance Only
yes, it's a lifetime warranty. i e-mailed the vendor. of course i had to modify the shroud and they'll probably hassle me about it, but that doesn't have anything to do with the electronics. we'll see what happens.
#723656
07/14/10 09:21 AM
07/14/10 09:21 AM
feets
Senior Management
Senior Management
Irving, TX
Sorry to hear that yours fried. I haven't had any problems with mine. Andy and I both run Mercedes fans that were damaged in collisions.
If they give you much fuss, see if you can get a second fan, swap the motors, then send it back. They get an unmolested shroud back.
