Re: Monster electric cooling fan upgrade. long. w/photos.
[Re: gtx69]
#723538
06/20/10 11:46 PM
06/20/10 11:46 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I have not tried one yet I'm still on the fence as to even going to electric.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: gtx69]
#723539
06/21/10 10:14 AM
06/21/10 10:14 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The aftermarket fans should work. They have to bolt in to the car just like the original. I assume they have the same type motor to provide similar function to the originals.
[Re: gtx69]
#723541
06/22/10 10:42 AM
06/22/10 10:42 AM
feets
Senior Management
Senior Management
Irving, TX
Here are the part numbers for the heavy gauge wire and plastic plug: The part number for the small wire is 000-540-38-05.
[Re: rapom]
#723543
06/22/10 04:47 PM
06/22/10 04:47 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Thanks for the info, feets. I'll be putting this on my Christmas list.
My 440 doesn't really like the 110+ temps in Arizona with my current e-fan setup: the ol' 3.8L Ford Taurus fan job. Fan moves enough air, but the shroud arrangement is not ideal at all. In fact, there is probably 40% of my total core that is open to the elements and not having the fan draw air across it.
You mentioned it before, but I'd like to bring it up again. For the price you pay through Summit or Jegs for one of those uber-expensive, poor fitting fans (300-400 bucks), you've still got to buy the relays and install them. Add to that the fact that it's been proven that a number of OEM applications sometimes move DOUBLE the air of those high dollar deals. Hell, my Taurus fan moves twice as much air as a black magic and cost 30 bucks.
When you say 26" radiator, is that measured width-wise, or diagonally?
I'll be shopping around for one of these bad dogs. Thanks.
[Re: Pat_Whalen]
#723544
06/22/10 06:55 PM
06/22/10 06:55 PM
feets
Senior Management
Senior Management
Irving, TX
The Mopars either came with 22" or 26" radiators for years. You either got a little one or a big one. The measurement is taken across the width of the core, not the tank. The radiator I showed in the mock-up measures about 26-1/2" across the core. It's a 26" radiator. I think it's out of a New Yorker or something similar from the 70s.
[Re: feets]
#723545
06/22/10 07:07 PM
06/22/10 07:07 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
I've got a big block Ramcharger. I can't imagine I'd have the smaller of the two.
Might just pick one of these up off of ebay.
[Re: Pat_Whalen]
#723546
06/22/10 07:21 PM
06/22/10 07:21 PM
feets
Senior Management
Senior Management
Irving, TX
The trucks had a different shape to the radiator. They were narrower and taller. You may want to check that.
Tell me how wide and tall your radiator is and I'll measure the cracked fan shroud I've got sitting around.
[Re: gtx69]
#723548
06/23/10 04:43 PM
06/23/10 04:43 PM
feets
Senior Management
Senior Management
Irving, TX
You sure didn't waste any time! Be sure to wire it up properly. You can see the layout in my pics. If you get the two large leads backwards it will smoke the wires without the fan running. It does have a capacitor so expect a wee tiny spark when you disconnect/reconnect the battery. That's normal and won't hurt anything.
If you can put your radiator on a bench and fit the fan to it you'll have an easier time.
[Re: Pat_Whalen]
#723551
06/23/10 07:07 PM
06/23/10 07:07 PM
feets
Senior Management
Senior Management
Irving, TX
The studs will be too wide for the fan shroud unless they happen to fit where the tabs are. That would be a long shot for all four but maybe one pair might fit.
It would still fit across the core of the radiator. Simple brackets might be able to hold it to the core assuming the distance from the core wasn't too great.
I don't know of any Mercedes radiators that are wider. Maybe an S class?
[Re: feets]
#723552
06/23/10 07:20 PM
06/23/10 07:20 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
So you're saying the entire shroud would be physically smaller than my core, but still cover it well enough? I wouldn't mind having to fab some brackets to hold it to the rad, I just don't want it to be sickeningly undersized (albeit my current taurus fan is).
[Re: Pat_Whalen]
#723553
06/23/10 08:58 PM
06/23/10 08:58 PM
feets
Senior Management
Senior Management
Irving, TX
The fan shroud measures 16-3/4" tall and 26-3/4" wide.
[Re: gtx69]
#723556
06/23/10 11:22 PM
06/23/10 11:22 PM
Posts: 12,039 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Well, that was quick! I'll call them tomorrow. Thank you.
Master, again and still
