Page 1 of 20 1 2 3 19 20
Monster electric cooling fan upgrade. long. w/photos. #723498
06/13/10 09:02 PM
06/13/10 09:02 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I've been on a never ending quest for an electric cooling fan that WORKS. There's no telling how many fans I've had on the hot rod over the years. I've tried pushers, pullers, pushers and pullers, cheapies, expensive fans, and everything else you can think of. The extra heat from the turbos and associated plumbing really dumps a BUNCH of heat under the hood.
This time, I think I've got it right.
** IF YOU WANT TO TRY THIS BE SURE TO READ THIS POST **
I installed the Mercedes cooling fan today. It's a quickie install and nearly drops right in.
The fan is from a 2001 to 2006 C-class Mercedes. There are a couple styles out there but they're all the same size and shape. Mercedes used both Temic and Brose as vendors. They are designed to move LOTS of air. From the factory, these cars can have as many as 7 heat exchangers/radiators in front of them. They have to keep all that stuff cool.
You can pick up the fans from internet vendors as well as junkyards like LKQ at a reasonable cost. If your wallet is feeling frisky, you can go straight to Mercedes but don't be surprised if they ask for your first and second born in exchange.
The fan shroud measures 26-3/4" across and 16-3/4" tall. Mounted to the radiator, it sticks out 2-3/4" from the lip on the upper radiator tank. That's about 3-1/4" if you're measuring from the core of the radiator to the water pump.
The motor is rated at 600 watts. That means it will pull a maximum of 50 amps on start up and 40 amps while running. The motor is a beast!
A stock alternator from the 60's won't handle the current but there are lots of drop-in upgrades to get the required output from stock alternators. The alternator upgrade is quick and easy.
If you can't get the wire plug from a wrecked car, you can pick up the pieces at a Mercedes dealer. You will need the plastic plug, two heavy wire leads, and one small wire lead.
These fans have a start up relay and capacitor built in. When looking at the wire end of the plug the heavy wire on the left is the positive. The other is obviously the ground. The little wire is the trigger. When it sees 12 volts, the fan will slowly come up to speed. When power is removed, the fan takes a couple seconds to respond and then shuts down. Here's a video of a bench test. These monsters move some air!
http://www.youtube.com/watch?v=kGylouOxVL0
I have a 26" radiator with a trashed core. I kept it around for mocking up all those cooling fans. It came in handy again today. Here it is with the Mercedes fan sitting on it. A sharp eye will find the broken mounting tab. That's why I got this one. The insurance company had to buy a new one for the wrecked car.
It fits the radiator core like it was made for it. A view from the top shows that the fan bulge does not stick up above the tank. You can get a better view of the fit between the shroud and the core.
I trimmed off the mounting tabs since I wasn't going to use them. A little snip with some end cutters did the trick. Now it's really looking like a nice fit.
If your radiator has the factory shroud mounts on it then slip some clip nuts over the radiator tabs and pop some 1/4" x 20 bolts in the shroud and it'll bolt right up.
I did have to snip the risers going up to the back of the fan bulge.
This is where I had to take a path that's a little different from everybody else. My radiator had the shroud brackets trimmed off years ago. I had to make my own brackets. Due to my turbo plumbing, I had to flip my fan upside down. Pretend you don't see any of that and your life will be happier.
Now, back on course...
I dropped the radiator and fan assembly into the car. It goes in nicely as an assembly.
Early B bodies have an engine compartment that is tight to say the least. It's almost on par with the 60's A bodies as far as length. Still, I've got plenty of extra room in there. The left side of the shroud is below the turbo down pipe. It really doesn't make contact.
My battery is in the trunk so I ran a lead off the back of the alternator. Heavy fuse blocks are hard to find at the parts house so I picked one up from a car audio store. This one has a 60 amp fuse.
Again, it only takes three wires for this fan. Since the relay is built in, you don't have to worry about that. It's all wired up and ready to go.
The little wire is the trigger. I ran it around to my fuel injection computer and programmed it to turn the fan on and off. You can run it to a manual switch if you like, or grab a fan controller like the Imperial 226203 ($20) and have it control the fan automatically.
[img]http://shop.advanceautoparts.com/wcsstor...03_pri_larg.jpg[/img]
The car is ready to rock 'n roll! It's that easy. Total install time shouldn't take more than 2 hours if you're taking your time.
My car has a mangled radiator support. Someone played bumper cars years ago and didn't fix it properly. The bottom of the radiator is almost 2 inches farther back than the stock location. A sharp eye will notice the angle on the radiator. Still, I have plenty of room to service the engine.
[img]http://sphotos.ak.fbcdn.net/hphotos-ak-a...9_2521071_n.jpg[/img]
[img]http://sphotos.ak.fbcdn.net/hphotos-ak-s...6_4298220_n.jpg[/img]
These fans work! I installed a similar fan on Andrewh's '65 Coronet with the 5.9 Magnum. It works like a champ! The fan only has to run for a minute or two before the radiator cools off enough to shut the fan down.
This fan will suck a terrycloth towel against the grille and hold it there. It appears that my air flow issues have been resolved.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723499
06/13/10 09:06 PM
06/13/10 09:06 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I wonder how well the aftermarket replacements hold up. It would make it a little easier to source the part if you don't have access to a Mercedes junk yard.
http://shop.ebay.com/i.html?_nkw=mercede...3286.m270.l1313
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: HealthServices] #723500
06/13/10 09:51 PM
06/13/10 09:51 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Nice and simple hook up.How much was the wiring plugs from mercedes?Do i need to get a loan from the bank?
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: HealthServices] #723501
06/13/10 10:00 PM
06/13/10 10:00 PM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
Feets, thanks for all the research and the pics, that looks great! Would you mind giving out the part numbers for the Mercedes plug and wires?
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: 440child] #723502
06/13/10 10:03 PM
06/13/10 10:03 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The Mercedes plug and wire part numbers are in the picture of the plug and wires. I don't have the bag from the little wire but a parts guy can find it in about 5 seconds using the number for the plug.
I should know. I'm a Mercedes parts guy.
I don't remember the cost of the parts. I think it was around $20.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723503
06/13/10 10:08 PM
06/13/10 10:08 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Would the fan assembly be the same for the 4 and 6 engine or do they only have one size engine in the C230 mercedes?
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723504
06/13/10 10:14 PM
06/13/10 10:14 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Here's the same style fan installed right side up in a friend's 360 powered Dart. He bolted the fan to his factory shroud mounts. No hacking required.
Click the link to the pic. It's pretty big. You can see how it's mounted.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723505
06/13/10 10:16 PM
06/13/10 10:16 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
This is the line that sold me. Some programmable set ups will run and run and run but never pull the temperature back down to automatically turn off while idling.
Seems like the Benz fans do it easily.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: gtx69] #723506
06/13/10 10:18 PM
06/13/10 10:18 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
It's the same fan on the 4, 6, and 8 cylinder cars. Even the AMG cars use that fan. It fits some CLK cars as well.
The C230 was a 4 banger then went to a V6.
The C240 and C320 are V6 cars.
The C32 has a supercharged intercooled V6.
The C55 has a 5.4 liter V8.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: Magnum] #723507
06/13/10 10:22 PM
06/13/10 10:22 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Why not use the ground as the trigger with an OE type switch? Why trigger with the +?
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: Magnum] #723508
06/13/10 10:24 PM
06/13/10 10:24 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
If you click the video link you can hear the fan running. It's hard to record the air movement on video. That's why I used the leaves and small flag.
When I have the fan running and the hood open the air is still blasting past the driver's vent window.
They move lots of air.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: BergmanAutoCraft] #723509
06/13/10 10:27 PM
06/13/10 10:27 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Thanks for all the info Feets.You're my hero.Now i can throw that hhr fan away and get a real fan. Be back on the road.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: BergmanAutoCraft] #723510
06/13/10 10:34 PM
06/13/10 10:34 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
That's how Mercedes designed it. You don't want to interrupt the current by removing the ground. 50 amps is a lot of current to be switching on and off.
The fan always has power, just like your headlights. It only turns on when you flip the switch.
The fourth cavity in the plug is for a feedback wire for the engine controller. It obviously isn't used in our applications.
The internal fan relay grounds through the fan motor to chassis ground.
The fan relay I used to fire the old electric fan now powers the trigger. My computer grounds the relay to complete the circuit.
Since most folks here don't have EFI, all they need to do is find a way to put 12 volts to that trigger lead. Do whatever makes you happy. Since it's powering a relay there will be no appreciable amperage on the lead.
It's my understanding that supplying a lower voltage signal to the trigger will run the fan on low speed but I don't have a good way of testing that.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723511
06/13/10 10:54 PM
06/13/10 10:54 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
thanks for the information and write-up.
my question is: are the 2000 c230 fans the same or only from 2001 on up? i ask because theres a 2000 c230 available for parts locally.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: pauly v.100] #723512
06/13/10 11:01 PM
06/13/10 11:01 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The 2000 C230 was a different chassis. It's fan is totally different.
You can always contact LKQ and see if they have a car with the correct fan in your area. I have no idea what they charge for the fans. It will vary by state and wholesale vs retail.
http://www.lkqcorp.com/home/home.asp
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723513
06/14/10 01:19 PM
06/14/10 01:19 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Thanks again!
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: pauly v.100] #723514
06/14/10 03:48 PM
06/14/10 03:48 PM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
Feets, is your radiator a 26" in a 22" core support?
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: 440child] #723515
06/14/10 04:35 PM
06/14/10 04:35 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Yes. That's why the radiator is hacked in there. It works.
gtx69, clear out your in box.
- Stu Harmon
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: feets] #723516
06/14/10 05:48 PM
06/14/10 05:48 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
I wonder, is it that noisy in the Mercedes? If it is I'm surprised the yuppies put up with it.
Re: Monster electric cooling fan upgrade. long. w/photos. [Re: John_Kunkel] #723517
06/14/10 06:07 PM
06/14/10 06:07 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Feets box is cleaned out.
