Re: stock stroke 440's [Re: greenmcode] #723480
06/16/10 12:16 AM
06/16/10 12:16 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
Here is my stock stroke street 440 combo.
.030 over 440
11.1 comp
stock crank
cower billet rods
bushed lifter bores
comp solid street roller cam
crower lifters
MW ported Indy SR heads
1.6 rockers
ported indy DP intake
pro systems 4150 carb
TTi headers
No times yet still working bugs out of the rest of the car.
Re: stock stroke 440's [Re: Mopar Racer] #723481
06/16/10 08:23 PM
06/16/10 08:23 PM
Chattanooga,Tn
Mopar Racer Offline
Mopar Racer  Offline
Chattanooga,Tn
Yes it was an O.E.M. steele crank.It had over 900+ passes on it with one freshening up after about 325 or so.I bracket race alot,sometimes twice a week.The engine had the usual great oil pressure before I was making the pass it let go on.Right before It was going to make the shift to 2nd gear it broke.After tearing the engine down,the crank was broke in 3 pieces.But the main webbing on the thrust main was busted from the crank bearing all the way up to the cam bearing.So I,m not sure which let go first the block or the crank.
Re: stock stroke 440's [Re: 67mprfan] #723482
06/16/10 09:21 PM
06/16/10 09:21 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
My old 440 that I had back in 1992:
bored 0.060
LY connecting Rod
Factory forged crank
Venolia Pistons 13 to 1
2 Holley 750 on a M1 manifold Mopar Performance
Mopar Performance Mini Express Mushroom Lifters
Centerline 106 lift 654, duration 316/316
2 1/8 Racing Headers
440 Cilinder Head 906 Back Yard Ported
All motor
1968 Charger 3700 lbs. with me in it
ran 10.50 at 126-127 mph. Drived 20 miles from house every weekend
