Re: E body 8 3/4 into an A body question or 2
[Re: Cuda340]
#723327
06/16/10 02:58 PM
06/16/10 02:58 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
I have to ask why not get an A-body rear 8 3/4 instead of trying to use B or E Body ones??? I understand he has the E body one, but why not sell it and get the correct rear???
A body rears are in the 250-350 range just for the housing.
I can find B body 8.75's complete for under $150 on occasion.
[Re: bboogieart]
#723329
06/16/10 08:31 PM
06/16/10 08:31 PM
Posts: 12,327 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Okay guys. I found a '67 B body rear for $150. It's out and on the ground and only about half an hour away from me. That appears to be the path of least resistance. I have a couple of E body 8 3/4s out in the barn that I doubt I will ever use. But I guess I'll use this other one instead.
10" rims with custom backspacing and some Dr. Diff axles and I think I am good to go.
I am not sure whether I will pull the springs over to the seats and use the ones already on the housing. Or whether I will cut them off and weld on the new ones I already have. I noticed that the center holes were larger on the new ones than on the old ones. I am not sure that is any better than pulling the springs over a little.
Thanks again guys!
Master, again and still
[Re: 70SWGR]
#723332
06/17/10 09:32 PM
06/17/10 09:32 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I picked up the 66 diff tonite. I'll mock it up tomorrow and decide what to do about the spring seats. I think I will probably just elongate the holes outward a little. That way the for/aft part of the hole is the same, which is the way the housing will be trying to twist. I was really surprised at how big the center pin hole was on the new MP spring seats that I got from Mancini.
[Re: DaveRS23]
#723333
06/17/10 10:10 PM
06/17/10 10:10 PM
Posts: 15,487 Florida
scratchnfotraction
you could just pick up new spring bolts from napa with the correct size head on them then just swap the bolt in the spring pack I clap the leafs to gether with c-clamps then remove the locating bolt and replace i also get them longer than needed so it ez-er to work the leafs and bolt swap then trim the bottom of the bolt when done ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: scratchnfotraction]
#723334
06/17/10 10:57 PM
06/17/10 10:57 PM
scratchnfotraction
make sure to sand blast it and paint it nice and purdy ![](/ubbthreads/images/graemlins/apimp.gif) just did mine,A-body 8 3/4 and got it in my 85 truck with 12s and 29x15x15 M/Ts
#723336
06/18/10 09:23 PM
06/18/10 09:23 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Now that's cool. And you have the same tires on your truck that I run on the Cuda.
