E body 8 3/4 into an A body question or 2
#723306
06/13/10 07:56 PM
06/13/10 07:56 PM
Posts: 12,310 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have pulled the 7 1/4 out of my project 68 Dart and would like to put an E body 8 3/4 I have laying around back into it. I know the E body housing is a little wider drum to drum than the A body housing, but I plan on ordering rims anyway so a change in offset to fit shouldn't be an issue.
I have a set of spring seats to weld on after I remove the E body seats. In measuring everything up, it appears to me that the E body 8 3/4 pinion will be about 3/8" farther offset than the 7 1/4 was with the housing centered in the body.
My questions are; A) does that difference in pinion location sound about right? B) will that small amount of driveline mis-alignment cause any real problems?
Thanks!
Master, again and still
Re: E body 8 3/4 into an A body question or 2
[Re: DaveRS23]
#723307
06/14/10 06:16 PM
06/14/10 06:16 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Anyone...........................?
[Re: Kern Dog]
#723311
06/14/10 07:38 PM
06/14/10 07:38 PM
Posts: 15,487 Florida
scratchnfotraction
the early B-body housing is the one that will bolt in an A-body ![](/ubbthreads/images/graemlins/thumbs.gif) it has the 44" perch centers and the a-body springs can be pulled 1/2" on each side to bolt it in ![](/ubbthreads/images/graemlins/wrench.gif) i had moser cut me a c-body housing down to a-body specs and use their large brake offset,5 on 4.5 wbp custom alloy a-body axles shiping/housing x2=80$ narrow housing was around 75$ way cheaper than buying an a-body 8 3/4 ready to run,IMO axles were 299 a set with greens ![](/ubbthreads/images/graemlins/iagree.gif) dont chop the e-body housing kinda like an a-body housing now days...worth something truck and c-body housing are good to chop down and the axles could be canadates for a cut respline on the cheap as well (I would save a truck housing myself and use the c-body housings no one wants) the early b-body in the a-body will need the offset rims also but no were near what the one you are talking about will...if they even make them ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: scratchnfotraction]
#723312
06/14/10 07:46 PM
06/14/10 07:46 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Pulling leaf springs IN to fit a wrong spring pad isn't right. Come on, man! I like junkyard science as much as anyone, but this kind of stuff gives car guys a bad name. When the rear springs go through their range of travel, this "Mod" will put undue stress on the springs, bushings and shackles. With 35+ years on the road, who knows what could happen. The shackles could fold during compression and then the rear end kicks to one side. Want to guess which way the car will turn at 65 mph? If you can locate another axle, YES, the 66-67 B body is the closest width to use. The 68-70 is about 3/4 wider if I remember right. RELOCATE the spring pads the right way and burn rubber! ![](/ubbthreads/images/graemlins/drive.gif)
#723313
06/14/10 07:50 PM
06/14/10 07:50 PM
scratchnfotraction
the offset of the pinion is not a big deal IIRC you want the axle same length on each side,let the pinion offset fall were it is,IIRC with out the backing plates on the housing pull the tape measure from flange to the oppisite side and weld the perch center at the 43" mark pull from the other side flange and weld perch centerd at the 43" mark this will set the housing center on 43" a-body specs want to make sure you get the pinion angle on the housing correct IIRC the pinion is 7* with the perches level dont recall if its 7* up or down though..I just read that here the other day...main reason i had moser do it ![](/ubbthreads/images/graemlins/whistling.gif) fit the first time and is correct ![](/ubbthreads/images/graemlins/bow.gif) FYI.. I have since bolted the a-body axle in my 85 truck as they share the same 43" perch centers as the a-body bolts in on top of springs and tucks 12" rims in the fenders of a stepside with 29x15x15 M/Ts i have thought about putting a truck axle under an a-body and use a straight front axle to make a gasser a-body ![](/ubbthreads/images/graemlins/boogie.gif) just food for thought ![](/ubbthreads/images/graemlins/biggrin.gif)
#723314
06/14/10 10:10 PM
06/14/10 10:10 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The only reason I am using the E body housing is because I have it laying around. It would be a lot more trouble for me to find and pull another 8 3/4. I would gladly trade it to anyone with one of the early B body housings if they wanted this one. I have stripped the housing bare so as I can prep, measure, and accurately mod it.
I am using the original 7 1/4 as a basic pattern to mod and install this 8 3/4, which is how I discovered the difference in the pinion locations when I mocked it up. A local welding shop looked at what I wanted to do and said that with angle-finders, getting the spring seats on at the correct angle is no big deal at all. But that shortening the axle tubes would be quite a bit more involved. (Meaning more money)
The car is a 68 and I have a set of Bill Reilly's templates so I can open up the rear fenderwells. I plan on using at least 10" rims, so I should have enough rim to get the backspace right.
I will check around and see if there is an old B body housing laying around before I tackle this one. I have some time before I need the rear.
I do have a truck Dana, too. But that would be a lot more work, what with changing the flanges and all.
Thanks for the help and info. I'll keep you posted if I find a B body rear.
[Re: Kern Dog]
#723315
06/14/10 10:16 PM
06/14/10 10:16 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
It seems to me that SOME E body guy would want your axle. Personally, I would look for a C body or Van 8 3/4 and have it cut down to work.
I have that c body rear right here, it's yours if you can get it shipped or come get it. in Northern Wisc.
[Re: bboogieart]
#723316
06/15/10 08:14 AM
06/15/10 08:14 AM
scratchnfotraction
you need a jig and pucks to cut reweld the ends on the housing..thats the more involved part with 10 rims they are gonna stick out anyways,so weld up the perches on 43" centers and run it your gonna cut the slab side so it should not rub but... if you do cut the housing dont go by the 7 1/4 specs..use the a-body 8 3/4 specs abody 8 3/4 only came with the small bolt pattern and the skinny 1 3/4" brakes when you use the large brake offset axle it will make the whole rear 1/2" wider...1/4" each side and let you run the b-body brakes check the e-body axle to see if it tappers down in the 28" area...they maybe good canadates for a cut respline...my 30" e-body axle are ![](/ubbthreads/images/graemlins/scope.gif) IMHO,you would be ahead of the game if you have the housing narrowed and cut respline the axle all to a-body specs,you got time,its cheaper,and it will fit correct a 68 dart is slab sided and the wheel wells are narrower than the duster/dart wheel wells,so it needs to be close with the e-body axle and brakes 4.5 backset on the rims will put it right for clearance on the tire bulge and spring after its cut to a-body specs I drove myself crazy with the measurements so I left it to moser...I just asked to have it cut to a-body housing specs and told them I was running the large brake offset axles fit perfect with the tire/rim in the center of the wheel well good luck either way ![](/ubbthreads/images/graemlins/Twocents.gif)
#723317
06/15/10 08:21 AM
06/15/10 08:21 AM
scratchnfotraction
never said pulling the spring out some to fit was correct...its just been done a lot...I have never seen or heard of a problem with it either I was just saying that could be done ![](/ubbthreads/images/graemlins/iagree.gif) haveing it cut to a-body specs is the right way and the fit is spot on but I have been were he is at trying to use what I have laying around and pulling the spring over either way a 1/4" is no biggie,,,it moves that much stock with worn bushings anyways ![](/ubbthreads/images/graemlins/whistling.gif) I know hickabilly real well and its not for every one...but I have built some mean rides using what i have on the cheap and it works for me thats why I am suggesting to him...just have moser cut and respline the whole thing bolt it in and it will resale later with no problems ![](/ubbthreads/images/graemlins/Twocents.gif)
#723318
06/15/10 08:01 PM
06/15/10 08:01 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I called a couple of buddies today looking for an early B body 8 3/4, no one had one. I'll look a little more the next couple of days. I feel that getting new spring seats on in the right place and at the right angle will not be a big deal. The new seats were $10 and the machine shop said maybe $50 to plasma off the old ones and locate and weld on the new ones.
I plan on ordering a new set of axles from Dr. Diff. I am not comfortable using stock axles in this application.
[Re: DaveRS23]
#723319
06/15/10 08:20 PM
06/15/10 08:20 PM
scratchnfotraction
by chance is the e-body housing you have 55 inches or so?? I have one that i think is an e-body but was told it came from a 67 polara which I think is a c-body the perches are 46"center if I recall i think the early B-body are 44" centers if it is an early B-housing you can get this one on trade if you want need to see if its the same as you got first ![](/ubbthreads/images/graemlins/popcrn.gif)
#723320
06/15/10 08:34 PM
06/15/10 08:34 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
It's about 56 1/2" flange to flange.
[Re: Kern Dog]
#723322
06/16/10 07:56 AM
06/16/10 07:56 AM
scratchnfotraction
mine comes up a tad over 55" IIRC I will dig it out and measure it agian this weekend flange to flange with out backing plates and get a perch center measurment are your axles 30" long from flange to end of splined shaft? I have looked at the chart in the archives and still cant figure which one it is and one of the charts is wrong..just cant remember which one ![](/ubbthreads/images/graemlins/popcrn.gif)
