Removing paint from plastic interior parts question #722510
06/12/10 05:32 PM
06/12/10 05:32 PM
Tenn.
jrwoodjoe Offline OP
Tenn.
I have a friend visiting and he needs to remove some paint from some interior panels that were painted some time ago. He wants to redye them correctly. What should he use to strip without damaging the grain or plastic?
Thanks. Joe
65 Barracuda
70 Challenger
Re: Removing paint from plastic interior parts question [Re: jrwoodjoe] #722511
06/12/10 06:01 PM
06/12/10 06:01 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Joe,
I have used brake fluid.
Ray
Re: Removing paint from plastic interior parts question [Re: rayztoy] #722512
06/12/10 06:46 PM
06/12/10 06:46 PM
Middle of the mitten
69DodgeCharger Offline
I have had good luck with plain old car wax and a good stiff brush but recently read that you can use Easy Off oven cleaner. Spray it down and then wrap it in a plastic bag or saran wrap, let sit overnight and then brush off and rinse and re dye in the color you want. Although I have never personally tried this method.
Re: Removing paint from plastic interior parts question [Re: 69DodgeCharger] #722513
06/12/10 07:17 PM
06/12/10 07:17 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Whatever you decide on using, test a little on the back side to see if it softens up the plastic first. Hate to see you open up that bag in the morning to be greeted by a pile of ooze.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Removing paint from plastic interior parts question [Re: jrwoodjoe] #722514
06/12/10 08:56 PM
06/12/10 08:56 PM
Alberta
rustbuckett68 Offline
Alberta
Easy off (not the descented stuff) works good on styrene, as in plastic models. As stated, check on the back side of the part.
Re: Removing paint from plastic interior parts question [Re: rustbuckett68] #722515
06/13/10 06:34 AM
06/13/10 06:34 AM
Tenn.
Tenn.
Thanks for all the input everyone. I know there had been post on the subject before but couldn't find the thread. I gave him the info. before he left and he was very appreciative.
Joe
