Trailer cleaning, Simply Awesome or Totally Awesome?
#721690
06/11/10 06:04 PM
06/11/10 06:04 PM
Posts: 43,243 Bend,OR USA
Cab_Burge
I went to the local dollar store looking for some cleaning solution that I had read about on here several weeks ago, I should have done a search before going I bought some stuff called Totally Awesome, with bleach. Is this the same stuff as Simply Awesome or , if not, has anyone used this stuff on the sides of the enclosed traikers to remove streaks?
Re: Trailer cleaning, Simply Awesome or Totally Awesome?
[Re: Cab_Burge]
#721691
06/11/10 06:24 PM
06/11/10 06:24 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Totally Awesome is all I will use on my enclosed....great stuff
Rickster
[Re: Cab_Burge]
#721692
06/11/10 06:30 PM
06/11/10 06:30 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
LA,s "Totally Awesome"! Be Carefull with it, at Full strength it will dissolve your paint making its own streaks. Its recommended to dillute it. Ive used it full strength but had someone right beside me to rinse it off imediately after I scrubbed it clean to my liking. mike Great Stuff!!, Ah I mean "Totally Awesome" mike
[Re: Cab_Burge]
#721693
06/11/10 08:02 PM
06/11/10 08:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Totally Awesome .... works great.... use it full strength but dont let it dry on you before you get it wiped off, you will see the procedure when you get started... I would do areas in a 2' wide starting at the top and work down then move over and back to the top... it works fast so dont dilly dally .... also I never used the stuff with bleach
[Re: MR_P_BODY]
#721694
06/11/10 09:14 PM
06/11/10 09:14 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Yeah...I picked up on this also several weeks ago and bought some LA Totally Awesome.... great stuff for motorhomes and trailers[white]. i used a soft brush on a stick and used it 50/50. What worked well was and old Windex Outdoor bottle with the built in nozzle[off...rinse...clean] at 50/50. Squirt it on brush it around....rinse. Tough to find some stuff that impresses these days.
The little old lady from Pasadena is back!
[Re: MR_P_BODY]
#721695
06/11/10 09:59 PM
06/11/10 09:59 PM
Sport440
Canton, Ohio
So dont Dilly Dally... Cabby, with it!
also I never used the stuff with bleach.
Me neither, mike
[Re: GaryHemi]
#721702
06/13/10 10:20 PM
06/13/10 10:20 PM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
I just started using Fastball. Hands down the best stuff I ever used. You have to spray it on and wipe it off. It will take stains out that I used to buff. I just got done with one side of my 48 footer. Then waxed it. Not looking forward to the other side. Lot of work.
Why does divorce cost so much?
Because it is worth it!!!!!
