Re: MP .590 cam info
[Re: SILVER67]
#720128
06/10/10 12:35 PM
06/10/10 12:35 PM
Posts: 951 Alliance, Ohio
Valiant_Showoff
Alliance, Ohio
I think the 3.23 gears are going to slow me down a bit.... Wondering how the .590 will like the 3.23's?
I do have a good 9 1/2 Dynamic (currently stalls a tad over 3000 in the .090 in the hole 440 I have with a Comp 470H) and a low first gear if that helps...
Michael
The 590 will HATE the 3.23 gears. IMO, you'll need 4.10's or steeper?
Re: 383man
[Re: Thor500]
#720134
06/10/10 04:19 PM
06/10/10 04:19 PM
Posts: 535 Ohio
racerAL
Ohio
absolutely..i'm ruuning the .590 with those rockers with NO problem.
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
Re: 383man
[Re: Thor500]
#720135
06/10/10 04:39 PM
06/10/10 04:39 PM
Posts: 2,379 MD
Kevins493
MD
Can you run the Crane type ductile rocker arms with this cam? Not to hi-jack the thread.
I'm using the same ones so thats not really a hijack!
Re: 383man
[Re: racerAL]
#720138
06/10/10 09:04 PM
06/10/10 09:04 PM
Posts: 625 Florida-West Coast
Thor500
Florida-West Coast
Thats good to know, maybe my stroker will be done sooner than I thought!
[Re: StripeHOG]
#720139
06/11/10 08:29 AM
06/11/10 08:29 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
HA HA , not entirely snooping Keith. A couple of years ago you sent me a used .590 in great shape, I just had to pay the shipping. I am trying to build a combination in my mind that I can use it now. The .590 seems to be a cam that will get a 493 close to the 600HP mark with MCH stage I ported Eddy RPM's.... Or at least I am hoping.
Like to get my '67 R/T in the 11's.....
Michael
you should be well into the 11's w/ that combo, You could probably get into the 11's w/ a 557.
my car has run a best of 11.13 w/ the .528 purple cam
wow that's a good slip for the 528!
[Re: cudadoug]
#720142
06/11/10 06:24 PM
06/11/10 06:24 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I am surprised Bob (Prosport) hasn't chimed in here. IIRC, his Dart Sport had a low deck 451 with Eddy heads...and a .590 MP stick, and went 9.90's @ 133-ish...
Rumor has it that it wasnt the MP 590. He painted the shaft purple and called it the MP .590
[Re: Sport440]
#720143
06/11/10 06:27 PM
06/11/10 06:27 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Uh oh...hello...Bob??
[Re: maximum entropy]
#720144
06/11/10 07:54 PM
06/11/10 07:54 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
Michael
that's up to the converter. 3000 is prolly too low. prolly. i've run giant cams and tall gears many times. with the right converter, it'll be huge fun.
[Re: SILVER67]
#720146
06/12/10 01:53 PM
06/12/10 01:53 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Would this cam still be pump gas friendly (93 octane) with aluminum heads and say 11 to 1 compression? Would it be worth it to use this cam in a 493 at that point for a street/strip car?
Seems like it would not be too difficult to build a 600HP 493 with MCH Eddy RPM heads and a Holley Street Dominator and thei cam? Flat tops? Maybe? Just bench racing....
I had a .030 over 440, .590 with 12.5:1 compr. mild stage 6 heads, M1, headers and it made 630HP on the dyno.
The low gear set will help with that cam. Otherwise 3.23 gears would really slow it down. Don
[Re: cudadon]
#720147
06/12/10 04:41 PM
06/12/10 04:41 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
Sorry guys, been busy with baseball and car shows(Super Summit today). I actually shot 'Kevins493' a private message the day he started this thread to give him my 590 advice. I've posted it so many times I thought you guys might be tired of hearing it.
My old 73 DartSport, now owned by 73DartSport had an 11.2 to 1 compression pump gas 451(added 50% CAM2 at the track just for safety but we may run a 20% mix next time out). 400 block and 440 crank, 440 length rods. Had ported Eddy heads, 590 cam and 1.6 rockers. I installed the cam at 104 so it was 2 degrees advanced, I didn't want to go further and lose MPH. Flat tops were around .018 in the hole iirc. It went 9.96 in good air, and with the tunnel ram and 2 750's it went 9.88 or 9.89 at 134 MPH at 3050#'s with me in it.
I ran crane ductile iron rockers for a couple years and then switched to Harland Sharps just for safety. I think iron rockers from RAS would be the way to go but I do love the Harlands.
Maintenance free streetable combo that would 60 foot at 1.36 footbraking and run high 9's through a quiet X-pipe/Magnaflow exhaust system. I loved that combo and may go back to it with my next car.
Oh, also had an 8" ATI converter and 4.30 gears with 32" tall tires.
