Reproduction choke available for Holley on 383/440? #719145
06/08/10 01:34 PM
06/08/10 01:34 PM
Highland, Michigan
1972Rallye Offline OP
Highland, Michigan
I can't find one anywhere (except NOS on e-bay) that's affordable... For '71 and '72 in my case -both take the same one. I know some '69 and '70 models had them too.
Re: Reproduction choke available for Holley on 383/440? [Re: 1972Rallye] #719146
06/08/10 05:51 PM
06/08/10 05:51 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
hey thanks for the note... sucks doesnt it? avs ones are 40.00 holley 200.00 repro! dan
Re: Reproduction choke available for Holley on 383/440? [Re: 1972Rallye] #719147
06/08/10 08:21 PM
06/08/10 08:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
no repops avail as of yet. so for now its good used or nos only.
Re: Reproduction choke available for Holley on 383/440? [Re: gtx6970] #719148
06/08/10 11:07 PM
06/08/10 11:07 PM
New Lenox il.
CARMAN Offline
CARMAN  Offline
New Lenox il.
I have this one was told it is for 69-72 bigblocks with a holly carb.Replaces factory part #3512867.If intrested let me know.
Re: Reproduction choke available for Holley on 383/440? [Re: CARMAN] #719149
06/08/10 11:08 PM
06/08/10 11:08 PM
New Lenox il.
CARMAN Offline
CARMAN  Offline
New Lenox il.
Pic of part #
Re: Reproduction choke available for Holley on 383/440? [Re: CARMAN] #719150
06/09/10 04:30 PM
06/09/10 04:30 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
thats 2 BBL just fyi dan
Re: Reproduction choke available for Holley on 383/440? [Re: ph23vo] #719151
06/09/10 07:06 PM
06/09/10 07:06 PM
New Lenox il.
CARMAN Offline
CARMAN  Offline
New Lenox il.
Looked it up here.type in 3512867
http://www.mymopar.com/index.php?pid=99
Re: Reproduction choke available for Holley on 383/440? [Re: CARMAN] #719152
06/09/10 10:13 PM
06/09/10 10:13 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
well it wont fit any holley 4 BBL carb i,ve ever seen.. the flat one barely clears.. so i dont know what to tell you.. good luck dan
Re: Reproduction choke available for Holley on 383/440? [Re: ph23vo] #719153
06/10/10 03:45 AM
06/10/10 03:45 AM
Anchorage, Alaska
Iceman01 Offline
Challenged
Iceman01  Offline
Challenged
Anchorage, Alaska
The cross-referenced or replacement part # listed in the Mopar parts book is dead wrong and does not fit correctly -- I paid a lot of money to find out...
Until total honesty is on the table, we're not even talking about reality...
Re: Reproduction choke available for Holley on 383/440? [Re: Iceman01] #719154
06/10/10 07:20 AM
06/10/10 07:20 AM
michigan
70 buzz Offline
70 buzz  Offline
michigan
Here is a picture of my choke. It is inperative to have the right gasket for the carb if you don't you will have clearence issues. My carb is a Holley. 383 engine 1970
Re: Reproduction choke available for Holley on 383/440? [Re: 70 buzz] #719155
06/10/10 09:14 AM
06/10/10 09:14 AM
Highland, Michigan
Highland, Michigan
Thanks for the great pic. Looks like the right one and matches the NOS choke thermostats I've seen.
Re: Reproduction choke available for Holley on 383/440? [Re: 1972Rallye] #719156
06/10/10 12:10 PM
06/10/10 12:10 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
never seen one of those on a factory set up.... always had the flat one..thats the first i have seen one of the replacements on a car!.. i just need a correct one since my car should be done factory corect is all.. dan
Re: Reproduction choke available for Holley on 383/440? [Re: 1972Rallye] #719157
06/10/10 12:28 PM
06/10/10 12:28 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Could you tell us exactly what your application is? There are a lot of different Holley four bbl chokes for 70-72 cars. Please post specifics.
Re: Reproduction choke available for Holley on 383/440? [Re: 70 buzz] #719158
06/10/10 01:25 PM
06/10/10 01:25 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
now im confused.is this kind of choke thermostat oem for a -70 383hp?at least i got one in the trunk of my -70 when i bought it,it says holley on it.sorry for hijacking but i think its related,how thick carb gasket is workable with the choke connected?.
Re: Reproduction choke available for Holley on 383/440? [Re: m46rat] #719159
06/10/10 01:40 PM
06/10/10 01:40 PM
Highland, Michigan
Highland, Michigan
The '71 is a 383 Magnum, Auto, No A/C, No N96 - Holley carb number 4668
The '72 is a 440 Magnum, 4 Speed, No A/C. N96 - Holley carb number 6254
The parts books I have both call out 3512867
Re: Reproduction choke available for Holley on 383/440? [Re: cuda-sweden] #719160
06/10/10 01:44 PM
06/10/10 01:44 PM
MoreParts Offline
MoreParts  Offline
My 70 383 Holley'd Challenger R/T has the same setup as above.
Re: Reproduction choke available for Holley on 383/440? [Re: ph23vo] #719161
06/10/10 01:55 PM
06/10/10 01:55 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Then you have obviously NEVER seen OR owned a 1970 Big block with a 4bbl since you are confusing the OP issue with your 68 and 69 big block 4bbl cars ...
HELLOOOOOOOO!!!!!!!!!!!
Re: Reproduction choke available for Holley on 383/440? [Re: cuda-sweden] #719162
06/10/10 01:58 PM
06/10/10 01:58 PM
JohnRR Offline
JohnRR  Offline
Yes you can thank Dan for confusing you.
That is correct for 1970 ,edit ... i see you need a thick basket wit hthe holley also ... but it is definitely needed for a CARTER or the carb will not fully seat to the manifold and you might break it trying .
Re: Reproduction choke available for Holley on 383/440? [Re: JohnRR] #719163
06/10/10 02:17 PM
06/10/10 02:17 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The pictures are correct, you need a 1/4" thick base gasket for the proper carb height, a thin gasket will have the carb resting on top of the choke housing, NAPA has the correct gasket. This is the same gasket for 383 Carter or Holley and 440 4BBL GTX, the chokes are different.
Re: Reproduction choke available for Holley on 383/440? [Re: JohnRR] #719164
06/10/10 02:22 PM
06/10/10 02:22 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
If you were around Seattle area shows in the early 2000's then it would be painfully obvious that he did own a 1970 Road Runner 383 AT car. We were all so glad when he flipped it. It was advertised here on moparts.
