Re: Junk motor mounts..UPDATE
[Re: minivan]
#717423
06/12/10 01:26 PM
06/12/10 01:26 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
OK started and power braked car with new Schumaker mounts... WOW hardly any engine movement at all.. Still cannot believe the "made in India" mounts I purchased at NAPA, with 1700 miles on them, allowed so much movement...
The negative.... ALOT more vibration is going through my car from the engine... Hopefully some of this will dissipate after I drive it a while.
Hope this helps some of you....
Try putting a regular mount , not india sourced if you can find one , on the pass side .
[Re: Magnum]
#717426
06/14/10 09:51 AM
06/14/10 09:51 AM
JohnRR
A gulag near you.
Add a chain and be done with it.
I tried that before. Next I ripped the passenger side one downwards.
Do the cars use the same rubber mount as trucks? If so get Diesel mounts
Dodgeboy, what are these diesel mounts you speak of?
He is asking a question he does not know the answer to , there is no diesel mount that is the same as the biscuit car mount .
[Re: 1967GTX440]
#717427
06/14/10 12:44 PM
06/14/10 12:44 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
I just replaces my motor & trans mounts with Schmucher mounts 67 b body 440 it raised the motor a little over an inch the car now drive 100% better and different.I have no vibration from the motor it's a 440 and it's balanced.
Now this is interesting.....
Drove my car over the weekend and I think my carb is acting up again. I have taken off the stock carb ( in the past) and blown out the passages and cleaned out the bowls and it ran great for a while.. I do think the schumacher mounts tend to transfer more of the engine vibrations than the soft "india" mounts... Hoping they might "loosen" up after some driving....
Friend with a roadrunner finally gave up on his stock carb and installed a new Edelbrock.. Said its never run so good and his gas mileage increased..
[Re: minivan]
#717428
06/14/10 02:34 PM
06/14/10 02:34 PM
JohnRR
A gulag near you.
just make sure you do not buy a PERFORMER 750
[Re: Gavin]
#717430
06/15/10 10:24 PM
06/15/10 10:24 PM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
Man, I've been down this road. At the end of the racing season last year, I started having problems skipping right over 2nd gear with the slapstick shifter. Thought the shifter was shot. Replaced it with two differnt shifters... Console in-out-in-out. Same problem. Finally noticed my oil pan was resting on the steering linkage. What the? Turns out the mounts were shot. Right sided really sagged down and left side sagged down and broken. I have a torque strap, so it wasn't really noticeable. I wanted to race the following weekend so I just got a cheap set from the local parts store. Went to the track twice and the new mounts were shot. Sagging again and back to shifting problems. I guess the shifter linkage was getting out of alignment somehow and/or rubbing on the header at the collector. So I got the Polylock mounts from Schumacher. When I called, they were on back-order and I had to wait a little over a week before they shipped, but initially they said it could have been almost a month delay. The Polylock mounts do not sag at all and created clearance problems with my Hooker Supercomp headers and the torsionbar on the left side. Thankfully the headers are two piece and I just removed the rear tube and clearanced it for the torsionbar. I was surprised at all the vibration the polylocks DO put into the car. My engine is balanced, but isn't exactly stock either. I have nine passes and not sure how many street miles on the poly mounts with no signs of trouble.
Re: Junk motor mounts..UPDATE AGAIN
[Re: dsp]
#717432
06/17/10 07:01 PM
06/17/10 07:01 PM
minivan
Eugene, Oregon
Save your money. The Korean mounts offered by NAPA are junk as well. My dad picked up a transmission mount from NAPA and gave it to me to install a couple of weeks ago. I returned it due to poor quality. The box was marked "Made in Korea". Thin gauge metal, poorly formed mounting flanges, and mounting slots that were positioned too close to the bend to allow insertion of the bolts. Schumacher mounts, although excellent quality, are an overkill for a stock application. Does Mopar (or anyone else) sell OEM rubber mounts? I do know that some of the Mopar ones are, in fact, reboxed Anchor (Korean).
I think this is the million dollar question.. Does anybody make a mount that is a good quality rubber or poly?? Something inbetween the india/Korean and the Schumacher??
[Re: Jim_Lusk]
#717436
06/18/10 07:42 AM
06/18/10 07:42 AM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
The Korean mounts seem to be decent quality, which doesn't surprise me. One of the best low cost tires on the market are also made in Korea (Kumho). You can tell that the "rubber" is low quality just by looking at a new Indian mount.
That may be, but after 1000 miles the Korea ones on my '67 were broken on the drivers side - hate to see what the indian ones would look like.
It is a 4 speed though with a 300 HP 360 crate motor - I did get on it a few times
[Re: QuickBpBp]
#717439
06/18/10 09:44 PM
06/18/10 09:44 PM
Posts: 21,242 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I raced for years and just put a solid mount on the driver's side and a rubber one on the passenger side with rubber trans mount. No vibrations and nothing moves...It's actually that simple,lasts for years...
I cut out all the rubber on my driver's side mount and welded a piece of rectangular tubing in to take the place of the rubber. My brother did the same thing to his 455 buick motor mount as well.
