Re: Congrats to Joe (KINDAFAST) Pinks All Out @ VMP
[Re: tboomer]
#717370
06/07/10 11:07 AM
06/07/10 11:07 AM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Hey Ted, They said it will be aired at the end of aug or the first of sept. Hopefully I don't look like a darn fool on tv.
6.50 @105.26
[Re: QuickDart 502]
#717374
06/08/10 04:42 PM
06/08/10 04:42 PM
Kindafast
Seaford, Va
Hey Ron, I did cut open the filter and found a little metallic in it. The oil has only been changed three times since new and I run the mess out of this past weekend. I put a new filter on it and it seems to be running great with the same oil pressure it had prior to running it hard. The ignition problem I still have to figure out. The darn thing is running great now. It's hard to fix it when you don't know whats broke.
6.50 @105.26
