Re: 1972 Dart street toy.
[Re: demon1515]
#716389
09/14/12 12:48 AM
09/14/12 12:48 AM
Exactly, but now, i don't have a back up plan, so i am all motivated again, like it should be since the beginning, but now i wont fall again on any temptation, and will finish it and have fun with it!
Good for you. You will enjoy it a lot knowing you put all that work into it. ![](/ubbthreads/images/graemlins/bow.gif)
[Re: ]
#716390
09/14/12 10:32 PM
09/14/12 10:32 PM
Posts: 234 ATL GA
demon1515
ATL GA
Thanks I WILL!
[Re: demon1515]
#716392
11/30/12 03:22 AM
11/30/12 03:22 AM
Posts: 234 ATL GA
demon1515
ATL GA
Simple Electronics are here long time ago just i didnt have a chance to show em to you guys, A new MSD Pro Billet Distributor, MSD Digital 6 with 2-step, timing retard rev limit and many other things i dont know yet how to use, plus a MSD blaster SS coil, As well as the new brake plumbing, the complete brand new wiring for the whole car from head lights to tail lights, ARP Head bolts, Melling HV oil pump, Oil pump fasteners, ARP harmonic balancer bolt, Mancini Flywheel bolts, roller pilot bearing And 3 bolt Mancini cam snout bearing, ![](http://i31.photobucket.com/albums/c390/CANDUNGO1515/Mobile%20Uploads/732A6041-FD5B-4972-BF09-6672C6746C06-5474-0000076039E921BC.jpg) ![](http://i31.photobucket.com/albums/c390/CANDUNGO1515/Mobile%20Uploads/F21A2B56-7805-4931-A707-5B1355898F9D-104-000000031071256F.jpg)
[Re: RV2]
#716394
01/19/13 08:39 PM
01/19/13 08:39 PM
Posts: 234 ATL GA
demon1515
ATL GA
Goza Machine Shop in Acworth GA is taking care of the .40 over, balance, align hone, squared the deck, rebuild the crankshaft 10 - 10 under before balance it with the billet flywheel, fluid damper harmonic balancer, Spec pressure plate, and installing the cam bearings on the block, Mr Tommy Goza is the best cant wait to get it back to start the engine assembly and blue print!
I did took apart the 833 trany with my 6 year old daughter and we just finish yesterday rebuilding it with new bearings, tail housing synchronizers and gaskets set, trust me without my daughter i couldn't do it, she got a photographic memory AWESOME!
[Re: demon1515]
#716396
02/06/13 11:25 PM
02/06/13 11:25 PM
[Re: NV69B7RR]
#716398
02/07/13 02:22 AM
02/07/13 02:22 AM
Posts: 234 ATL GA
demon1515
ATL GA
Very nice. What kind of horsepower are you looking to get out of it? Keep up the progress.
Thanks, i hope for 500 even, but if not reached i will change the cam and Boost the MOFO out and i am sure 700 will be within easy reach at less than 15 PSI of boost!
[Re: demon1515]
#716402
03/17/13 12:41 AM
03/17/13 12:41 AM
I hate these torx screws. I was putting together my wilwood front brakes and the hub to rotor plate adapter uses the 3/8x16x1 Torx screws and need to be torqued to 55lb/ft and my 40 snapped. I go to my neibour who's a mechanic to borrow one and he proceeds to give me sht for buying a cheap tool. I get a good one from him go back in my shop and go to torque the screw and bang.......the damn thing breaks.
[Re: ]
#716403
03/24/13 03:23 AM
03/24/13 03:23 AM
Posts: 234 ATL GA
demon1515
ATL GA
What a coincidence, my T45 Torx also broke putting together my wilwood brake system. LOL
[Re: demon1515]
#716404
03/24/13 04:56 PM
03/24/13 04:56 PM
I changed the screws and used 3/8x1x16 stainless bolts.
[Re: ]
#716405
03/29/13 11:48 PM
03/29/13 11:48 PM
Posts: 234 ATL GA
demon1515
ATL GA
[Re: RV2]
#716408
04/07/13 10:08 PM
04/07/13 10:08 PM
Posts: 234 ATL GA
demon1515
ATL GA
