Page 1 of 7 1 2 3 4 5 6 7
1972 Dart street toy. #716309
06/04/10 10:44 PM
06/04/10 10:44 PM
ATL GA
demon1515 Offline OP
ATL GA
Re: 1972 Dart street toy. [Re: demon1515] #716310
06/04/10 10:46 PM
06/04/10 10:46 PM
ATL GA
ATL GA
OK, THE TRUCK ARRIVES!!!!!!!!
Original Mopar Tuff steering wheel + addapter "Hard pice to come by, and not cheap"
Good used front lower balance, bumper guards deleted
Manual aluminum steering box "real light unit"
Mancini Racing billet front motor plate, fluid damper harmonic ballancer, hurst competition shifter, custom disc brake front conversion i pice together with wilwood parts and RX-7 rotors
Eagle rods with arp2000 bolts for the 440 big block engine "check em up in comparation with the 2jz rod!
4 speed new procces mopar crash box! "SWEETTT"
Eddy Torker 440 intake and B1 big block valve covers
440 Source SFI billet flywheel
440 Source billet 1/4 inch gridle and main studs assembly with windage tray and billet rear main seal cap
1968 HP2 mopar big block 440 engine and Lakewood scattershield
3.73 gears Dana 60 diff
Stick [Edited by Moparts - Family Friendly Site - Keep it clean] pedal assembly
Car Tool 1/8 inch contoured subframe connectors specially build for the Dart
Re: 1972 Dart street toy. [Re: demon1515] #716311
06/04/10 10:47 PM
06/04/10 10:47 PM
ATL GA
ATL GA
Well parts are keep comming
Edelbrock performance RPM max wedge aluminum heads
Re: 1972 Dart street toy. [Re: demon1515] #716312
06/04/10 10:48 PM
06/04/10 10:48 PM
ATL GA
ATL GA
New updates in this,
I redrill the factory 5x4 front hubs and use RX-7 front rotors, the calipers are wilwood 4 piston (not installed yet) but prety easy to do by just fab a 3/16 brackets that bolt it on the spindle, weld 2.0 wheels and 165/80-15 street tires, this is a custom brake that really works and cheap less than $200 for it and my work fabricating the setup, it will use stainless braided brake lines.
Re: 1972 Dart street toy. [Re: demon1515] #716313
06/05/10 01:36 PM
06/05/10 01:36 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Those front rims totally change the personality of the car.
Is this going to be a race car or a street car? Are you going to do wheeltubs out back?
Re: 1972 Dart street toy. [Re: Neil] #716314
06/05/10 03:36 PM
06/05/10 03:36 PM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
I agree. I think people might be curious on how wide of a tire you're going to run out back as well.
Re: 1972 Dart street toy. [Re: OrangeProwler] #716315
06/05/10 09:43 PM
06/05/10 09:43 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Looking good
Re: 1972 Dart street toy. [Re: SRT6776] #716316
06/05/10 10:01 PM
06/05/10 10:01 PM
ATL GA
ATL GA
Thanx for the comments guys,
it is going to be a street strip car more street than strip it will be on 275-60-15 rear tire on 15x10 with 3.5 backspace and a dana60 dont know yet if i will fab a custom unequal 4 link system with coilovers or stock leaf springs eather way it will have minitub done with spring relocating system installed,
More pictures soon as i took the boat achor slant 6 out of the way
Re: 1972 Dart street toy. [Re: demon1515] #716317
07/28/10 08:57 AM
07/28/10 08:57 AM
ATL GA
ATL GA
A litlle front end change i think it looks better with this grill!
Before
After
Re: 1972 Dart street toy. [Re: demon1515] #716318
09/18/10 07:43 PM
09/18/10 07:43 PM
ATL GA
ATL GA
SOME minitubing manual steering box and front end love, UPDATE!
MINITUBING, this is a very easy one to do, but it took me about 4.5 hrs. per side.
Manual steering box with no adapter whatsoever very easy from power to manual!
SOME FRONT SUSPENSION LOVE, still need to install the new 90-10 drag shocks,
Re: 1972 Dart street toy. [Re: demon1515] #716319
09/18/10 07:54 PM
09/18/10 07:54 PM
ATL GA
ATL GA
I also score here a set of TTI 2 inch primaries underchassis headers for A-body, they are sweet! 8-)
Re: 1972 Dart street toy. [Re: demon1515] #716320
10/23/10 06:42 PM
10/23/10 06:42 PM
ATL GA
ATL GA
US CAR TOOL SUB FRAME CONNECTORS, driver side first the pass side next week, i run out of shielding gas :evil: !
By the way they fits like a glove very happy with the fit and fitment!
Re: 1972 Dart street toy. [Re: demon1515] #716321
10/25/10 09:46 PM
10/25/10 09:46 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
Your gonna hate putting the TTIs on, the look and work great but are a PITA to install and remove. just took mine off my dart to use in another project. the next set will be custom. BTW on yours.
Re: 1972 Dart street toy. [Re: Randy..] #716322
10/26/10 01:38 AM
10/26/10 01:38 AM
ATL GA
ATL GA
Ohh yea i can imagin me lifting the engine everytime they need to be removed for something, i hope the new starter wont get messed up anytime soon as well as the header copper gaskets, or anything requared the remmove of them
Re: 1972 Dart street toy. [Re: demon1515] #716323
11/08/10 03:19 PM
11/08/10 03:19 PM
ATL GA
ATL GA
here is the other side of the frame connectors done!
Re: 1972 Dart street toy. [Re: demon1515] #716324
11/08/10 03:36 PM
11/08/10 03:36 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
Re: 1972 Dart street toy. [Re: demon1515] #716325
11/10/10 06:45 PM
11/10/10 06:45 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
That's looks like it is going to fun
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 1972 Dart street toy. [Re: BloFish] #716326
11/10/10 10:16 PM
11/10/10 10:16 PM
ATL GA
ATL GA
Thanks guys,
So far is has been fun all the way now i am trying to get the rear suspension and the dana60 done before the cold wether comes so i can roll it arround to my friend shop in order to work on it during the winter time!
Re: 1972 Dart street toy. [Re: demon1515] #716327
11/10/10 10:34 PM
11/10/10 10:34 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Looking good! Id like to see it in person.
Re: 1972 Dart street toy. [Re: RV2] #716328
11/11/10 12:24 AM
11/11/10 12:24 AM
ATL GA
ATL GA
Yea Come on buddy, call me 678-492-8931!
