Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715675
06/05/10 07:33 AM
06/05/10 07:33 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Still waiting for an answer on my square-jetted using a power valve question! ANYONE EVER SEE OR HEAR OF THIS BEING DONE??? Thanks! RandyB
As your intuition is telling you...it is unusual. I've never seen it without something else being wrong. You can most likely rule-out a weaker 'signal' in the front half of the engine. Is the P/V sized correctly? Is it ruptured? If you want additional advise/views start a new post topic. I can only speak for myself but, I'll only read thru a post once even if I reply I rarely look for a reply to my reply...Because I don't reply often, LOL. I'm not sure but, it almost seemed like you were trying to use a similair # jet in a different carb? If that's the case then don't IMO. For me, at the track sometimes you just give it what it wants and ask Q's later. Hoodscoops can cause jetting issues that won't show up on a chassis dyno. Hopefully within the next 2 weeks Dartin' will be running and we'll all hang-out at the track to tune.
Re: DOMINATOR JETTING ON MY 448" ??? [Re: HardcoreB] #715676
06/05/10 11:35 AM
06/05/10 11:35 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Sean! The PV I'm running is a 4.5. My vacuum is 6" at idle,in gear. RandyB
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715677
06/05/10 11:41 AM
06/05/10 11:41 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I would say that`s not common and after chasing my tail for years and wearing out jet threads, the chassis dyno is the way to go+ have you messed w/bleeds yet. Have you opened the carb up to see if anything`s funky inside?
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715678
06/05/10 12:37 PM
06/05/10 12:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Tells me that the PV circuit is too small so you need
the added jet size to cover it up.... the carb has
been opened many times but I never measured the PV
holes... the carb was set on the dyno to the numbers
it has now
EDIT
I actually said it backwards the PV circuit is too
big... it might have a high flow PV and it could
use a standard... being that carb is old
Re: DOMINATOR JETTING ON MY 448" ??? [Re: MR_P_BODY] #715679
06/05/10 02:25 PM
06/05/10 02:25 PM
UK
602heavy Offline
602heavy  Offline
UK
Toss the PV & square jet accordingly , only the motor can tell you what size jetting for that carb , it all depends on how the motor is set up , going up in jet sometimes won't net any gains due to air speed having already been maxed out , messing with HSB/emulsion circuit can net some gains , i've always wondered why holley ships these carbs 88 square jet with two power valves , they could @ least supply jet extensions to the rear , but they don't.
Re: DOMINATOR JETTING ON MY 448" ??? [Re: 602heavy] #715680
06/05/10 03:15 PM
06/05/10 03:15 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I think some of you mis-read which carb has the power valve! NOT THE DOMINATOR! The 850 that the car was dynoed with. I think I might just square-jet the 850 also. Maybe start out with 86 squared,and go from there! Thanks guys! RandyB
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715681
06/05/10 03:21 PM
06/05/10 03:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy... why mess with it... it was on the dyno and
it works on your car... if its not broke dont fix it
Re: DOMINATOR JETTING ON MY 448" ??? [Re: MR_P_BODY] #715682
06/05/10 06:15 PM
06/05/10 06:15 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Mine is jetted 86/89 no power valves.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715683
06/05/10 07:30 PM
06/05/10 07:30 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
POVER VALVE FRONT AND 86 REAR NO POVER VALVE 92
Re: DOMINATOR JETTING ON MY 448" ??? [Re: cbarracuda] #715684
06/05/10 08:20 PM
06/05/10 08:20 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
On my last car, the DartSport, it had a #9375 carb and liked 98 jets , no power valves.
On this 69 Dart I have an old 9375 that was rebuilt by BIGS and it likes 86 jets squared, no power valves. You'll just have to do some testing.
Re: DOMINATOR JETTING ON MY 448" ??? [Re: ProSport] #715685
06/06/10 11:46 AM
06/06/10 11:46 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks guys! Hopefully I'll be back at it next sunday. New slicks should be in this week! Anybody using GoodYear D-3 compound? That's what these will be! Got a good deal on them from Harlow Tire,here in metro Detroit!
