Re: DOMINATOR JETTING ON MY 448" ???
[Re: Labratt]
#715675
06/05/10 07:33 AM
06/05/10 07:33 AM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Still waiting for an answer on my square-jetted using a power valve question! ANYONE EVER SEE OR HEAR OF THIS BEING DONE??? Thanks! RandyB
As your intuition is telling you...it is unusual. I've never seen it without something else being wrong. You can most likely rule-out a weaker 'signal' in the front half of the engine. Is the P/V sized correctly? Is it ruptured? If you want additional advise/views start a new post topic. I can only speak for myself but, I'll only read thru a post once even if I reply I rarely look for a reply to my reply...Because I don't reply often, LOL. I'm not sure but, it almost seemed like you were trying to use a similair # jet in a different carb? If that's the case then don't IMO. For me, at the track sometimes you just give it what it wants and ask Q's later. Hoodscoops can cause jetting issues that won't show up on a chassis dyno. Hopefully within the next 2 weeks Dartin' will be running and we'll all hang-out at the track to tune. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Labratt]
#715681
06/05/10 03:21 PM
06/05/10 03:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think some of you mis-read which carb has the power valve! NOT THE DOMINATOR! The 850 that the car was dynoed with. I think I might just square-jet the 850 also. Maybe start out with 86 squared,and go from there! Thanks guys! RandyB
Randy... why mess with it... it was on the dyno and it works on your car... if its not broke dont fix it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#715682
06/05/10 06:15 PM
06/05/10 06:15 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Mine is jetted 86/89 no power valves.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: cbarracuda]
#715684
06/05/10 08:20 PM
06/05/10 08:20 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
On my last car, the DartSport, it had a #9375 carb and liked 98 jets ![](/ubbthreads/images/graemlins/blush.gif) , no power valves. On this 69 Dart I have an old 9375 that was rebuilt by BIGS and it likes 86 jets squared, no power valves. You'll just have to do some testing.
