Re: Converter Slippage High "Powerglide" [Re: abodiesonly1] #713936
06/12/10 03:24 AM
06/12/10 03:24 AM
Arizona
Chris'sBarracuda Offline OP
Arizona
I was able to snag a decent pic from the vid!
That's cool.. I like it..
I tried it on the brake with the DA @ 4200 the other day. It stalled @ 6500 immediately. Would tickle the chip @ 6600..
I'm not certain it will help to tighten it up, but Gecker's opinion is to tighten it up 200-300 rpm. However, he also has said his fastest converter stalls @ 6700 in good air.
I still need to try several different things. It's much easier when something isn't breaking every pass..
We'll see..
Chris..
Re: Converter Slippage High "Powerglide" VIDEO ADDED [Re: Chris'sBarracuda] #713937
06/12/10 07:02 AM
06/12/10 07:02 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
I did some research on the JD Hygaurd. Many are running this fluid in nitrous cars.
I just tried my own experiment. I was running ATF type F and I switched to ATF +4. It tighten the converter noticably. I would say 200 rpms.My next step would be to try Red Line Race Trans fluid. This fluid is a higher viscosity than standard.
I believe the most aggressive change would be the hygaurd but from what I've read it will turn the inside of the transmission black.
