Holley 750dp tuning- advanced tactics?
#713353
06/01/10 04:45 PM
06/01/10 04:45 PM
Posts: 1,686 Philadelphia
radar
Philadelphia
I have posted here lots and gotten my tune up pretty good thanks to everybody's help. I have a holley 750 double pumper on my mild 408 (high 230s duration .525" cam, air gap, street headers, OD 4spd stickshift, 4:11s 28" tire). I am still battling with a lean spot at 2200 rpm. I have a wideband installed, and I'm currently switching (moved closer to work) from driving mostly highway to driving mostly stop and go ![](/ubbthreads/images/graemlins/frown.gif) I have been doing some reading and researching and I think I can maybe restrict my main air bleeds to transition to the main circuit sooner?I have no idea how to go about it in a scientific way. I have plenty of timing at idle, high 13s:1 afr at idle, curb idle not too far open (not too much transfer slot exposed), and it is not an off idle acc. pump thing- it happens at cruise or whenever I'm trying to drive gently around 2200rpm. I had masked the problem by running rich and cleaning up on the highway blasts but now I gotta dial it in for real to keep my plugs clean. Do I need to buy a more adjustable carb (HP series?) to address this? The car runs awesome on the highway, and accelerates great. I don't want to make it just a strip car and never drive it, but it is annoying in traffic with this lean spot. Thanks
Re: Holley 750dp tuning- advanced tactics?
[Re: Mr.Yuck]
#713355
06/01/10 06:47 PM
06/01/10 06:47 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
You don't want to drill them out, that'll make it leaner, those are Air bleeds, so if anything, you'll want to restricted them, but normally you really don't need to jack with the high speed air bleeds, if it feels good driving around, i agree, the heck with the "wideband", just tune for "best" drivability & MPH, if its only going 13.1 on the wideband, that is not lean, matter of fact, 13.2 AFR is about the best for overall power throughout NA, blower/nitrous/turbo cars like alittle more fuel, but if your dropping below 13.0 AFR NA your heading on the downward slide for best power/drivablity.
[Re: radar]
#713357
06/01/10 07:11 PM
06/01/10 07:11 PM
RapidRobert
I'd see what in hg of vac you have at the dead spot and see how much pump shot you have @2200 and at that point is that at WOT or squeezing into it moderately.
Re: Holley 750dp- advanced tactics? MAB restriction?
[Re: RapidRobert]
#713359
06/01/10 07:26 PM
06/01/10 07:26 PM
radar
Philadelphia
Thanks for the replies but my question wasn't about drilling anything or accelerator pump shots or wideband tuning. The car comes off idle fine and the squirters get her going like they should. There is no stumble on tip in from idle and the afrs I listed etc were to rule out common tuning pitfalls.
I have read that RESTRICTING the main air bleed can make the main circuit come on sooner. I believe what I am dealing with is a problem with the overlap or lack thereof between the transfer (idle circuit still active) to the mains.
And like I said, the car ran fine when I was mostly on the highway because I was able to run rich on the bottom to cover this lean spot and all the highway running would keep everything clean and happy. Now that I live near work I have to lean up the idle and jetting to be able to run lean enough to keep clean plugs.
I've got it close- good power and clean plugs with great throttle response and no pinging. I just can't get rid of this lean spot at cruise at 2200 rpm. No pump shot, no pressing the gas, no drilling, no chasing a magic af number. I am trying to find out about turning my mains on 2-300rpm earlier.
Robert you gave me a thoughtful answer- thanks. I need to reconnect my vac. gauge but I can tell you I am fine when pressing the gas and getting a shot and WOT is scary but works just like it should. It is at cruise or light throttle that I have a problem.
Edit: I have a 4 corner idle 750dp with 3 hole 1" spacer. settings are currently as follows: idle screws 7/8 turn out main jets 72 8.5 power valve (pvcrs are tiny on the DPs anyway) idles at 850rpm curb idle screw 3/4 turn in
Rear metering block has PV plug and 80 jets. WOT works like it should. An agressive launch covers the lean spot with acc. pump shot.
I have heard of using wire to reduce the MABs (main air bleeds) and make the main circuit come on sooner? I'm looking for someone with experience doing it. I have used wire to restrict pvcrs on a 350 holley 2 barrel before for use on a hot slant 6, so Im not completely new to this game.
[Re: radar]
#713360
06/01/10 08:30 PM
06/01/10 08:30 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
""I have read that RESTRICTING the main air bleed can make the main circuit come on sooner."" Radar, I have read the same and Quick Fuel explained the same theory when dealing with the air bleeds. 2200rpms is real close to when the mains should start coming in. If you have adjustable air bleeds, try a set of air bleeds apx .002" SMALLER to bring the mains in quicker (richer). Please check your wideband to see how much quicker they came in and then you can estimate the size easier if you have to make another change. If .002" (x 4 bleeds) makes a 100rpm difference, then you can use that as a reference.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#713362
06/01/10 08:35 PM
06/01/10 08:35 PM
radar
Philadelphia
Thanks man thats the info I'm looking for. I don't have adjustable bleeds. I guess I'm looking at either sticking pieces of wire in there or drilling and tapping for a brass set screws and then drilling them like jets?
About the smaller carb-I know I could use a 650 but I want to get the most out of my stroker. A 750 isn't too radical for a warm 408 with 4:11 gears in a light 4spd car and I do enjoy righ rpm blasts pretty often (after dark). Unfortunately on the way to work it is a parade of people doing 35 in a 40mph zone. I know I'm trying too hard when I could maybe buy an eddy carb or something but I only know hollys and I want to make it work. My pump cams work fine, and I'm not having any trouble with the secondaries, just light throttle cruise. I can cruise in low gear but that gets old. I know my motor should have power there not a flat spot.
I came this far! Do I need to get an HP holley or proform main body with adjustable bleeds or can I work with the standard double pumper?
rdr
[Re: RobX4406]
#713365
06/01/10 09:31 PM
06/01/10 09:31 PM
radar
Philadelphia
I'm running a 275HL comp cam (high 230duration)in a 408 it should have smooth torque available at 2200 even if the HP doesn't come in until 3k+ ?
The car does a surging stumbling thing around 2200. At cruise it doesn't ever run well at that rpm. At cruise a pump shot is always a neck snapping acceleration out of the bad spot. The problem is not evident if I launch the car- the acc pump covers the bad spot. If I am cruising and it loses power then jerks foreward I can always look down at the tach and see 2200rpm. I have no trouble cruising at lower rpm- I have decent power below and above 2200rpm.
This isn't my first time tuning with a wideband and I am not chasing a straight line afr. For a baseline I like to see 13-16 at cruise and 12-14 under power. Anything better than that is fine tuning to me. An occasional dip to 11s or 16s doesn't freak me out and I understand how to lean out the mains to use the power valve under load/low vac. I also understand that the double pumper has small pvcrs and is meant to run a little rich. Thats fine, I just want my plugs to stay clean without blasting them out on the highway every day. I now have that, but the 2200 spot is getting worse at the same time.
I'm just getting real close to running clean for stop and go traffic but this problem at the overlap spot between circuits is becoming more evident now that I'm taking away unneccesary richness in the idle/transfer circuits and mains. If it was a race car it wouldn't be a problem at all but I'm chasing street drivability.
Also I am running an OD 4spd so I can't just run the r's up before shifting without screaming for longer than is fun or running up somebody's butt. I don't actually cruise in 4th unless I'm doing over 70mph- 1:1 third is too much fun on the highway.
[Re: 451Mopar]
#713368
06/02/10 07:07 AM
06/02/10 07:07 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
What is your timing at 2200 rpm? If you have vacuum advance, disconnect it and check if it gets better?
ahh yes I forgot to ask that. I'd drop the vac advance and try full timing at 2400...maybe start at 36* and go up. My old 340 liked 38* at 2400. What size are your primarys? I used 72-80's and 28 squirters. (750HP)
[Re: Mr.Yuck]
#713369
06/02/10 09:53 AM
06/02/10 09:53 AM
Posts: 531 Virginia
JimG
Virginia
No. Increasing the size of the MABs will make make the mains begin to flow at LOWER airflow (sooner) and decreasing them will make the mains begin to flow at HIGHER airflow (later). Think about why the MABs are there. Without them, the carb would get richer and richer as airflow increased. The air bleeds are there to modify this behavior. The introduction of air creates an emulsion which flows easier than liquid fuel. Easier flow = "sooner" flow. This is greatly oversimplified, but if you think it through I think you'll see what I mean. But don't take my word for - I'm just some guy on the internet that you don't know from Adam, and you know how internet advice goes. ![](/ubbthreads/images/graemlins/laugh.gif) You're already inclined to mess with the MABs anyway, so just go way overboard and restrict the heck out of them and watch your wideband and see what happens. A well-secured paperclip or wire will do nicely. I'm not trying to bag on the guys who said they've read the opposite of what I'm saying. I've read it too. All I'm saying is try it for yourself and come to your own conclusion. Modifying the carb to accept homemade screw-in air bleeds, as you already mentioned, is no big deal at all. For the MABs, 8-32 brass screws work just fine, and the soft metal in the Holley main body is easy to drill and tap. For IABs, you might want to go 10-32 (if there's enough meat in the main body) as the orfices will need to be larger and you usually have very little hex left in a 8-32 by the time you drill to the proper size. Finally, you mentioned that you might have a "hole" between the main and transition circuits. Possible, and easy to check by changing the air bleeds. Far more common is too much overlap between the transition circuit and the mains, causing pig-rich conditions at light throttle, especially under high vacuum conditions. Are you sure you don't need more main jet? Based on what you've said, I think you're on the right track by experimenting with the MABs. Just be darn sure you measure very carefully the existing press-in air bleeds so you can get back where you started if you lose the rabbit. Once you do that, you can do no harm as long as you don't screw up when you drill and tap the main body for screw-in MABs.
[Re: JimG]
#713370
06/02/10 12:10 PM
06/02/10 12:10 PM
joedust451
super gas
super gas
Branson, Mo.
Installing screw-in bleeds is not hard at all, you should really never have to mess with the sizeing of the HSBs, i'll bet "anything" its that 1" spacer causeing your problems, you need to increase the jets 2 & 2 when running a 1" spacer as a start, your too lean, install some 74/82s & i bet the problems "gone", but don't take my word for it lol.
