Why is my rubber leaf spring squeaking? Sound clip
#712250
05/31/10 12:59 PM
05/31/10 12:59 PM
Posts: 4,882 Florida
BDW
This is a follow-up to a previous post. I have ESPO leaf springs with rubber bushings, moved inward 1" with Dr Diff relocation kit. The rubber bushing has a very annoying squeak. I have loosened the bushing bolt to allow the assembly to move in case there was binding. It seems like the squeak is caused by the bushing rubbing the hanger. I have tried dripping some lube on the area but it didn't seem to help. Any ideas? http://www.youtube.com/watch?v=MVtGbAdKAgM
Re: Why is my rubber leaf spring squeaking? Sound clip
[Re: BDW]
#712251
05/31/10 01:04 PM
05/31/10 01:04 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Have you tried loosening the bolt, putting it at ride height, then tightening the poop out of it? I don't think the rubber is actually suppose to move and putting lube in there will make things worst.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: Mopar_Country]
#712254
05/31/10 01:20 PM
05/31/10 01:20 PM
BDW
No offense taken, I appreciate all inputs.
I'm fairly certain it is coming from the area. You can cup your hand around the eyelet and feel the vibration. I can also push up on the eyelet and hear a groan.
I did try to use a scope but the sound comes from the entire leaf spring, it's actually easier to hear by ear alone. And it's loudest at the bushing.
Thx
[Re: BDW]
#712257
05/31/10 09:34 PM
05/31/10 09:34 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
The outer shell of the bushing should move with the leaf spring. The inner shell should stay with the bolt and the car.
So there is no moving parts. The rubber will twist to allow movement.
The inner shell should be very tight in the box. Not neccessarily during install but definately after the bolt is tighten up and that's why it's important to do this when the suspension is loaded.
[Re: BDW]
#712260
06/03/10 02:54 AM
06/03/10 02:54 AM
Magnum
Yes, it makes sense and it's also very easy to see.
Bounce the car and see if the bolt is moving.
