Re: is 200 temp ok for 440 ?
[Re: BobN]
#711659
05/30/10 10:52 PM
05/30/10 10:52 PM
Posts: 565 IA
landon1
IA
i run about 200 or so with my 440 - always has, before and after rebuild. with a 190-195 thermostat, it makes sense
'71 Satellite Sebring 440
[Re: landon1]
#711660
05/30/10 11:35 PM
05/30/10 11:35 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
200 is perfectly normal.
I don't know why people get worried about it.
[Re: terzmo]
#711661
05/31/10 12:39 AM
05/31/10 12:39 AM
DaytonaTurbo
Manitoba, Canada
shroud will do nada at highway speed...the rad gets full cooling air at highway speeds..the shroud helps the fan pull air at low speeds....200 at highway speeds means the rad is not efficient enough...
While I agree a shroud only helps with low speed cooling, once you hit 30mph or so the cooling is all air flow from moving, not from the fan.
Showing 200 on the gauge while on the highway is to be expected if you're running a 195 t-stat. Now if he was running a 180 t-stat and doing 200 on the highway, then I would say your cooling system does need some attention.
BobN, what temp rating of t-stat are you using?
And yes the redline water wetter does help, I've used it.
[Re: DaytonaTurbo]
#711665
05/31/10 10:19 AM
05/31/10 10:19 AM
Supercuda
About to go away
About to go away
up yours
[quote Showing 200 on the gauge while on the highway is to be expected if you're running a 195 t-stat. Now if he was running a 180 t-stat and doing 200 on the highway, then I would say your cooling system does need some attention.
Your thermostat only regulates the minimum temperature, not the maximum.
If an engine runs down the highway at 200 degrees with a 195 thermostat, then it will run down the highway at 200 degrees with a 160 thermostat. At best a lower rated thermostat will just delay the amount of time it takes to get to the system operating temperature.
The only time a thermostat will affect maximum temps (assuming no failure mode) is if the thermostat is artificially keeping the minimum system temperature above it's normal operating temperature.
[Re: BobN]
#711667
05/31/10 01:18 PM
05/31/10 01:18 PM
Posts: 936 own private Idaho
ngpSatellite
own private Idaho
have Mopar hemi waterpump, Mopar 71 BB hi flow radiator, shroud and Mopar clutch fan . I am throwing a bottle of Water wetter in tomorrow , Cant hurt. I am thinking to get a good aftermarket coolant gauge . So I know if correct reading. I do not not enough money to have my radiator redone by Glen Ray. That will be some other year.
will putting a trans cooler help?
IS THE WP HOUSING STOCK?? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: DaytonaTurbo]
#711670
05/31/10 01:55 PM
05/31/10 01:55 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
![](/ubbthreads/images/graemlins/iagree.gif)
