Page 2 of 3 1 2 3
Re: SS SPRINGS [Re: ademon] #710329
06/04/10 01:43 PM
06/04/10 01:43 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Got that, I knew they were stacked stiffer on the pass side.
Re: SS SPRINGS [Re: Moparnut426] #710330
06/04/10 11:27 PM
06/04/10 11:27 PM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
Here's a set of "new" SS springs that were NOT heavy enough. When the car would launch it felt like it was going to roll over on the right door. I ended up adding a extra leaf to the right side. (took the 2nd leaf from the old SS spring and made it the 3rd leaf on new set). The car sits with the RR higher than the left, but it launchs fairly level. 11.5MT's, 4:56 Dana, no snubber, 3200 lbs, Calvert front shocks, 6 cyl torsion bars.
I'm pleased with mine.
Brian
Re: SS SPRINGS [Re: '72CudaRacer] #710331
06/04/10 11:28 PM
06/04/10 11:28 PM
Mooresburg, Tn
Mooresburg, Tn
another
Re: SS SPRINGS WITH FLOATERS???? [Re: '72CudaRacer] #710332
06/11/10 10:13 AM
06/11/10 10:13 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
I have been reading some posts and online about floaters and thought id ask if any of you use floaters WITH your SS springs???
Re: SS SPRINGS WITH FLOATERS???? [Re: MIKES_DUSTER] #710333
06/11/10 01:09 PM
06/11/10 01:09 PM
Mooresburg, Tn
Mooresburg, Tn
I'm not aware of anyone doing that. The floaters are used when you have leaf springs AND ladder bar/4 link set. Now days you can buy a set of coil over shocks relativly inexpencive. Add a dia bar and no need for heavy springs.
Brian
Re: SS SPRINGS WITH FLOATERS???? [Re: '72CudaRacer] #710334
06/12/10 09:02 PM
06/12/10 09:02 PM
Thanks.
Re: SS SPRINGS WITH FLOATERS???? [Re: MIKES_DUSTER] #710335
06/13/10 12:13 AM
06/13/10 12:13 AM
What I meant was sliders,NOT floaters!!!
Re: SS SPRINGS WITH FLOATERS???? [Re: MIKES_DUSTER] #710336
06/27/10 09:10 PM
06/27/10 09:10 PM
My old leafs are out and my SS springs will be in hopefully tomorrow night or at least this week. My new front hangers will be here tomorrow too.
I have 2 questions.
1, Which spring on which side??? (002/003)
2, What pinion angle do I need??
Re: SS SPRINGS WITH FLOATERS???? [Re: MIKES_DUSTER] #710337
06/27/10 09:17 PM
06/27/10 09:17 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
02/03 is the part # left /right spring, the spring with the extra leaf should go on the pass/R side thats why a lot of cars with SS springs sit a bit higher on the pass side.
Quoted from a half dozen posts up.
As for pinion angle , I am shooting for 3 down to start and will shim till happy.
I am using sliders , but am still a ways from putting laps on it.
On paper , they are a fine idea.
We'll be finding out how good of an idea it is on concrete pretty soon I hope.
383man [Re: tubtar] #710338
06/27/10 10:17 PM
06/27/10 10:17 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have the 3400 lb springs on my 63 and they work great for me. C-body long shocks and no snubber. Ron
Re: 383man [Re: 383man] #710339
06/30/10 11:11 PM
06/30/10 11:11 PM
Well,my SS springs are FINALLY in!!!!! A BIG thanks goes out to my buddy John who helped me take the old leafs out and put in the new leafs!!!!!!
I do have a question...On the purch theres 3 holes,we put the dowel pin on the leafs in the middle hole and it looks like it moved my rear forward a inch or so.
My question is...Can I move it back to the back hole to get my tires more clearance in the front of the wheel well???
Re: 383man [Re: MIKES_DUSTER] #710340
07/01/10 01:07 AM
07/01/10 01:07 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Well,my SS springs are FINALLY in!!!!! A BIG thanks goes out to my buddy who helped me take the old leafs out and put in the new leafs!!!!!!
They should be in the middle hole, so thats ok, if i remember, the SS springs will have the Pin alittle more forward then on the stock springs, i'm sure they did this for better spring control & less wrap-up, If the tires clear, you should be good to go
Mike, make sure you check pinion angle, see where the trans tail shaft is at, then adjust from there, shoot for a bare minimum of -4, also make sure the rear hangers are in the 10:00 & 4:00 a clock position, top 10:00, bottom 4:00.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 383man [Re: joedust451] #710341
07/01/10 09:03 AM
07/01/10 09:03 AM
I havent set up the pinion angle as of yet. Im still putting my motor together and when thats done we will put the motor/tranny in together. As of right now,it is 7 degrees.
So,CAN I move the rear back and put the SS pin in the back hole of the purch???
Re: 383man [Re: MIKES_DUSTER] #710342
07/01/10 03:08 PM
07/01/10 03:08 PM
Anyone????
Re: 383man [Re: MIKES_DUSTER] #710343
07/01/10 03:33 PM
07/01/10 03:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve never tried that but wouldn`t that mess up the u-bolt location in terms of how it clamps to the housing?
Re: 383man [Re: MIKES_DUSTER] #710344
07/01/10 04:53 PM
07/01/10 04:53 PM
sweden
sshemi Offline
sshemi  Offline
sweden
sure you can but you will have to offset the hole in the lower plate the same amount
Re: 383man [Re: MIKES_DUSTER] #710345
07/01/10 05:11 PM
07/01/10 05:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why not put spacers at the front of the front hanger
to move it back
Re: 383man [Re: MR_P_BODY] #710346
07/01/10 10:27 PM
07/01/10 10:27 PM
to move it back
Now THATS a GREAT idea!!!!
Re: 383man [Re: MIKES_DUSTER] #710347
07/02/10 12:50 AM
07/02/10 12:50 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Mike, i wouldn't try & move the rear back, if anything, you want to move it forward, Remember the "altered" Mopars back in the 60s, they move the rear forward for a reason , if you still have tire clearance in the stock position (which you should) just leave it be.
Re: 383man [Re: joedust451] #710348
07/02/10 10:09 AM
07/02/10 10:09 AM
Joe...I do have clearance but with these new SS springs,my 1/4 is sitting about 2" higher than before. I need new QTP's so I thought I would go from 28" tall to 29" tall to FILL IN the wheel well. If I do that,I would need to move the rear back about an 1".
Page 2 of 3 1 2 3
