Page 1 of 3 1 2 3
SS SPRINGS #710309
05/28/10 11:46 PM
05/28/10 11:46 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Are you happy with them???
Re: SS SPRINGS [Re: MIKES_DUSTER] #710310
05/28/10 11:52 PM
05/28/10 11:52 PM
Clinton Twp, Michigan
DerickS Offline
DerickS  Offline
Absolutely! Have been with the same pair for over 10 years
Re: SS SPRINGS [Re: DerickS] #710311
05/28/10 11:54 PM
05/28/10 11:54 PM
What do you 60'?? Did you turn the front hanger upside down to lower the rear end??
Re: SS SPRINGS [Re: MIKES_DUSTER] #710312
05/29/10 08:50 AM
05/29/10 08:50 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Mine have worked great for over 25 years.
Nautilus Racing-
Re: SS SPRINGS [Re: Chris2581] #710313
05/29/10 09:30 AM
05/29/10 09:30 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
1.36 60' 02/03 with mopar drag shocks, no snubber....Phill
Re: SS SPRINGS [Re: 9 Sec Phill] #710314
05/29/10 09:57 AM
05/29/10 09:57 AM
Raleigh N.C
hemiparts Offline
"Missile Pilot"
hemiparts  Offline
"Missile Pilot"
Raleigh N.C
Have 02/03 on my Duster and they work like a champ. Should I dump my pinion snubber ??
Re: SS SPRINGS [Re: hemiparts] #710315
05/29/10 10:01 AM
05/29/10 10:01 AM
MR_P_BODY Offline
Happy Birthday MR_P_BODY  Offline
Try it without it.... if the front of the spring is
strong enough you wont need the snubber BUT if the
spring gets too much wind up the snubber will help
cover the problem
Re: SS SPRINGS [Re: MR_P_BODY] #710316
05/29/10 10:53 PM
05/29/10 10:53 PM
ohio
1Bad440 Offline
1Bad440  Offline
ohio
002 & 003 Mexican made
Re: SS SPRINGS [Re: MIKES_DUSTER] #710317
05/29/10 11:04 PM
05/29/10 11:04 PM
DerickS Offline
DerickS  Offline
60 foot mid 1.6's did not flip the hanger or lower the rearend....its not a chevy guy!
Re: SS SPRINGS [Re: DerickS] #710318
05/30/10 02:11 AM
05/30/10 02:11 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Mike, what springs are you running? Are you thinking of changing them? SS springs do work, but theres other stuff you need to do to make them benifit as i'm sure you know, like setting a steeper pinion angle, good shocks, then setting the rear hangers properly, i just did some mods too my old stock 5 leaf springs & the results are really good, i had NO seperation in back to help plant the tires, so the tires just "skated", at the track i needed to get them hot & then pray they would hook, the main problem was i never put in a snubber back on do to all the Neg. feedback on them, i figured clamping the front segments would be enough, well it obviously wasn't, just last week at the track it was squaling the DRs on the 1-2 shift , never did that before, so just yesterday i installed my homemade snubber figured what the hell, it is sitting just shy of a 1/2" from the floor, that fixed it, it now seperates a good 2-3" back there & plants the tires nicely, so nice it boggs the engine down & hooks, the front end now yanks ups really good, so this might be something you may want to try if you have old springs, i also installed 1/4" thick steel plate 2.1/2 wide x 16" long on the top of the front segments & clamped it all down, & then pulled off the rear straps on the springs, the car acts "totally" different now, it reacts like a mopar
Whatever you decide, good luck with it
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: SS SPRINGS [Re: joedust451] #710319
05/30/10 09:54 PM
05/30/10 09:54 PM
Thanks guys and yes,you too Derrick!!!!
Joe...I have stock springs that are SHOT!!! There bent and broke where the bushing is. A Moparts member from Pa "HOOKED ME UP" with a set of SS 3 weeks ago so I am planning on putting them on.
Re: SS SPRINGS [Re: MIKES_DUSTER] #710320
05/30/10 11:44 PM
05/30/10 11:44 PM
organ
maximum entropy Offline
organ
ss springs work great. i've had a set of 002/003s on my turd FOREVER. they will not die. i moved them into the frame rails, and i run 2" billet lowering blocks, no snubber, and rancho 9000S set on 7 usually. i got a 1.56 60' on drag radials at our iceskating rink last time out.
Re: SS SPRINGS [Re: maximum entropy] #710321
05/31/10 08:50 AM
05/31/10 08:50 AM
utica ny
meus31 Offline
meus31  Offline
utica ny
I have a customerscar with 02 03 on it 70 duster with 3.5 degrees pinion angle with a pump gas 408 and a 727 and a 8 inch turbo action convertor and 430 its been 10 48 at 126 with a 144 60 ft time . gonna try 4.5 degrees pinion angle gonnaput a set of afco sliders in the back to lower the car hopfully a inch and a half or so it has qa1 shocks all around was also wondering if any of you guys have ever tried any staggered shock settings .a also had lenny at ultimate convertor build a convertor matched for the motor so we will see.
Re: SS SPRINGS [Re: meus31] #710322
05/31/10 09:25 AM
05/31/10 09:25 AM
Whats in the 408?? Any pics of the duster??
Re: SS SPRINGS [Re: MIKES_DUSTER] #710323
05/31/10 04:39 PM
05/31/10 04:39 PM
utica ny
meus31 Offline
meus31  Offline
utica ny
I will try to get you some pics its a pretty neat car cause the guy bought it when it was like 4 weeks old and hes had it ever since and other than one quarter it retains all it original paint . its a 408 all eagle rotator 10 75 to 1 comp. a super victor intake with a set of ryan ported eddys its a solid roller with around 640 lift and 256 intake duration i beleave 260 exhaust @ 50 it has a quick fuel 850 on it with a 727 trans and a 8 3/4 with 430 in it. not sure of the weight but should now in a week or too. hopefully gonna try all the new stuff this week at the track
Re: SS SPRINGS [Re: meus31] #710324
06/03/10 11:29 PM
06/03/10 11:29 PM
Re: SS SPRINGS [Re: MIKES_DUSTER] #710325
06/03/10 11:39 PM
06/03/10 11:39 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
Have them 02/03 as well, 1.40 60ft so far!
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: SS SPRINGS [Re: MIKES_DUSTER] #710326
06/04/10 10:01 AM
06/04/10 10:01 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
For 1.50 or slower short times they are fine. For faster cars they are less and less effective the quicker the times. If someone doesn't want to go to the trouble or expense of a real race car suspension CalTracs are the next best option. I can hear the criticism coming but that's my opinion. I, personally, wouldn't use them on anything.
Re: SS SPRINGS [Re: BobR] #710327
06/04/10 01:34 PM
06/04/10 01:34 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Then what the HE!! am I doin wrong.
i have ss springs, et streets drag radials, 3.91 gears, and a snubber. 4 gear car also, I had summit rear shocks, was told they were too short. I bought the xtra long mopar shocks, they were only 1.5" longer. Havent driven the car since. I was running the air psi all over trying to get them to hook, and the best I could muster was a 1.99 60 ft.
What is the 02/03 all about?
Did I order too stout of spring when i ordered mine? I think I have the 3200lb spring.
Kasey
Re: SS SPRINGS [Re: Moparnut426] #710328
06/04/10 01:38 PM
06/04/10 01:38 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
02/03 is the part # left /right spring, the spring with the extra leaf should go on the pass/R side thats why a lot of cars with SS springs sit a bit higher on the pass side.
Page 1 of 3 1 2 3
