Re: 8.50 to 7.50 chassis certification question
[Re: blown572dart]
#708754
05/26/10 08:48 PM
05/26/10 08:48 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: blown572dart]
#708756
05/26/10 09:07 PM
05/26/10 09:07 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
you sunovagun..... watch it
[Re: joshking440]
#708758
05/26/10 09:17 PM
05/26/10 09:17 PM
Posts: 243 NJ
arc
NJ
[Re: joshking440]
#708762
05/26/10 09:37 PM
05/26/10 09:37 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
25.4 You will have to have rocker sill bar, dash bar, forward crossmember, seat bar, doors x-ed, funny car cage, and x-in the driveshart tunnel. I think that's all. Because of the stock floor you do not have to have the diagonals under the seat.
[Re: Leon441]
#708763
05/26/10 10:37 PM
05/26/10 10:37 PM
Posts: 2,287 Hamilton,Ont
72chrgrally
Hamilton,Ont
Is your current cage moly or mild steel? Steve
Photobucket sucks
[Re: joshking440]
#708764
05/27/10 12:24 AM
05/27/10 12:24 AM
Posts: 54 Illinois
Ted P
Illinois
The easiest is 25.5 good to 7.50 can be chrome moly or mild steel. The other certs are 6.50@3600# for 25.3 and 6.00 @3200lbs for 25.2 and both only moly. If you're trying to do it youself go to sfi.com and buy the spec.
[Re: Leon441]
#708767
05/27/10 01:32 PM
05/27/10 01:32 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Mine is chrome moly. I have a dash bar, I have bars going out to the front frame rails (is that forward crossmember?) Im confused on x in the drive shaft tunnel?
[Re: joshking440]
#708769
05/27/10 01:54 PM
05/27/10 01:54 PM
Posts: 4,321 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
...You will have to have rocker sill bar, dash bar, forward crossmember, seat bar, doors x-ed, funny car cage, and x-in the driveshart tunnel. I think that's all. Because of the stock floor you do not have to have the diagonals under the seat. Mine is chrome moly. I have a dash bar, I have bars going out to the front frame rails (is that forward crossmember?) Im confused on x in the drive shaft tunnel?
The front trans. crossmember CAN serve as your fwd. crossmember(series 6a-c)if the cage is built accordingly. The 'X' in the tunnel would go between your dimensionally legal subframe connectors possibly holding a driveshaft loop as well.
[Re: joshking440]
#708771
05/27/10 03:11 PM
05/27/10 03:11 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
with a stock firewall and floor you do not need any x bars under the car. You do need a bar from the frame connector to the sill bar behind the seat. Only the bars in the divers compartment are part of the cert. the bars going from your dash bar out under the hood do not matter.
if you have a 1 5/8ths cage now you can add the funny ca cage, roof bar and gussets pretty easy. If you are going to do this yourself you should get the sfi book as it lists all of the different sizes you can use.
BB, TT5,Procharged 3300lb Street Car 4.79/154
