Re: 383man
[Re: ZIPPY]
#707229
05/26/10 12:35 PM
05/26/10 12:35 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Doug, shooting for Lapeer Sunday.
Last time I went to Milan I got a whole two passes about 6 hours apart, and no water to do a burnout in. It just wasn't worth it. I'd rather stay home and watch TV than do that again.
hmmmm i was hoping to bring my car,,,and run at Milan,,, last time i was there,,the track was very good...... we'll see if the wife agrees to dragging the car and trailer,,,,up to Michigan,,,, ![](/ubbthreads/images/graemlins/beer.gif)
Re: 383man
[Re: 69CHARGERMD]
#707230
05/26/10 12:50 PM
05/26/10 12:50 PM
Posts: 17,923 S.E. Michigan
ZIPPY
S.E. Michigan
Well if you go, good luck man I'll take spinning 11s if that's all I can get. A MPH number would be nice to have about now. I went to Lapeer November 2009 with the 2008 Challenger (before we tore it all apart). There was no noticeable wheelspin and it ran a string 1.50 60 footers... But then again that isn't a leaf spring car.
Re: 383man
[Re: ZIPPY]
#707231
05/26/10 01:35 PM
05/26/10 01:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I went to Lapeer November 2009 with the 2008 Challenger (before we tore it all apart). There was no noticeable wheelspin and it ran a string 1.50 60 footers were the norm. But then again that isn't a leaf spring car.
Not very often do I have a problem at Lapeer when it comes to traction.... for me its the shut down area and I dont like to use my chute(unless its a must) ![](/ubbthreads/images/graemlins/wave.gif)
Re: 383man
[Re: MR_P_BODY]
#707232
05/29/10 12:20 AM
05/29/10 12:20 AM
ZIPPY
S.E. Michigan
Only one day left, any more guesses? Never tried setting idle mixture using the fast a/f display (and vacuum gauge at the same time) until earlier tonight, and that was different. The RPM is higher, the vacuum is higher, and the idle feels stronger at 17 or 18:1 than at 14:1 for some reason? When I set it by ear or vacuum it ends up at 17 or 18:1 every time. I put it in the 14s at operating temp thinking maybe it will help it run cooler at low speeds ![](/ubbthreads/images/graemlins/shruggy.gif) Don't really like the fact it makes the quality worse, but don't understand what's up with it. Need more time playing with it I guess. Nothing left to do but swap a couple parts around tomorrow, fuel up and take a spin.
Rich H.
Esse Quam Videri
Re: 383man
[Re: Labratt]
#707235
05/29/10 11:43 AM
05/29/10 11:43 AM
BradH
Rich,we'll definately have to line the X's up tomorrow!
Oh, that'll be fun to watch: ZIPPY, the light's green... ZIPPY, the light's green... ZIPPY, the light's green!!!
![](/ubbthreads/images/graemlins/tonguue.gif)
Re: 383man
[Re: Labratt]
#707237
05/30/10 12:09 AM
05/30/10 12:09 AM
ZIPPY
S.E. Michigan
You guys are probably not too far from the truth there, It has been a long time after all..... If I can get in one successful run without anything going haywire, we can get our photo op anytime after that Randy. I have video capability also but don't know if I'll bring the camera...sometimes, the less stuff to go wrong the better. Today was NOT supposed to be a thrash fest, just swapping tires and a couple parts, no big deal, relaxing day at home getting things done. Then at 11am I couldn't find the @#$^^@#$^$#!@#%^&%^& keys To make a long story short...keys were eventually found... 7 hours later ![](/ubbthreads/images/graemlins/rolleyes.gif) I wanted to be done by then.... I put a few miles on it on radials/the normal stock shocks I like to use, dinked with the idle mixture some more and it ended up just like last year...so maybe it was right to begin with. I could swear the idle mixture was changing on it's own for awhile there (which is possible, since it started with old gas in it), but after running some fresh fuel through it, it went back to normal. I then did the Hoosier cheater slicks, DS2 front runners, took off the sway bar, and put the QA1 front shocks on/ adjusted them to full loose in extension. Went for a spin to cool off, and it sure drives like crap ![](/ubbthreads/images/graemlins/laugh2.gif) I had totally forgotten how weird all that stuff feels until under power...definitely not the hot ticket for street use. But I'm gonna do it anyway, Lapeer ain't all that far. See you guys in the morning.
Rich H.
Esse Quam Videri
Re: 383man
[Re: ZIPPY]
#707238
06/01/10 12:50 PM
06/01/10 12:50 PM
ZIPPY
S.E. Michigan
And the results are: Bubba won the ET guess Mr. P won the MPH guess Kinda fun to see how that works out sometimes ![](/ubbthreads/images/graemlins/smile.gif)
Rich H.
Esse Quam Videri
