mini tub A body with spring relocate. What size tire?
#706949
05/25/10 12:04 AM
05/25/10 12:04 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
As described, 67 dart with mini tub and spring relocate. How big a tire are you running? Looking to run a 325 50 15 my et street radial on a 10" wheel. Thanks ![](/ubbthreads/images/graemlins/beer.gif)
Re: mini tub A body with spring relocate. What size tire?
[Re: dave571]
#706950
05/25/10 12:09 AM
05/25/10 12:09 AM
Triple Threat
Renton Washington
Frame rail to Quarter you'll have roughly 14-14.5" to work with. 325's will fit.
[Re: dave571]
#706952
05/25/10 03:19 AM
05/25/10 03:19 AM
Posts: 1,262 Netherlands
72Challenger
Netherlands
Don't know about these darts but on my Duster I did a minitub w/ springs relocated under the chassis and I can get away with 335/35/17's on 11x17" rims. Looks badass for a panther pink streetcar w/ lowering blocks.
[Re: 72Challenger]
#706953
05/25/10 03:35 AM
05/25/10 03:35 AM
Posts: 1,880 USA
Ron Silva
USA
I just put these 315/60/15's HOOSIER DOT Drag Radials on My 67 Valiant and I could easily go another inch wider. 10" rim, 11.1 tread, 29.7 tall. My wheel openings are stretched to accept the taller tire.
SRT DEMON ONE SEAT
[Re: dave571]
#706954
05/25/10 12:15 PM
05/25/10 12:15 PM
Posts: 43,359 Bend,OR USA
Cab_Burge
Are you willing to trim or stretch the wheel opening? If so a 315x60x15 or a 295x65x15 on a ten inch wheel will fit ![](/ubbthreads/images/graemlins/thumbs.gif) My duster has had the wheel openings stretched five inches, three on the front side and two on the rear, I moved the rear end forward one inch ![](/ubbthreads/images/graemlins/devil.gif) My intent was to be able to run that size and not get anyones attention(on the street) of having a big tire ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: Cab_Burge]
#706955
05/25/10 01:39 PM
05/25/10 01:39 PM
Posts: 1,178 Indy
FlyFish
Indy
I have 28x11.5 (10” tread, 11.2” section) QTP’s on a 10” rim…they fit fine, could go a little wider if I wanted to.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: Cab_Burge]
#706962
06/08/10 03:21 PM
06/08/10 03:21 PM
Posts: 1,476 Oh
RacerGofKGB
Got The Big One
Got The Big One
Oh
Yea. I can hardly notice. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: RacerGofKGB]
#706963
06/08/10 05:26 PM
06/08/10 05:26 PM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
I did the same thing to my 67 Dart, and plan on using a 325/50R15 tire on a 10 inch wheel.
The tubs and springs have been moved, but when I measured for the wheels, I needed to run 7 1/2" of backspace. This was not the look I was going for. Besides, the rear disc set up that I have recommends no more than 3 1/2" of backspace.
This means I will be having my rear end narrowed by 4" on each side to obtain the proper backspacing.
1970 Duster 340 clone
[Re: dave571]
#706965
06/08/10 08:34 PM
06/08/10 08:34 PM
Posts: 192 MI
RickRoss
MI
[Re: EDDIEB]
#706966
06/08/10 08:40 PM
06/08/10 08:40 PM
BrianT
Lees Summit, MO
What back spacing are you guys running with 10 in wheel?
I plan on running 3 1/2 inches...as soon as the rear end is narrowed.
